vtkPVProbeLineFilter Class Reference
Filter to simplify probe line usage when probing over a simple line. More...
#include <vtkPVProbeLineFilter.h>
Inheritance diagram for vtkPVProbeLineFilter:
Collaboration diagram for vtkPVProbeLineFilter:
typedef vtkPolyDataAlgorithm Superclass
- Public Types inherited from vtkPolyDataAlgorithm
enum  DesiredOutputPrecision
virtual void SetPassCellArrays (bool)
 Shallow copy the input cell data arrays to the output. More...
virtual void PassCellArraysOn ()
virtual void PassCellArraysOff ()
virtual bool GetPassCellArrays ()
virtual void SetPassPointArrays (bool)
 Shallow copy the input point data arrays to the output Off by default. More...
virtual void PassPointArraysOn ()
virtual void PassPointArraysOff ()
virtual bool GetPassPointArrays ()
virtual void SetPassFieldArrays (bool)
 Set whether to pass the field-data arrays from the Input i.e. More...
virtual void PassFieldArraysOn ()
virtual void PassFieldArraysOff ()
virtual bool GetPassFieldArrays ()
virtual void SetTolerance (double)
 Set the tolerance used to compute whether a point in the source is in a cell of the input. More...
virtual double GetTolerance ()
virtual void SetComputeTolerance (bool)
 Set whether to use the Tolerance field or precompute the tolerance. More...
virtual void ComputeToleranceOn ()
virtual void ComputeToleranceOff ()
virtual bool GetComputeTolerance ()
virtual void SetPassPartialArrays (bool)
 When dealing with composite datasets, partial arrays are common i.e. More...
virtual bool GetPassPartialArrays ()
virtual void PassPartialArraysOn ()
virtual void PassPartialArraysOff ()
virtual int GetSamplingPattern ()
 Setter and getter for SamplingPattern (values to be taken from the enumeration vtkProbeLineFilter::SamplingPattern). More...
virtual void SetSamplingPattern (int)
virtual int GetLineResolution ()
 Setter and getter for LineResolution. More...
virtual void SetLineResolution (int)
virtual double * GetPoint1 ()
 Get/Set the begin and end points for the line to probe against. More...
virtual void GetPoint1 (double &, double &, double &)
virtual void GetPoint1 (double[3])
virtual void SetPoint1 (double, double, double)
virtual void SetPoint1 (double[3])
virtual double * GetPoint2 ()
virtual void GetPoint2 (double &, double &, double &)
virtual void GetPoint2 (double[3])
virtual void SetPoint2 (double, double, double)
virtual void SetPoint2 (double[3])
- Public Member Functions inherited from vtkPolyDataAlgorithm
vtkPolyDataAlgorithm * NewInstance () const
vtkDataObject * GetInput ()
vtkPolyData * GetPolyDataInput (int port)
vtkPolyData * GetOutput ()
vtkPolyData * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVProbeLineFilter * New ()
static vtkPVProbeLineFilter * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPolyDataAlgorithm
static vtkPolyDataAlgorithm * New ()
static vtkPolyDataAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPVProbeLineFilter ()
 ~vtkPVProbeLineFilter () override=default
int FillInputPortInformation (int, vtkInformation *) override
- Protected Member Functions inherited from vtkPolyDataAlgorithm
 vtkPolyDataAlgorithm ()
 ~vtkPolyDataAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int SamplingPattern = 0
int LineResolution = 1000
bool PassPartialArrays = false
bool PassCellArrays = false
bool PassPointArrays = false
bool PassFieldArrays = false
bool ComputeTolerance = true
double Tolerance = 1.0
double Point1 [3] = { 0, 0, 0 }
double Point2 [3] = { 1, 1, 1 }
vtkNew< vtkLineSource > LineSource
vtkNew< vtkProbeLineFilter > Prober
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
Internal Paraview filters for API backward compatibilty and ease of use. Internally build a line source as well as a vtkProbeLineFilter and exposes their properties.
Definition at line 22 of file vtkPVProbeLineFilter.h.
Definition at line 27 of file vtkPVProbeLineFilter.h.
