vtkPVPlaneCutter Class Reference
Slice with plane filter. More...
#include <vtkPVPlaneCutter.h>
Inherits vtkPlaneCutter.
Collaboration diagram for vtkPVPlaneCutter:
typedef vtkPlaneCutter Superclass
int ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
virtual bool GetDual ()
 @ More...
virtual void SetDual (bool)
virtual void SetLevelOfResolution (int)
 Sets the level of resolution. More...
virtual int GetLevelOfResolution ()
virtual void SetUseNativeCutter (bool)
 Sets if plane cutter is used instead of the specialized AMR cutter. More...
virtual bool GetUseNativeCutter ()
virtual void UseNativeCutterOn ()
virtual void UseNativeCutterOff ()
static vtkPVPlaneCutter * SafeDownCast (vtkObject *o)
static vtkPVPlaneCutter * New ()
 vtkPVPlaneCutter ()
 ~vtkPVPlaneCutter () override
int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
int FillInputPortInformation (int, vtkInformation *info) override
int FillOutputPortInformation (int, vtkInformation *info) override
bool Dual = false
int LevelOfResolution = 0
bool UseNativeCutter = true
vtkNew< vtkAMRCutPlane > AMRPlaneCutter
vtkNew< vtkAMRSliceFilter > AMRAxisAlignedPlaneCutter
vtkNew< vtkHyperTreeGridPlaneCutter > HTGPlaneCutter
vtkNew< vtkHyperTreeGridAxisCut > HTGAxisAlignedPlaneCutter
This is a subclass of vtkPlaneCutter that allows selection of input vtkHyperTreeGrid, vtkOverlappingAMR.
Definition at line 22 of file vtkPVPlaneCutter.h.
typedef vtkPlaneCutter vtkPVPlaneCutter::Superclass
Definition at line 25 of file vtkPVPlaneCutter.h.
◆ vtkPVPlaneCutter()
vtkPVPlaneCutter::vtkPVPlaneCutter ( )
◆ ~vtkPVPlaneCutter()
vtkPVPlaneCutter::~vtkPVPlaneCutter ( )
virtual const char* vtkPVPlaneCutter::GetClassName ( )
static int vtkPVPlaneCutter::IsTypeOf ( const char *  type)
virtual int vtkPVPlaneCutter::IsA ( const char *  type)
static vtkPVPlaneCutter* vtkPVPlaneCutter::SafeDownCast ( vtkObject *  o)
void vtkPVPlaneCutter::PrintSelf ( ostream &  os,
override
static vtkPVPlaneCutter* vtkPVPlaneCutter::New ( )
◆ ProcessRequest()
int vtkPVPlaneCutter::ProcessRequest ( vtkInformation *  ,
vtkInformationVector **  ,
override
◆ GetDual()
virtual bool vtkPVPlaneCutter::GetDual ( )
If set to true, the dual grid is used for cutting.
Default is false.
Note: Only used for cutting hyper tree grids.
◆ SetDual()
virtual void vtkPVPlaneCutter::SetDual ( bool  )
◆ SetLevelOfResolution()
virtual void vtkPVPlaneCutter::SetLevelOfResolution ( int  )
Default is 0.
Note: Only used for cutting overlapping AMR.
◆ GetLevelOfResolution()
virtual int vtkPVPlaneCutter::GetLevelOfResolution ( )
Default is 0.
◆ SetUseNativeCutter()
virtual void vtkPVPlaneCutter::SetUseNativeCutter ( bool  )
Default is true.
◆ GetUseNativeCutter()
virtual bool vtkPVPlaneCutter::GetUseNativeCutter ( )
Default is true.
◆ UseNativeCutterOn()
virtual void vtkPVPlaneCutter::UseNativeCutterOn ( )
Default is true.
◆ UseNativeCutterOff()
virtual void vtkPVPlaneCutter::UseNativeCutterOff ( )
Default is true.
◆ RequestData()
int vtkPVPlaneCutter::RequestData ( vtkInformation *  ,
◆ RequestDataObject()
int vtkPVPlaneCutter::RequestDataObject ( vtkInformation *  ,
◆ FillInputPortInformation()
int vtkPVPlaneCutter::FillInputPortInformation ( int  ,
vtkInformation *  info
◆ FillOutputPortInformation()
int vtkPVPlaneCutter::FillOutputPortInformation ( int  ,
◆ Dual
bool vtkPVPlaneCutter::Dual = false
Definition at line 80 of file vtkPVPlaneCutter.h.
◆ LevelOfResolution
int vtkPVPlaneCutter::LevelOfResolution = 0
Definition at line 81 of file vtkPVPlaneCutter.h.
◆ UseNativeCutter
bool vtkPVPlaneCutter::UseNativeCutter = true
Definition at line 82 of file vtkPVPlaneCutter.h.
◆ AMRPlaneCutter
vtkNew<vtkAMRCutPlane> vtkPVPlaneCutter::AMRPlaneCutter
Definition at line 84 of file vtkPVPlaneCutter.h.
◆ AMRAxisAlignedPlaneCutter
vtkNew<vtkAMRSliceFilter> vtkPVPlaneCutter::AMRAxisAlignedPlaneCutter
Definition at line 85 of file vtkPVPlaneCutter.h.
◆ HTGPlaneCutter
vtkNew<vtkHyperTreeGridPlaneCutter> vtkPVPlaneCutter::HTGPlaneCutter
Definition at line 86 of file vtkPVPlaneCutter.h.
◆ HTGAxisAlignedPlaneCutter
vtkNew<vtkHyperTreeGridAxisCut> vtkPVPlaneCutter::HTGAxisAlignedPlaneCutter
Definition at line 87 of file vtkPVPlaneCutter.h.
