vtkPVRotateAroundOriginTransform Class Reference
baseclass for all ParaView vtkTransform class. More...
#include <vtkPVRotateAroundOriginTransform.h>
Inheritance diagram for vtkPVRotateAroundOriginTransform:
Collaboration diagram for vtkPVRotateAroundOriginTransform:
typedef vtkPVTransform Superclass
- Public Types inherited from vtkPVTransform
typedef vtkTransform Superclass
- Public Types inherited from vtkTransform
typedef vtkLinearTransform Superclass
- Public Types inherited from vtkLinearTransform
typedef vtkHomogeneousTransform Superclass
- Public Types inherited from vtkHomogeneousTransform
typedef vtkAbstractTransform Superclass
- Public Types inherited from vtkAbstractTransform
void SetOriginOfRotation (double xyz[3])
 Get/Set Origin of rotation. More...
void SetOriginOfRotation (double x, double y, double z)
virtual double * GetOriginOfRotation ()
virtual void GetOriginOfRotation (double &, double &, double &)
virtual void GetOriginOfRotation (double[3])
- Public Member Functions inherited from vtkPVTransform
void SetAbsolutePosition (double xyz[3])
 Get/Set Position of the transform. More...
void SetAbsolutePosition (double x, double y, double z)
virtual double * GetAbsolutePosition ()
virtual void GetAbsolutePosition (double &, double &, double &)
virtual void GetAbsolutePosition (double[3])
void SetAbsoluteRotation (double xyz[3])
 Get/Set Rotation for the transform. More...
void SetAbsoluteRotation (double x, double y, double z)
virtual double * GetAbsoluteRotation ()
virtual void GetAbsoluteRotation (double &, double &, double &)
virtual void GetAbsoluteRotation (double[3])
void SetAbsoluteScale (double xyz[3])
 Get/Set Scale for the transform. More...
void SetAbsoluteScale (double x, double y, double z)
virtual double * GetAbsoluteScale ()
virtual void GetAbsoluteScale (double &, double &, double &)
virtual void GetAbsoluteScale (double[3])
- Public Member Functions inherited from vtkTransform
vtkTransform * NewInstance () const
void Identity ()
void Inverse ()
void Concatenate (vtkLinearTransform *transform)
void GetInverse (vtkMatrix4x4 *inverse)
void GetTranspose (vtkMatrix4x4 *transpose)
int CircuitCheck (vtkAbstractTransform *transform)
vtkAbstractTransform * GetInverse ()
vtkAbstractTransform * MakeTransform ()
vtkMTimeType GetMTime ()
void Translate (double x, double y, double z)
void Translate (const double x[3])
void Translate (const float x[3])
void RotateWXYZ (double angle, double x, double y, double z)
void RotateWXYZ (double angle, const double axis[3])
void RotateWXYZ (double angle, const float axis[3])
void RotateX (double angle)
void RotateY (double angle)
void RotateZ (double angle)
void Scale (double x, double y, double z)
void Scale (const double s[3])
void Scale (const float s[3])
void SetMatrix (vtkMatrix4x4 *matrix)
void SetMatrix (const double elements[16])
void Concatenate (vtkMatrix4x4 *matrix)
void Concatenate (const double elements[16])
void PreMultiply ()
void PostMultiply ()
int GetNumberOfConcatenatedTransforms ()
vtkLinearTransform * GetConcatenatedTransform (int i)
void GetOrientation (double orient[3])
void GetOrientation (float orient[3])
double * GetOrientation ()
void GetOrientationWXYZ (double wxyz[4])
void GetOrientationWXYZ (float wxyz[4])
double * GetOrientationWXYZ ()
void GetPosition (double pos[3])
void GetPosition (float pos[3])
double * GetPosition ()
void GetScale (double scale[3])
void GetScale (float scale[3])
double * GetScale ()
void SetInput (vtkLinearTransform *input)
vtkLinearTransform * GetInput ()
int GetInverseFlag ()
void Push ()
void Pop ()
void MultiplyPoint (const float in[4], float out[4])
void MultiplyPoint (const double in[4], double out[4])
void PreMultiply ()
void Push ()
void Pop ()
- Public Member Functions inherited from vtkLinearTransform
vtkLinearTransform * NewInstance () const
void TransformPoints (vtkPoints *inPts, vtkPoints *outPts)