◆ vtkPVProbeLineFilter()
vtkPVProbeLineFilter::vtkPVProbeLineFilter ( )
◆ ~vtkPVProbeLineFilter()
vtkPVProbeLineFilter::~vtkPVProbeLineFilter ( )
overrideprotecteddefault
static vtkPVProbeLineFilter* vtkPVProbeLineFilter::New ( )
virtual const char* vtkPVProbeLineFilter::GetClassName ( )
static int vtkPVProbeLineFilter::IsTypeOf ( const char *  type)
virtual int vtkPVProbeLineFilter::IsA ( const char *  type)
Reimplemented from vtkPolyDataAlgorithm.
static vtkPVProbeLineFilter* vtkPVProbeLineFilter::SafeDownCast ( vtkObject *  o)
void vtkPVProbeLineFilter::PrintSelf ( ostream &  os,
◆ SetPassCellArrays()
virtual void vtkPVProbeLineFilter::SetPassCellArrays ( bool  )
Off by default.
◆ PassCellArraysOn()
virtual void vtkPVProbeLineFilter::PassCellArraysOn ( )
Off by default.
◆ PassCellArraysOff()
virtual void vtkPVProbeLineFilter::PassCellArraysOff ( )
Off by default.
◆ GetPassCellArrays()
virtual bool vtkPVProbeLineFilter::GetPassCellArrays ( )
Off by default.
◆ SetPassPointArrays()
virtual void vtkPVProbeLineFilter::SetPassPointArrays ( bool  )
◆ PassPointArraysOn()
virtual void vtkPVProbeLineFilter::PassPointArraysOn ( )
◆ PassPointArraysOff()
virtual void vtkPVProbeLineFilter::PassPointArraysOff ( )
◆ GetPassPointArrays()
virtual bool vtkPVProbeLineFilter::GetPassPointArrays ( )
◆ SetPassFieldArrays()
virtual void vtkPVProbeLineFilter::SetPassFieldArrays ( bool  )
the input providing the geometry to the output. On by default.
◆ PassFieldArraysOn()
virtual void vtkPVProbeLineFilter::PassFieldArraysOn ( )
◆ PassFieldArraysOff()
virtual void vtkPVProbeLineFilter::PassFieldArraysOff ( )
◆ GetPassFieldArrays()
virtual bool vtkPVProbeLineFilter::GetPassFieldArrays ( )
◆ SetTolerance()
virtual void vtkPVProbeLineFilter::SetTolerance ( double  )
This value is only used if ComputeTolerance is off.
◆ GetTolerance()
virtual double vtkPVProbeLineFilter::GetTolerance ( )
◆ SetComputeTolerance()
virtual void vtkPVProbeLineFilter::SetComputeTolerance ( bool  )
When on, the tolerance will be computed and the field value is ignored. On by default.
◆ ComputeToleranceOn()
virtual void vtkPVProbeLineFilter::ComputeToleranceOn ( )
◆ ComputeToleranceOff()
virtual void vtkPVProbeLineFilter::ComputeToleranceOff ( )
◆ GetComputeTolerance()
virtual bool vtkPVProbeLineFilter::GetComputeTolerance ( )
◆ SetPassPartialArrays()
virtual void vtkPVProbeLineFilter::SetPassPartialArrays ( bool  )
data-arrays that are not available in all of the blocks. By default, this filter only passes those point and cell data-arrays that are available in all the blocks i.e. partial array are removed. When PassPartialArrays is turned on, this behavior is changed to take a union of all arrays present thus partial arrays are passed as well. However, for composite dataset input, this filter still produces a non-composite output. For all those locations in a block of where a particular data array is missing, this filter uses vtkMath::Nan() for double and float arrays, while 0 for all other types of arrays i.e int, char etc.
