builder server manager undo sets for render view interactions and pushes them on the undo stack. More...
#include <vtkSMInteractionUndoStackBuilder.h>
| void | Clear () |
| Clear the undo set currently being recorded. More... | |
| void | StartInteraction () |
| Called to record the state at the beginning of an interaction. More... | |
| void | EndInteraction () |
| Called to record the state at the end of an interaction and push it on the stack. More... | |
| void | SetRenderView (vtkSMRenderViewProxy *) |
| Get/Set the render view proxy for which we are monitoring the interactions. More... | |
| virtual vtkSMRenderViewProxy * | GetRenderView () |
| virtual vtkSMUndoStack * | GetUndoStack () |
| Get/Set the undo stack that this builder will build. More... | |
| virtual void | SetUndoStack (vtkSMUndoStack *) |
Public Member Functions inherited from vtkSMObject | |
| static vtkSMInteractionUndoStackBuilder * | New () |
| static vtkSMInteractionUndoStackBuilder * | SafeDownCast (vtkObject *o) |
| vtkSMInteractionUndoStackBuilder () | |
| ~vtkSMInteractionUndoStackBuilder () override | |
| void | ExecuteEvent (vtkObject *caller, unsigned long event, void *data) |
| Event handler. More... | |
| void | PropertyModified (const char *pname) |
| vtkSMObject () | |
Protected Attributes | |
| vtkSMRenderViewProxy * | RenderView |
| vtkSMUndoStack * | UndoStack |
| vtkUndoSet * | UndoSet |
Friends | |
| class | vtkSMInteractionUndoStackBuilderObserver |
vtkSMInteractionUndoStackBuilder specializes in interaction. This class can create undo elements for only one render view at a time.
Definition at line 24 of file vtkSMInteractionUndoStackBuilder.h.
Definition at line 28 of file vtkSMInteractionUndoStackBuilder.h.
| void vtkSMInteractionUndoStackBuilder::SetRenderView | ( | vtkSMRenderViewProxy * | ) |
| void vtkSMInteractionUndoStackBuilder::Clear | ( | ) |
| void vtkSMInteractionUndoStackBuilder::StartInteraction | ( | ) |
Usually, this method isn't called directly, since the builder listens to interaction events on the interactor and calls it automatically. May be used when changing the camera programmatically.
| void vtkSMInteractionUndoStackBuilder::EndInteraction | ( | ) |
Event handler.
friend |
Definition at line 87 of file vtkSMInteractionUndoStackBuilder.h.
Definition at line 76 of file vtkSMInteractionUndoStackBuilder.h.
Definition at line 77 of file vtkSMInteractionUndoStackBuilder.h.
Definition at line 78 of file vtkSMInteractionUndoStackBuilder.h.
