Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
vtkPVSelectionSource Class Reference
selection source used to produce different types of vtkSelections. More...
#include <vtkPVSelectionSource.h>
Inheritance diagram for vtkPVSelectionSource:
Collaboration diagram for vtkPVSelectionSource:
typedef vtkSelectionAlgorithm Superclass
- Public Types inherited from vtkSelectionAlgorithm
enum  DesiredOutputPrecision
void AddFrustum (double vertices[32])
 Set a frustum to choose within. More...
virtual void SetArrayName (const char *)
 For threshold and value selection, this controls the name of the scalar array that will be thresholded within. More...
void AddGlobalID (vtkIdType id)
 Add global IDs. More...
void RemoveAllGlobalIDs ()
void AddPedigreeID (const char *domain, vtkIdType id)
 Add integer pedigree IDs in a particular domain. More...
void RemoveAllPedigreeIDs ()
void AddPedigreeStringID (const char *domain, const char *id)
 Add string pedigree IDs in a particular domain. More...
void RemoveAllPedigreeStringIDs ()
void AddID (vtkIdType piece, vtkIdType id)
 Add a (piece, id) to the selection set. More...
void RemoveAllIDs ()
void AddValue (vtkIdType piece, vtkIdType value)
 Add a (piece, value) to the selection set. More...
void RemoveAllValues ()
void AddCompositeID (unsigned int composite_index, vtkIdType piece, vtkIdType id)
 Add IDs that will be added to the selection produced by the selection source. More...
void RemoveAllCompositeIDs ()
void AddHierarhicalID (unsigned int level, unsigned int dataset, vtkIdType id)
 The list of IDs that will be added to the selection produced by the selection source. More...
void RemoveAllHierarchicalIDs ()
void AddThreshold (double min, double max)
 Add a value range to threshold within. More...
void RemoveAllThresholds ()
void AddBlock (vtkIdType blockno)
 Add the flat-index/composite index for a block. More...
void RemoveAllBlocks ()
void AddLocation (double x, double y, double z)
 Add a point in world space to probe at. More...
void RemoveAllLocations ()
void AddBlockSelector (const char *selector)
 Add/Remove block-selectors to make selections with vtkSelectionNode::BLOCK_SELECTORS as the content-type. More...
void RemoveAllBlockSelectors ()
virtual void SetProcessID (int)
 Get/Set which process to limit the selection to. More...
virtual int GetProcessID ()
virtual void SetFieldType (int)
 Set the field type for the generated selection. More...
virtual int GetFieldType ()
virtual void SetContainingCells (int)
 When extracting by points, extract the cells that contain the passing points. More...
virtual int GetContainingCells ()
virtual void SetInverse (int)
virtual int GetInverse ()
virtual void SetQueryString (const char *)
 Set/get the query expression string. More...
virtual char * GetQueryString ()
virtual void SetNumberOfLayers (int)
 Specify number of layers to extract connected to the selected elements. More...
virtual int GetNumberOfLayers ()
virtual void SetRemoveSeed (bool)
 Set/Get the flag the control if, when using the number of layers to extract connected elements, the initial selection seed should be removed. More...
virtual bool GetRemoveSeed ()
virtual void SetRemoveIntermediateLayers (bool)
 Set/Get the flag the control if, when using the number of layers to extract connected elements, the intermediate layers should be removed. More...
virtual bool GetRemoveIntermediateLayers ()
- Public Member Functions inherited from vtkSelectionAlgorithm
vtkSelectionAlgorithm * NewInstance () const
vtkSelection * GetOutput ()
vtkSelection * GetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVSelectionSource * New ()
static vtkPVSelectionSource * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSelectionAlgorithm
static vtkSelectionAlgorithm * New ()
static vtkSelectionAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
Protected Types
enum  Modes {
  FRUSTUM, GLOBALIDS, ID, COMPOSITEID,
  HIERARCHICALID, THRESHOLDS, LOCATIONS, BLOCKS,
  BLOCK_SELECTORS, PEDIGREEIDS, QUERY, VALUES
 vtkPVSelectionSource ()
 ~vtkPVSelectionSource () override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
- Protected Member Functions inherited from vtkSelectionAlgorithm
 vtkSelectionAlgorithm ()
 ~vtkSelectionAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
Modes Mode
int ProcessID
int FieldType
int ContainingCells
int Inverse
double Frustum [32]
char * ArrayName
char * QueryString
int NumberOfLayers
bool RemoveSeed = false
bool RemoveIntermediateLayers = false
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkPVSelectionSource is used to create different types of selections. It provides different APIs for different types of selections to create. The output selection type depends on the API used most recently.