◆ GetPassPartialArrays()
virtual bool vtkPVProbeLineFilter::GetPassPartialArrays ( )
◆ PassPartialArraysOn()
virtual void vtkPVProbeLineFilter::PassPartialArraysOn ( )
◆ PassPartialArraysOff()
virtual void vtkPVProbeLineFilter::PassPartialArraysOff ( )
◆ GetSamplingPattern()
virtual int vtkPVProbeLineFilter::GetSamplingPattern ( )
◆ SetSamplingPattern()
virtual void vtkPVProbeLineFilter::SetSamplingPattern ( int  )
◆ GetLineResolution()
virtual int vtkPVProbeLineFilter::GetLineResolution ( )
This attribute is only used if sampling using SamplingPattern::SAMPLE_LINE_UNIFORMLY. It sets the number of points in the sampling line.
◆ SetLineResolution()
virtual void vtkPVProbeLineFilter::SetLineResolution ( int  )
◆ GetPoint1() [1/3]
virtual double* vtkPVProbeLineFilter::GetPoint1 ( )
◆ GetPoint1() [2/3]
virtual void vtkPVProbeLineFilter::GetPoint1 ( double &  ,
double &  ,
double &
◆ GetPoint1() [3/3]
virtual void vtkPVProbeLineFilter::GetPoint1 ( double  [3])
◆ SetPoint1() [1/2]
virtual void vtkPVProbeLineFilter::SetPoint1 ( double  ,
double  ,
double
◆ SetPoint1() [2/2]
virtual void vtkPVProbeLineFilter::SetPoint1 ( double  [3])
◆ GetPoint2() [1/3]
virtual double* vtkPVProbeLineFilter::GetPoint2 ( )
◆ GetPoint2() [2/3]
virtual void vtkPVProbeLineFilter::GetPoint2 ( double &  ,
double &  ,
double &
◆ GetPoint2() [3/3]
virtual void vtkPVProbeLineFilter::GetPoint2 ( double  [3])
◆ SetPoint2() [1/2]
virtual void vtkPVProbeLineFilter::SetPoint2 ( double  ,
double  ,
double
◆ SetPoint2() [2/2]
virtual void vtkPVProbeLineFilter::SetPoint2 ( double  [3])
◆ RequestData()
int vtkPVProbeLineFilter::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ FillInputPortInformation()
int vtkPVProbeLineFilter::FillInputPortInformation ( int  ,
vtkInformation *
◆ SamplingPattern
int vtkPVProbeLineFilter::SamplingPattern = 0
Definition at line 135 of file vtkPVProbeLineFilter.h.
◆ LineResolution
int vtkPVProbeLineFilter::LineResolution = 1000
Definition at line 136 of file vtkPVProbeLineFilter.h.
◆ PassPartialArrays
bool vtkPVProbeLineFilter::PassPartialArrays = false
Definition at line 137 of file vtkPVProbeLineFilter.h.
◆ PassCellArrays
bool vtkPVProbeLineFilter::PassCellArrays = false
Definition at line 138 of file vtkPVProbeLineFilter.h.
◆ PassPointArrays
bool vtkPVProbeLineFilter::PassPointArrays = false
Definition at line 139 of file vtkPVProbeLineFilter.h.
◆ PassFieldArrays
bool vtkPVProbeLineFilter::PassFieldArrays = false
Definition at line 140 of file vtkPVProbeLineFilter.h.
◆ ComputeTolerance
bool vtkPVProbeLineFilter::ComputeTolerance = true
Definition at line 141 of file vtkPVProbeLineFilter.h.
◆ Tolerance
double vtkPVProbeLineFilter::Tolerance = 1.0
Definition at line 142 of file vtkPVProbeLineFilter.h.
◆ Point1
double vtkPVProbeLineFilter::Point1[3] = { 0, 0, 0 }
Definition at line 143 of file vtkPVProbeLineFilter.h.
◆ Point2
double vtkPVProbeLineFilter::Point2[3] = { 1, 1, 1 }
Definition at line 144 of file vtkPVProbeLineFilter.h.
◆ LineSource
vtkNew<vtkLineSource> vtkPVProbeLineFilter::LineSource
Definition at line 146 of file vtkPVProbeLineFilter.h.
◆ Prober
vtkNew<vtkProbeLineFilter> vtkPVProbeLineFilter::Prober
Definition at line 147 of file vtkPVProbeLineFilter.h.