virtual void TransformNormals (vtkDataArray *inNms, vtkDataArray *outNms)
virtual void TransformVectors (vtkDataArray *inVrs, vtkDataArray *outVrs)
void TransformNormal (const float in[3], float out[3])
void TransformNormal (const double in[3], double out[3])
double * TransformNormal (double x, double y, double z)
double * TransformNormal (const double normal[3])
float * TransformFloatNormal (float x, float y, float z)
float * TransformFloatNormal (const float normal[3])
double * TransformDoubleNormal (double x, double y, double z)
double * TransformDoubleNormal (const double normal[3])
double * TransformVector (double x, double y, double z)
double * TransformVector (const double normal[3])
void TransformVector (const float in[3], float out[3])
void TransformVector (const double in[3], double out[3])
float * TransformFloatVector (float x, float y, float z)
float * TransformFloatVector (const float vec[3])
double * TransformDoubleVector (double x, double y, double z)
double * TransformDoubleVector (const double vec[3])
void TransformPointsNormalsVectors (vtkPoints *inPts, vtkPoints *outPts, vtkDataArray *inNms, vtkDataArray *outNms, vtkDataArray *inVrs, vtkDataArray *outVrs)
vtkLinearTransform * GetLinearInverse ()
void InternalTransformPoint (const float in[3], float out[3])
void InternalTransformPoint (const double in[3], double out[3])
virtual void InternalTransformNormal (const float in[3], float out[3])
virtual void InternalTransformNormal (const double in[3], double out[3])
virtual void InternalTransformVector (const float in[3], float out[3])
virtual void InternalTransformVector (const double in[3], double out[3])
void InternalTransformDerivative (const float in[3], float out[3], float derivative[3][3])
void InternalTransformDerivative (const double in[3], double out[3], double derivative[3][3])
- Public Member Functions inherited from vtkHomogeneousTransform
vtkHomogeneousTransform * NewInstance () const
void GetMatrix (vtkMatrix4x4 *m)
vtkMatrix4x4 * GetMatrix ()
vtkHomogeneousTransform * GetHomogeneousInverse ()
- Public Member Functions inherited from vtkAbstractTransform
vtkAbstractTransform * NewInstance () const
double * TransformNormalAtPoint (const double point[3], const double normal[3])
double * TransformVectorAtPoint (const double point[3], const double vector[3])
void SetInverse (vtkAbstractTransform *transform)
void DeepCopy (vtkAbstractTransform *)
void Update ()
virtual void UnRegister (vtkObjectBase *O)
void TransformPoint (const float in[3], float out[3])
void TransformPoint (const double in[3], double out[3])
double * TransformPoint (double x, double y, double z)
double * TransformPoint (const double point[3])
float * TransformFloatPoint (float x, float y, float z)
float * TransformFloatPoint (const float point[3])
double * TransformDoublePoint (double x, double y, double z)
double * TransformDoublePoint (const double point[3])
void TransformNormalAtPoint (const float point[3], const float in[3], float out[3])
void TransformNormalAtPoint (const double point[3], const double in[3], double out[3])
double * TransformDoubleNormalAtPoint (const double point[3], const double normal[3])
float * TransformFloatNormalAtPoint (const float point[3], const float normal[3])
void TransformVectorAtPoint (const float point[3], const float in[3], float out[3])
void TransformVectorAtPoint (const double point[3], const double in[3], double out[3])
double * TransformDoubleVectorAtPoint (const double point[3], const double vector[3])
float * TransformFloatVectorAtPoint (const float point[3], const float vector[3])
static vtkPVRotateAroundOriginTransform * New ()
static vtkPVRotateAroundOriginTransform * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVTransform
static vtkPVTransform * New ()
static vtkPVTransform * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTransform
static vtkTransform * New ()
static vtkTransform * SafeDownCast (vtkObjectBase *o)
