vtkSMCoreUtilities Class Reference
collection of utilities. More...
#include <vtkSMCoreUtilities.h>
Inheritance diagram for vtkSMCoreUtilities:
Collaboration diagram for vtkSMCoreUtilities:
static vtkSMCoreUtilities * New ()
static vtkSMCoreUtilities * SafeDownCast (vtkObject *o)
static const char * GetFileNameProperty (vtkSMProxy *)
 Given a proxy (or proxy prototype), returns the name of the property that ParaView application will be use as the default FileName property. More...
static std::vector< std::string > GetFileNameProperties (vtkSMProxy *proxy)
 Returns list of all properties that accept filenames in order that they are defined. More...
static std::string SanitizeName (const char *)
 Sanitize a label/name to be remove spaces, delimiters etc. More...
static std::string SanitizeName (const std::string &name)
static const char * GetStringForCellType (int cellType)
 Given a VTK cell type value from the enum in vtkCellTypes.h, returns a string describing that cell type for use if ParaView's GUI. More...
static void ReplaceReaderFileName (vtkSMProxy *proxy, const std::vector< std::string > &files, const char *propName)
 Replaces input proxy, which should be a reader proxy, by a new proxy in the pipeline. More...
static std::string FindLargestPrefix (const std::vector< std::string > &files)
 Find the largest prefix that matches all file names in files, and then append a '*' to signify that it is a collection of files. More...
static bool AdjustRangeForLog (double range[2])
 Given a range, converts it to be a valid range to switch to log space. More...
static bool AdjustRangeForLog (double &rmin, double &rmax)
static bool AdjustRange (double range[2])
 Adjust the given range to make it suitable for use with color maps. More...
static bool AdjustRange (double &rmin, double &rmax)
static bool AlmostEqual (const double range[2], int ulpsDiff)
 Compares val1 and val2 and returns true is the two numbers are within ulpsDiff ULPs (units in last place) from each other. More...
static bool AlmostEqual (double rmin, double rmax, int ulpsDiff)
static const char * GetInputPropertyName (vtkSMProxy *proxy, int port=0)
 Given a proxy and a port number get the name of the input. More...
 vtkSMCoreUtilities ()
 ~vtkSMCoreUtilities () override
vtkSMCoreUtilities provides miscellaneous utility functions.
Definition at line 21 of file vtkSMCoreUtilities.h.
Definition at line 25 of file vtkSMCoreUtilities.h.
◆ vtkSMCoreUtilities()
vtkSMCoreUtilities::vtkSMCoreUtilities ( )
◆ ~vtkSMCoreUtilities()
vtkSMCoreUtilities::~vtkSMCoreUtilities ( )
static vtkSMCoreUtilities* vtkSMCoreUtilities::New ( )
virtual const char* vtkSMCoreUtilities::GetClassName ( )
static int vtkSMCoreUtilities::IsTypeOf ( const char *  type)
virtual int vtkSMCoreUtilities::IsA ( const char *  type)
static vtkSMCoreUtilities* vtkSMCoreUtilities::SafeDownCast ( vtkObject *  o)
void vtkSMCoreUtilities::PrintSelf ( ostream &  os,
◆ GetFileNameProperty()
static const char* vtkSMCoreUtilities::GetFileNameProperty ( vtkSMProxy *  )
Returns the name of the property or nullptr when no such property is found.
◆ GetFileNameProperties()
static std::vector<std::string> vtkSMCoreUtilities::GetFileNameProperties ( vtkSMProxy *  proxy)
◆ SanitizeName() [1/2]
static std::string vtkSMCoreUtilities::SanitizeName ( const char *  )
◆ SanitizeName() [2/2]
static std::string vtkSMCoreUtilities::SanitizeName ( const std::string &  name)
inlinestatic
Definition at line 45 of file vtkSMCoreUtilities.h.
◆ AdjustRangeForLog() [1/2]
static bool vtkSMCoreUtilities::AdjustRangeForLog ( double  range[2])
If the range is changed, returns true, otherwise returns false.
◆ AdjustRangeForLog() [2/2]
static bool vtkSMCoreUtilities::AdjustRangeForLog ( double &  rmin,
double &  rmax
inlinestatic
Definition at line 56 of file vtkSMCoreUtilities.h.
◆ AdjustRange() [1/2]
static bool vtkSMCoreUtilities::AdjustRange ( double  range[2])
The current logic (which may change in future) does the following:
  1. If the range is invalid i.e range[1] < range[0], simply returns false and keeps the range unchanged.
  2. If the range[0] == range[1] (using logic to handle nearly similar floating points numbers), then the range[1] is adjusted to be such that range[1] > range[0p].
  3. If range[0] < range[1] (beyond the margin of error checked for in (2), then range is left unchanged.
Returns
true if the range was changed, false is the range was left unchanged.
◆ AdjustRange() [2/2]
static bool vtkSMCoreUtilities::AdjustRange ( double &  rmin,
double &  rmax
inlinestatic
Returns
Definition at line 82 of file vtkSMCoreUtilities.h.
◆ AlmostEqual() [1/2]
static bool vtkSMCoreUtilities::AlmostEqual ( const double  range[2],
int  ulpsDiff
◆ AlmostEqual() [2/2]
static bool vtkSMCoreUtilities::AlmostEqual ( double  rmin,
double  rmax,
int  ulpsDiff
inlinestatic
Definition at line 98 of file vtkSMCoreUtilities.h.
◆ GetInputPropertyName()
static const char* vtkSMCoreUtilities::GetInputPropertyName ( vtkSMProxy *  proxy,
int  port = 0
◆ GetStringForCellType()
static const char* vtkSMCoreUtilities::GetStringForCellType ( int  cellType)
For example it pasesd VTK_TRIANGLE it will return "Triangle". If an unknown cell type is passed to this it returns the string "Unknown".
◆ ReplaceReaderFileName()
static void vtkSMCoreUtilities::ReplaceReaderFileName ( vtkSMProxy *  proxy,
const std::vector< std::string > &  files,
const char *  propName
The new input files are stored in files, and propName should be the file name property in the reader (usually "FileName" or "FileNames").
◆ FindLargestPrefix()
static std::string vtkSMCoreUtilities::FindLargestPrefix ( const std::vector< std::string > &  files)
If they all start with something different, this returns '*'.
