vtkReductionFilter Class Reference
A generic filter that can reduce any type of dataset using any reduction algorithm. More...
#include <vtkReductionFilter.h>
Inheritance diagram for vtkReductionFilter:
Collaboration diagram for vtkReductionFilter:
enum  ReductionModeType { REDUCE_ALL_TO_ONE = 0, MOVE_ALL_TO_ONE = 1, REDUCE_ALL_TO_ALL = 2 }
enum  Tags { TRANSMIT_DATA_OBJECT = 23484 }
typedef enum vtkReductionFilter::ReductionModeType ReductionModeType
enum  DesiredOutputPrecision
void SetController (vtkMultiProcessController *)
 Get/Set the MPI controller used for gathering. More...
virtual void SetReductionMode (int)
 Get/Set the Reduction Mode. More...
virtual int GetReductionMode ()
virtual void SetReductionProcessId (int)
 Get/Set the node to reduce to, default is 0. More...
virtual int GetReductionProcessId ()
void SetPreGatherHelper (vtkAlgorithm *)
 Get/Set the pre-reduction helper. More...
void SetPreGatherHelperName (const char *)
virtual vtkAlgorithm * GetPreGatherHelper ()
void SetPostGatherHelper (vtkAlgorithm *)
 Get/Set the reduction helper. More...
void SetPostGatherHelperName (const char *)
virtual vtkAlgorithm * GetPostGatherHelper ()
virtual void SetPassThrough (int)
 Get/Set the PassThrough flag which (when set to a nonnegative number N) tells the filter to produce results that come from node N only. More...
virtual int GetPassThrough ()
virtual void SetGenerateProcessIds (int)
 When set, a new array vtkOriginalProcessIds will be added to the output of the the pre-gather helper (or input, if no pre-gather helper is set). More...
virtual int GetGenerateProcessIds ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkReductionFilter * New ()
static vtkReductionFilter * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkReductionFilter ()
 ~vtkReductionFilter () override
int RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
void Reduce (vtkDataObject *input, vtkDataObject *output)
vtkDataObject * PreProcess (vtkDataObject *input)
void PostProcess (vtkDataObject *output, vtkSmartPointer< vtkDataObject > inputs[], unsigned int num_inputs)
int GatherSelection (vtkSelection *sendData, std::vector< vtkSmartPointer< vtkDataObject >> &receiveData, int destProcessId)
 Gather for vtkSelection sendData is a vtkSelection while receiveData is a vector of NumberOfProcesses vtkSelections. More...
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkAlgorithm * PreGatherHelper
vtkAlgorithm * PostGatherHelper
int PassThrough
int GenerateProcessIds
int ReductionMode
int ReductionProcessId
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
A generic filter that can reduce any type of dataset using any reduction algorithm. Actual reduction is performed by running the PreGatherHelper and PostGatherHelper algorithms. The PreGatherHelper runs on each node in parallel. Next the intermediate results are gathered to the root node. Then the root node then runs the PostGatherHelper algorithm to produce a single result. The PostGatherHelper must be an algorithm that takes multiple input connections and produces a single reduced output.
In addition to doing reduction the PassThrough variable lets you choose to pass through the results of any one node instead of aggregating all of them together.
Definition at line 32 of file vtkReductionFilter.h.
Definition at line 36 of file vtkReductionFilter.h.
◆ ReductionModeType
◆ ReductionModeType
Enumerator
REDUCE_ALL_TO_ONE
MOVE_ALL_TO_ONE
REDUCE_ALL_TO_ALL
Definition at line 39 of file vtkReductionFilter.h.
◆ Tags
Enumerator
Definition at line 117 of file vtkReductionFilter.h.
◆ vtkReductionFilter()
vtkReductionFilter::vtkReductionFilter ( )
◆ ~vtkReductionFilter()
vtkReductionFilter::~vtkReductionFilter ( )
static vtkReductionFilter* vtkReductionFilter::New ( )
virtual const char* vtkReductionFilter::GetClassName ( )
static int vtkReductionFilter::IsTypeOf ( const char *  type)
virtual int vtkReductionFilter::IsA ( const char *  type)
static vtkReductionFilter* vtkReductionFilter::SafeDownCast ( vtkObject *  o)
void vtkReductionFilter::PrintSelf ( ostream &  os,
◆ SetReductionMode()
virtual void vtkReductionFilter::SetReductionMode ( int  )
REDUCE_ALL_TO_ONE is the default behavior. It reduces all data on a single node, while other nodes keeps their data. MOVE_ALL_TO_ONE Reduce all data on a single node while other nodes delete their data. ALL NODES Reduce all data on all nodes.