static void GetOrientation (double orient[3], vtkMatrix4x4 *matrix)
- Static Public Member Functions inherited from vtkLinearTransform
static vtkLinearTransform * SafeDownCast (vtkObjectBase *o)
- Static Public Member Functions inherited from vtkHomogeneousTransform
static vtkHomogeneousTransform * SafeDownCast (vtkObjectBase *o)
- Static Public Member Functions inherited from vtkAbstractTransform
static vtkAbstractTransform * SafeDownCast (vtkObjectBase *o)
 vtkPVRotateAroundOriginTransform ()=default
 ~vtkPVRotateAroundOriginTransform () override=default
void UpdateMatrix () override
- Protected Member Functions inherited from vtkPVTransform
 vtkPVTransform ()=default
 ~vtkPVTransform () override=default
- Protected Member Functions inherited from vtkTransform
 vtkTransform ()
 ~vtkTransform ()
void InternalDeepCopy (vtkAbstractTransform *t)
void InternalUpdate ()
- Protected Member Functions inherited from vtkLinearTransform
 vtkLinearTransform ()
 ~vtkLinearTransform ()
- Protected Member Functions inherited from vtkHomogeneousTransform
 vtkHomogeneousTransform ()
 ~vtkHomogeneousTransform ()
- Protected Member Functions inherited from vtkAbstractTransform
 vtkAbstractTransform ()
 ~vtkAbstractTransform ()
double OriginOfRotation [3] = { 0.0, 0.0, 0.0 }
- Protected Attributes inherited from vtkPVTransform
double AbsolutePosition [3] = { 0.0, 0.0, 0.0 }
double AbsoluteRotation [3] = { 0.0, 0.0, 0.0 }
double AbsoluteScale [3] = { 1.0, 1.0, 1.0 }
vtkNew< vtkTransform > AbsoluteTransform
- Protected Attributes inherited from vtkTransform
vtkLinearTransform * Input
vtkTransformConcatenation * Concatenation
vtkTransformConcatenationStack * Stack
vtkMTimeType MatrixUpdateMTime
float Point [4]
double DoublePoint [4]
double ReturnValue [4]
- Protected Attributes inherited from vtkHomogeneousTransform
vtkMatrix4x4 * Matrix
- Protected Attributes inherited from vtkAbstractTransform
float InternalFloatPoint [3]
double InternalDoublePoint [3]
vtkPVRotateAroundOriginTransform extend vtkPVTransform by setting an origin of rotation and overriding UpdateMatrix to rotate around this point.
Definition at line 18 of file vtkPVRotateAroundOriginTransform.h.
Definition at line 22 of file vtkPVRotateAroundOriginTransform.h.
◆ vtkPVRotateAroundOriginTransform()
vtkPVRotateAroundOriginTransform::vtkPVRotateAroundOriginTransform ( )
protecteddefault
◆ ~vtkPVRotateAroundOriginTransform()
vtkPVRotateAroundOriginTransform::~vtkPVRotateAroundOriginTransform ( )
overrideprotecteddefault
static vtkPVRotateAroundOriginTransform* vtkPVRotateAroundOriginTransform::New ( )
virtual const char* vtkPVRotateAroundOriginTransform::GetClassName ( )
Reimplemented from vtkPVTransform.
static int vtkPVRotateAroundOriginTransform::IsTypeOf ( const char *  type)
virtual int vtkPVRotateAroundOriginTransform::IsA ( const char *  type)
static vtkPVRotateAroundOriginTransform* vtkPVRotateAroundOriginTransform::SafeDownCast ( vtkObject *  o)
void vtkPVRotateAroundOriginTransform::PrintSelf ( ostream &  os,
Reimplemented from vtkTransform.
◆ SetOriginOfRotation() [1/2]
void vtkPVRotateAroundOriginTransform::SetOriginOfRotation ( double  xyz[3])
◆ SetOriginOfRotation() [2/2]
void vtkPVRotateAroundOriginTransform::SetOriginOfRotation ( double  x,
double  y,
double  z
◆ GetOriginOfRotation() [1/3]
virtual double* vtkPVRotateAroundOriginTransform::GetOriginOfRotation ( )
◆ GetOriginOfRotation() [2/3]
virtual void vtkPVRotateAroundOriginTransform::GetOriginOfRotation ( double &  ,
double &  ,
double &
◆ GetOriginOfRotation() [3/3]
virtual void vtkPVRotateAroundOriginTransform::GetOriginOfRotation ( double  [3])
◆ UpdateMatrix()
void vtkPVRotateAroundOriginTransform::UpdateMatrix ( )
overrideprotectedvirtual
◆ OriginOfRotation
double vtkPVRotateAroundOriginTransform::OriginOfRotation[3] = { 0.0, 0.0, 0.0 }
Definition at line 40 of file vtkPVRotateAroundOriginTransform.h.
