vtkPythonCalculator Class Reference
Evaluates a Python expression vtkPythonCalculator uses Python to calculate an expression. This filter depends heavily on the numpy and paraview.vtk modules. To use the parallel functions, mpi4py is also necessary. The expression is evaluated and the resulting scalar value or numpy array is added to the output as an array. See numpy and paraview.vtk documentation for the list of available functions. More...
#include <vtkPythonCalculator.h>
Inheritance diagram for vtkPythonCalculator:
Collaboration diagram for vtkPythonCalculator:
typedef vtkProgrammableFilter Superclass
- Public Types inherited from vtkProgrammableFilter
typedef void(* ProgrammableMethodCallbackType) (void *arg)
enum  DesiredOutputPrecision
virtual void SetArrayAssociation (int)
 Which field data to get the arrays from. More...
virtual int GetArrayAssociation ()
virtual void SetExpression (std::string)
 Set the text of the python expression to execute. More...
virtual std::string GetExpression ()
virtual void SetMultilineExpression (std::string)
 Set the text of the python multiline expression. More...
virtual std::string GetMultilineExpression ()
virtual void SetArrayName (const char *)
 Set the name of the output array. More...
virtual char * GetArrayName ()
virtual int GetResultArrayType ()
 Type of the result array. More...
virtual void SetResultArrayType (int)
virtual bool GetUseMultilineExpression ()
 If true, executes MultilineExpression, which is a multiline string representing a Python script, ending by a return statement. More...
virtual void SetUseMultilineExpression (bool)
- Public Member Functions inherited from vtkProgrammableFilter
vtkProgrammableFilter * NewInstance () const
void SetExecuteMethod (void(*f)(void *), void *arg)
void SetExecuteMethodArgDelete (void(*f)(void *))
vtkPolyData * GetPolyDataInput ()
vtkStructuredPoints * GetStructuredPointsInput ()
vtkStructuredGrid * GetStructuredGridInput ()
vtkUnstructuredGrid * GetUnstructuredGridInput ()
vtkRectilinearGrid * GetRectilinearGridInput ()
vtkGraph * GetGraphInput ()
vtkTable * GetTableInput ()
virtual void SetCopyArrays (bool)
virtual bool GetCopyArrays ()
virtual void CopyArraysOn ()
virtual void CopyArraysOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPythonCalculator * SafeDownCast (vtkObject *o)
static vtkPythonCalculator * New ()
static void ExecuteScript (void *)
 For internal use only. More...
- Static Public Member Functions inherited from vtkProgrammableFilter
static vtkProgrammableFilter * New ()
static vtkProgrammableFilter * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPythonCalculator ()
 ~vtkPythonCalculator () override
void Exec (const std::string &)
int RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
- Protected Member Functions inherited from vtkProgrammableFilter
 vtkProgrammableFilter ()
 ~vtkProgrammableFilter ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
virtual int RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
std::string Expression
std::string MultilineExpression
bool UseMultilineExpression = false
char * ArrayName = nullptr
int ArrayAssociation = vtkDataObject::FIELD_ASSOCIATION_POINTS
int ResultArrayType = VTK_DOUBLE
- Protected Attributes inherited from vtkProgrammableFilter
ProgrammableMethodCallbackType ExecuteMethod
ProgrammableMethodCallbackType ExecuteMethodArgDelete
void * ExecuteMethodArg
bool CopyArrays
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This filter tries to make it easy for the user to write expressions by defining certain variables. The filter tries to assign each array to a variable of the same name. If the name of the array is not a valid Python variable, it has to be accessed through a dictionary called arrays (i.e. arrays['array_name']). The points can be accessed using the points variable.
Definition at line 29 of file vtkPythonCalculator.h.
Definition at line 32 of file vtkPythonCalculator.h.
◆ vtkPythonCalculator()
vtkPythonCalculator::vtkPythonCalculator ( )
◆ ~vtkPythonCalculator()
vtkPythonCalculator::~vtkPythonCalculator ( )
virtual const char* vtkPythonCalculator::GetClassName ( )
static int vtkPythonCalculator::IsTypeOf ( const char *  type)
virtual int vtkPythonCalculator::IsA ( const char *  type)
Reimplemented from vtkProgrammableFilter.
static vtkPythonCalculator* vtkPythonCalculator::SafeDownCast ( vtkObject *  o)
void vtkPythonCalculator::PrintSelf ( ostream &  os,
static vtkPythonCalculator* vtkPythonCalculator::New ( )
◆ SetArrayAssociation()
virtual void vtkPythonCalculator::SetArrayAssociation ( int  )
See vtkDataObject::FieldAssociations for choices. The default is FIELD_ASSOCIATION_POINTS.
◆ GetArrayAssociation()
virtual int vtkPythonCalculator::GetArrayAssociation ( )
◆ SetExpression()
virtual void vtkPythonCalculator::SetExpression ( std::string  )
This expression must return a scalar value (which is converted to an array) or a numpy array.
◆ GetExpression()
virtual std::string vtkPythonCalculator::GetExpression ( )
◆ SetMultilineExpression()
virtual void vtkPythonCalculator::SetMultilineExpression ( std::string  )
The expression must use an explicit return statement for the result scalar value or numpy array.
◆ GetMultilineExpression()
virtual std::string vtkPythonCalculator::GetMultilineExpression ( )
◆ SetArrayName()
virtual void vtkPythonCalculator::SetArrayName ( const char *  )
◆ GetArrayName()
virtual char* vtkPythonCalculator::GetArrayName ( )
◆ GetResultArrayType()
virtual int vtkPythonCalculator::GetResultArrayType ( )
Initial value is VTK_DOUBLE.
◆ SetResultArrayType()
virtual void vtkPythonCalculator::SetResultArrayType ( int  )
◆ GetUseMultilineExpression()
virtual bool vtkPythonCalculator::GetUseMultilineExpression ( )
Otherwise, evaluates Expression, a python expression. Initial value is false.
◆ SetUseMultilineExpression()
virtual void vtkPythonCalculator::SetUseMultilineExpression ( bool  )
◆ ExecuteScript()
static void vtkPythonCalculator::ExecuteScript ( void *  )
◆ Exec()
void vtkPythonCalculator::Exec ( const std::string &  )
◆ FillOutputPortInformation()
int vtkPythonCalculator::FillOutputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ FillInputPortInformation()
int vtkPythonCalculator::FillInputPortInformation ( int  port,
◆ RequestData()
int vtkPythonCalculator::RequestData ( vtkInformation *  request,
◆ RequestDataObject()
int vtkPythonCalculator::RequestDataObject ( vtkInformation *  request,
◆ Expression
std::string vtkPythonCalculator::Expression
Definition at line 119 of file vtkPythonCalculator.h.
◆ MultilineExpression
std::string vtkPythonCalculator::MultilineExpression
Definition at line 120 of file vtkPythonCalculator.h.
◆ UseMultilineExpression
bool vtkPythonCalculator::UseMultilineExpression = false
Definition at line 121 of file vtkPythonCalculator.h.
◆ ArrayName
char* vtkPythonCalculator::ArrayName = nullptr
Definition at line 123 of file vtkPythonCalculator.h.
◆ ArrayAssociation
int vtkPythonCalculator::ArrayAssociation = vtkDataObject::FIELD_ASSOCIATION_POINTS
Definition at line 124 of file vtkPythonCalculator.h.
◆ ResultArrayType
int vtkPythonCalculator::ResultArrayType = VTK_DOUBLE
Definition at line 125 of file vtkPythonCalculator.h.