◆ GetReductionMode()
virtual int vtkReductionFilter::GetReductionMode ( )
◆ SetReductionProcessId()
virtual void vtkReductionFilter::SetReductionProcessId ( int  )
Not used with REDUCE_ALL_TO_ALL Reduction mode
◆ GetReductionProcessId()
virtual int vtkReductionFilter::GetReductionProcessId ( )
◆ SetPreGatherHelper()
void vtkReductionFilter::SetPreGatherHelper ( vtkAlgorithm *  )
Pre-Reduction helper is an algorithm that runs on each node's data before it is sent to the root.
◆ SetPreGatherHelperName()
void vtkReductionFilter::SetPreGatherHelperName ( const char *  )
◆ GetPreGatherHelper()
virtual vtkAlgorithm* vtkReductionFilter::GetPreGatherHelper ( )
◆ SetPostGatherHelper()
void vtkReductionFilter::SetPostGatherHelper ( vtkAlgorithm *  )
Reduction helper is an algorithm with multiple input connections, that produces a single output as the reduced output. This is run on the root node to produce a result from the gathered results of each node.
◆ SetPostGatherHelperName()
void vtkReductionFilter::SetPostGatherHelperName ( const char *  )
◆ GetPostGatherHelper()
virtual vtkAlgorithm* vtkReductionFilter::GetPostGatherHelper ( )
◆ SetController()
void vtkReductionFilter::SetController ( vtkMultiProcessController *  )
◆ SetPassThrough()
virtual void vtkReductionFilter::SetPassThrough ( int  )
The data from that node still runs through the PreReduction and PostGatherHelper algorithms.
◆ GetPassThrough()
virtual int vtkReductionFilter::GetPassThrough ( )
◆ SetGenerateProcessIds()
virtual void vtkReductionFilter::SetGenerateProcessIds ( int  )
The values in the array indicate the process id. Note that the array is added only if the number of processes is > 1.
◆ GetGenerateProcessIds()
virtual int vtkReductionFilter::GetGenerateProcessIds ( )
◆ FillInputPortInformation()
int vtkReductionFilter::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ RequestDataObject()
int vtkReductionFilter::RequestDataObject ( vtkInformation *  request,
◆ RequestData()
int vtkReductionFilter::RequestData ( vtkInformation *  request,
◆ Reduce()
void vtkReductionFilter::Reduce ( vtkDataObject *  input,
vtkDataObject *  output
◆ PreProcess()
vtkDataObject* vtkReductionFilter::PreProcess ( vtkDataObject *  input)
◆ PostProcess()
void vtkReductionFilter::PostProcess ( vtkDataObject *  output,
◆ GatherSelection()
int vtkReductionFilter::GatherSelection ( vtkSelection *  sendData,
std::vector< vtkSmartPointer< vtkDataObject >> &  receiveData,
int  destProcessId
Selections are gathered on destProcessId
◆ PreGatherHelper
vtkAlgorithm* vtkReductionFilter::PreGatherHelper
Definition at line 148 of file vtkReductionFilter.h.
◆ PostGatherHelper
vtkAlgorithm* vtkReductionFilter::PostGatherHelper
Definition at line 149 of file vtkReductionFilter.h.
◆ Controller
vtkMultiProcessController* vtkReductionFilter::Controller
Definition at line 150 of file vtkReductionFilter.h.
◆ PassThrough
int vtkReductionFilter::PassThrough
Definition at line 151 of file vtkReductionFilter.h.
◆ GenerateProcessIds
int vtkReductionFilter::GenerateProcessIds
Definition at line 152 of file vtkReductionFilter.h.
◆ ReductionMode
int vtkReductionFilter::ReductionMode
Definition at line 153 of file vtkReductionFilter.h.
◆ ReductionProcessId
int vtkReductionFilter::ReductionProcessId
Definition at line 154 of file vtkReductionFilter.h.