Definition at line 19 of file vtkPVSelectionSource.h.
Definition at line 23 of file vtkPVSelectionSource.h.
◆ Modes
Enumerator
FRUSTUM
GLOBALIDS
ID
COMPOSITEID
HIERARCHICALID
THRESHOLDS
LOCATIONS
BLOCKS
BLOCK_SELECTORS
PEDIGREEIDS
QUERY
VALUES
Definition at line 212 of file vtkPVSelectionSource.h.
◆ vtkPVSelectionSource()
vtkPVSelectionSource::vtkPVSelectionSource ( )
◆ ~vtkPVSelectionSource()
vtkPVSelectionSource::~vtkPVSelectionSource ( )
static vtkPVSelectionSource* vtkPVSelectionSource::New ( )
virtual const char* vtkPVSelectionSource::GetClassName ( )
static int vtkPVSelectionSource::IsTypeOf ( const char *  type)
virtual int vtkPVSelectionSource::IsA ( const char *  type)
Reimplemented from vtkSelectionAlgorithm.
static vtkPVSelectionSource* vtkPVSelectionSource::SafeDownCast ( vtkObject *  o)
void vtkPVSelectionSource::PrintSelf ( ostream &  os,
◆ AddFrustum()
void vtkPVSelectionSource::AddFrustum ( double  vertices[32])
◆ AddGlobalID()
void vtkPVSelectionSource::AddGlobalID ( vtkIdType  id)
Add global IDs.
◆ RemoveAllGlobalIDs()
void vtkPVSelectionSource::RemoveAllGlobalIDs ( )
Add global IDs.
◆ AddPedigreeID()
void vtkPVSelectionSource::AddPedigreeID ( const char *  domain,
vtkIdType  id
◆ RemoveAllPedigreeIDs()
void vtkPVSelectionSource::RemoveAllPedigreeIDs ( )
◆ AddPedigreeStringID()
void vtkPVSelectionSource::AddPedigreeStringID ( const char *  domain,
const char *  id
◆ RemoveAllPedigreeStringIDs()
void vtkPVSelectionSource::RemoveAllPedigreeStringIDs ( )
◆ AddID()
void vtkPVSelectionSource::AddID ( vtkIdType  piece,
vtkIdType  id
The source will generate only the ids for which piece == UPDATE_PIECE_NUMBER. If piece == -1, the id applies to all pieces.
◆ RemoveAllIDs()
void vtkPVSelectionSource::RemoveAllIDs ( )
◆ AddValue()
void vtkPVSelectionSource::AddValue ( vtkIdType  piece,
vtkIdType  value
The source will generate only the values for which piece == UPDATE_PIECE_NUMBER. If piece == -1, the id applies to all pieces.
◆ RemoveAllValues()
void vtkPVSelectionSource::RemoveAllValues ( )
◆ AddCompositeID()
void vtkPVSelectionSource::AddCompositeID ( unsigned int  composite_index,
vtkIdType  piece,
vtkIdType  id
◆ RemoveAllCompositeIDs()
void vtkPVSelectionSource::RemoveAllCompositeIDs ( )
◆ AddHierarhicalID()
void vtkPVSelectionSource::AddHierarhicalID ( unsigned int  level,
vtkIdType  id
◆ RemoveAllHierarchicalIDs()
void vtkPVSelectionSource::RemoveAllHierarchicalIDs ( )
◆ AddThreshold()
void vtkPVSelectionSource::AddThreshold ( double  min,
double  max
◆ RemoveAllThresholds()
void vtkPVSelectionSource::RemoveAllThresholds ( )
◆ AddBlock()
void vtkPVSelectionSource::AddBlock ( vtkIdType  blockno)
◆ RemoveAllBlocks()
void vtkPVSelectionSource::RemoveAllBlocks ( )
◆ SetArrayName()
virtual void vtkPVSelectionSource::SetArrayName ( const char *  )
◆ AddLocation()
void vtkPVSelectionSource::AddLocation ( double  x,
double  y,
double  z
◆ RemoveAllLocations()
void vtkPVSelectionSource::RemoveAllLocations ( )
◆ AddBlockSelector()
void vtkPVSelectionSource::AddBlockSelector ( const char *  selector)
◆ RemoveAllBlockSelectors()
void vtkPVSelectionSource::RemoveAllBlockSelectors ( )
◆ SetProcessID()
virtual void vtkPVSelectionSource::SetProcessID ( int  )
-1 is treated as all processes.
