vtkPVWebApplication Class Reference
defines ParaViewWeb application interface. More...
#include <vtkPVWebApplication.h>
Inheritance diagram for vtkPVWebApplication:
Collaboration diagram for vtkPVWebApplication:
bool GetHasImagesBeingProcessed (vtkSMViewProxy *)
 StillRenderToString() need not necessary returns the most recently rendered image. More...
bool HandleInteractionEvent (vtkSMViewProxy *view, vtkWebInteractionEvent *event)
 Communicate mouse interaction to a view. More...
void InvalidateCache (vtkSMViewProxy *view)
 Invalidate view cache. More...
const char * GetWebGLSceneMetaData (vtkSMViewProxy *view)
 Return the Meta data description of the input scene in JSON format. More...
const char * GetWebGLBinaryData (vtkSMViewProxy *view, const char *id, int partIndex)
 Return the binary data given the part index and the webGL object piece id in the scene. More...
vtkUnsignedCharArrayStillRender (vtkSMViewProxy *view, int quality=100)
 Render a view and obtain the rendered image. More...
vtkUnsignedCharArrayInteractiveRender (vtkSMViewProxy *view, int quality=50)
const char * StillRenderToString (vtkSMViewProxy *view, unsigned long time=0, int quality=100)
vtkUnsignedCharArrayStillRenderToBuffer (vtkSMViewProxy *view, unsigned long time=0, int quality=100)
virtual vtkMTimeType GetLastStillRenderToMTime ()
 Return the MTime of the last array exported by StillRenderToString, StillRenderToBuffer. More...
virtual intGetLastStillRenderImageSize ()
 Return the size of the last image exported. More...
virtual void GetLastStillRenderImageSize (int &, int &)
virtual void GetLastStillRenderImageSize (int[2])
static vtkPVWebApplicationNew ()
static vtkPVWebApplicationSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVWebApplication ()
 ~vtkPVWebApplication () override
int ImageEncoding
int ImageCompression
vtkMTimeType LastStillRenderToMTime
int LastStillRenderImageSize [3]
enum  { ENCODING_NONE = 0, ENCODING_BASE64 = 1 }
 Set the encoding to be used for rendered images. More...
virtual void SetImageEncoding (int)
virtual int GetImageEncoding ()
enum  { COMPRESSION_NONE = 0, COMPRESSION_PNG = 1, COMPRESSION_JPEG = 2 }
 Set the compression to be used for rendered images. More...
virtual void SetImageCompression (int)
virtual int GetImageCompression ()
vtkPVWebApplication defines the core interface for a ParaViewWeb application. This exposes methods that make it easier to manage views and rendered images from views.
Definition at line 22 of file vtkPVWebApplication.h.
Definition at line 26 of file vtkPVWebApplication.h.
◆ anonymous enum
anonymous enum
Enumerator
ENCODING_NONE
ENCODING_BASE64
Definition at line 33 of file vtkPVWebApplication.h.
◆ anonymous enum
anonymous enum
Enumerator
COMPRESSION_NONE
COMPRESSION_PNG
COMPRESSION_JPEG
Definition at line 46 of file vtkPVWebApplication.h.
◆ vtkPVWebApplication()
vtkPVWebApplication::vtkPVWebApplication ( )
◆ ~vtkPVWebApplication()
vtkPVWebApplication::~vtkPVWebApplication ( )
static vtkPVWebApplication* vtkPVWebApplication::New ( )
virtual const char* vtkPVWebApplication::GetClassName ( )
static int vtkPVWebApplication::IsTypeOf ( const char *  type)
virtual int vtkPVWebApplication::IsA ( const char *  type)
static vtkPVWebApplication* vtkPVWebApplication::SafeDownCast ( vtkObject o)
void vtkPVWebApplication::PrintSelf ( ostream &  os,
◆ SetImageEncoding()
virtual void vtkPVWebApplication::SetImageEncoding ( int  )
◆ GetImageEncoding()
virtual int vtkPVWebApplication::GetImageEncoding ( )
◆ SetImageCompression()
virtual void vtkPVWebApplication::SetImageCompression ( int  )
◆ GetImageCompression()
virtual int vtkPVWebApplication::GetImageCompression ( )
◆ StillRender()
vtkUnsignedCharArray* vtkPVWebApplication::StillRender ( vtkSMViewProxy view,
int  quality = 100
◆ InteractiveRender()
vtkUnsignedCharArray* vtkPVWebApplication::InteractiveRender ( vtkSMViewProxy view,
int  quality = 50
◆ StillRenderToString()
const char* vtkPVWebApplication::StillRenderToString ( vtkSMViewProxy view,
unsigned long  time = 0,
int  quality = 100
◆ StillRenderToBuffer()
vtkUnsignedCharArray* vtkPVWebApplication::StillRenderToBuffer ( vtkSMViewProxy view,
int  quality = 100
◆ GetHasImagesBeingProcessed()
bool vtkPVWebApplication::GetHasImagesBeingProcessed ( vtkSMViewProxy )
Use this method to get whether there are any pending images being processed concurrently.
◆ HandleInteractionEvent()
bool vtkPVWebApplication::HandleInteractionEvent ( vtkSMViewProxy view,
vtkWebInteractionEvent event
Returns true if the interaction changed the view state, otherwise returns false.
◆ InvalidateCache()
void vtkPVWebApplication::InvalidateCache ( vtkSMViewProxy view)
◆ GetLastStillRenderToMTime()
virtual vtkMTimeType vtkPVWebApplication::GetLastStillRenderToMTime ( )
◆ GetWebGLSceneMetaData()
const char* vtkPVWebApplication::GetWebGLSceneMetaData ( vtkSMViewProxy view)
This is using the vtkWebGLExporter to parse the scene. NOTE: This should be called before getting the webGL binary data.
◆ GetWebGLBinaryData()
const char* vtkPVWebApplication::GetWebGLBinaryData ( vtkSMViewProxy view,
const char *  id,
int  partIndex
◆ GetLastStillRenderImageSize() [1/3]
virtual int* vtkPVWebApplication::GetLastStillRenderImageSize ( )
◆ GetLastStillRenderImageSize() [2/3]
virtual void vtkPVWebApplication::GetLastStillRenderImageSize ( int ,
int
◆ GetLastStillRenderImageSize() [3/3]
virtual void vtkPVWebApplication::GetLastStillRenderImageSize ( int  [2])
◆ ImageEncoding
int vtkPVWebApplication::ImageEncoding
Definition at line 116 of file vtkPVWebApplication.h.
◆ ImageCompression
int vtkPVWebApplication::ImageCompression
Definition at line 117 of file vtkPVWebApplication.h.
◆ LastStillRenderToMTime
vtkMTimeType vtkPVWebApplication::LastStillRenderToMTime
Definition at line 118 of file vtkPVWebApplication.h.
◆ LastStillRenderImageSize
int vtkPVWebApplication::LastStillRenderImageSize[3]
Definition at line 119 of file vtkPVWebApplication.h.
