vtkPythonAnimationCue Class Reference
#include <vtkPythonAnimationCue.h>
Inheritance diagram for vtkPythonAnimationCue:
Collaboration diagram for vtkPythonAnimationCue:
typedef vtkAnimationCue Superclass
- Public Types inherited from vtkAnimationCue
enum  TimeCodes
virtual void SetEnabled (bool)
 Enable/Disable this cue. More...
virtual bool GetEnabled ()
virtual void EnabledOn ()
virtual void EnabledOff ()
void SetScript (const std::string &)
 Get/Set the python script to execute. More...
std::string GetScript () const
- Public Member Functions inherited from vtkAnimationCue
vtkAnimationCue * NewInstance () const
virtual void Tick (double currenttime, double deltatime, double clocktime)
virtual void Initialize ()
virtual void Finalize ()
virtual void SetTimeMode (int mode)
virtual int GetTimeMode ()
void SetTimeModeToRelative ()
void SetTimeModeToNormalized ()
virtual void SetStartTime (double)
virtual double GetStartTime ()
virtual void SetEndTime (double)
virtual double GetEndTime ()
virtual double GetAnimationTime ()
virtual double GetDeltaTime ()
virtual double GetClockTime ()
static vtkPythonAnimationCue * New ()
static vtkPythonAnimationCue * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkAnimationCue
static vtkAnimationCue * SafeDownCast (vtkObjectBase *o)
static vtkAnimationCue * New ()
 vtkPythonAnimationCue ()
 ~vtkPythonAnimationCue () override
void DeleteInterpretor ()
 Cleans the interpretor. More...
virtual void HandleStartCueEvent ()
 Callbacks that forward the call to corresponding Python function. More...
virtual void HandleTickEvent ()
virtual void HandleEndCueEvent ()
- Protected Member Functions inherited from vtkAnimationCue
 vtkAnimationCue ()
 ~vtkAnimationCue ()
virtual void StartCueInternal ()
virtual void TickInternal (double currenttime, double deltatime, double clocktime)
virtual void EndCueInternal ()
bool Enabled
std::string Script
- Protected Attributes inherited from vtkAnimationCue
 UNINITIALIZED
 INACTIVE
 ACTIVE
double StartTime
double EndTime
int TimeMode
double AnimationTime
double DeltaTime
double ClockTime
int CueState
- Public Attributes inherited from vtkAnimationCue
 TIMEMODE_NORMALIZED
 TIMEMODE_RELATIVE
vtkPythonAnimationCue is an animation cue that can execute arbitrary Python scripts.
Definition at line 19 of file vtkPythonAnimationCue.h.
Definition at line 23 of file vtkPythonAnimationCue.h.
◆ vtkPythonAnimationCue()
vtkPythonAnimationCue::vtkPythonAnimationCue ( )
◆ ~vtkPythonAnimationCue()
vtkPythonAnimationCue::~vtkPythonAnimationCue ( )
static vtkPythonAnimationCue* vtkPythonAnimationCue::New ( )
virtual const char* vtkPythonAnimationCue::GetClassName ( )
static int vtkPythonAnimationCue::IsTypeOf ( const char *  type)
virtual int vtkPythonAnimationCue::IsA ( const char *  type)
Reimplemented from vtkAnimationCue.
static vtkPythonAnimationCue* vtkPythonAnimationCue::SafeDownCast ( vtkObject *  o)
void vtkPythonAnimationCue::PrintSelf ( ostream &  os,
◆ SetEnabled()
virtual void vtkPythonAnimationCue::SetEnabled ( bool  )
◆ GetEnabled()
virtual bool vtkPythonAnimationCue::GetEnabled ( )
◆ EnabledOn()
virtual void vtkPythonAnimationCue::EnabledOn ( )
◆ EnabledOff()
virtual void vtkPythonAnimationCue::EnabledOff ( )
◆ SetScript()
void vtkPythonAnimationCue::SetScript ( const std::string &  )
The script must have the following functions:
  • start_cue(cue): (optional) if present, called when the cue starts.
  • tick(cue) : (required) called on every tick.
  • end_cue(cue): (optional) if present, called when the cue ends.
◆ GetScript()
std::string vtkPythonAnimationCue::GetScript ( ) const
◆ HandleStartCueEvent()
virtual void vtkPythonAnimationCue::HandleStartCueEvent ( )
protectedvirtual
◆ HandleTickEvent()
virtual void vtkPythonAnimationCue::HandleTickEvent ( )
protectedvirtual
◆ HandleEndCueEvent()
virtual void vtkPythonAnimationCue::HandleEndCueEvent ( )
protectedvirtual
◆ DeleteInterpretor()
void vtkPythonAnimationCue::DeleteInterpretor ( )
◆ Enabled
bool vtkPythonAnimationCue::Enabled
Definition at line 65 of file vtkPythonAnimationCue.h.
◆ Script
std::string vtkPythonAnimationCue::Script
Definition at line 66 of file vtkPythonAnimationCue.h.