◆ GetProcessID()
virtual int vtkPVSelectionSource::GetProcessID ( )
◆ SetFieldType()
virtual void vtkPVSelectionSource::SetFieldType ( int  )
Possible values are as defined by vtkSelectionNode::SelectionField.
◆ GetFieldType()
virtual int vtkPVSelectionSource::GetFieldType ( )
◆ SetContainingCells()
virtual void vtkPVSelectionSource::SetContainingCells ( int  )
◆ GetContainingCells()
virtual int vtkPVSelectionSource::GetContainingCells ( )
◆ SetInverse()
virtual void vtkPVSelectionSource::SetInverse ( int  )
◆ GetInverse()
virtual int vtkPVSelectionSource::GetInverse ( )
◆ SetQueryString()
virtual void vtkPVSelectionSource::SetQueryString ( const char *  )
◆ GetQueryString()
virtual char* vtkPVSelectionSource::GetQueryString ( )
◆ SetNumberOfLayers()
virtual void vtkPVSelectionSource::SetNumberOfLayers ( int  )
◆ GetNumberOfLayers()
virtual int vtkPVSelectionSource::GetNumberOfLayers ( )
◆ SetRemoveSeed()
virtual void vtkPVSelectionSource::SetRemoveSeed ( bool  )
Default is falsse
◆ GetRemoveSeed()
virtual bool vtkPVSelectionSource::GetRemoveSeed ( )
Default is falsse
◆ SetRemoveIntermediateLayers()
virtual void vtkPVSelectionSource::SetRemoveIntermediateLayers ( bool  )
Default is falsse
◆ GetRemoveIntermediateLayers()
virtual bool vtkPVSelectionSource::GetRemoveIntermediateLayers ( )
Default is falsse
◆ RequestInformation()
int vtkPVSelectionSource::RequestInformation ( vtkInformation *  request,
overrideprotectedvirtual
◆ RequestData()
int vtkPVSelectionSource::RequestData ( vtkInformation *  request,
◆ Mode
Modes vtkPVSelectionSource::Mode
Definition at line 228 of file vtkPVSelectionSource.h.
◆ ProcessID
int vtkPVSelectionSource::ProcessID
Definition at line 229 of file vtkPVSelectionSource.h.
◆ FieldType
int vtkPVSelectionSource::FieldType
Definition at line 230 of file vtkPVSelectionSource.h.
◆ ContainingCells
int vtkPVSelectionSource::ContainingCells
Definition at line 231 of file vtkPVSelectionSource.h.
◆ Inverse
int vtkPVSelectionSource::Inverse
Definition at line 232 of file vtkPVSelectionSource.h.
◆ Frustum
double vtkPVSelectionSource::Frustum[32]
Definition at line 233 of file vtkPVSelectionSource.h.
◆ ArrayName
char* vtkPVSelectionSource::ArrayName
Definition at line 234 of file vtkPVSelectionSource.h.
◆ QueryString
char* vtkPVSelectionSource::QueryString
Definition at line 235 of file vtkPVSelectionSource.h.
◆ NumberOfLayers
int vtkPVSelectionSource::NumberOfLayers
Definition at line 236 of file vtkPVSelectionSource.h.
◆ RemoveSeed
bool vtkPVSelectionSource::RemoveSeed = false
Definition at line 237 of file vtkPVSelectionSource.h.
◆ RemoveIntermediateLayers
bool vtkPVSelectionSource::RemoveIntermediateLayers = false
Definition at line 238 of file vtkPVSelectionSource.h.
