vtkPVMergeTablesMultiBlock Class Reference
used to merge rows in tables. More...
#include <vtkPVMergeTablesMultiBlock.h>
Inheritance diagram for vtkPVMergeTablesMultiBlock:
Collaboration diagram for vtkPVMergeTablesMultiBlock:
typedef vtkMultiBlockDataSetAlgorithm Superclass
- Public Types inherited from vtkMultiBlockDataSetAlgorithm
enum  DesiredOutputPrecision
- Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
vtkMultiBlockDataSetAlgorithm * NewInstance () const
vtkMultiBlockDataSet * GetOutput ()
vtkMultiBlockDataSet * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVMergeTablesMultiBlock * New ()
static vtkPVMergeTablesMultiBlock * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
static vtkMultiBlockDataSetAlgorithm * New ()
static vtkMultiBlockDataSetAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPVMergeTablesMultiBlock ()
 ~vtkPVMergeTablesMultiBlock () override
- Protected Member Functions inherited from vtkMultiBlockDataSetAlgorithm
 vtkMultiBlockDataSetAlgorithm ()
 ~vtkMultiBlockDataSetAlgorithm ()
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
Simplified version of vtkMergeTables which simply combines tables merging columns. This assumes that each of the inputs either has exactly identical columns or no columns at all. This filter can handle composite datasets as well. The output is produced by merging corresponding leaf nodes. This assumes that all inputs have the same composite structure. All inputs must either be vtkTable or vtkCompositeDataSet mixing is not allowed. The output is a multiblock dataset of vtkTable.
Todo:
We may want to consolidate with vtkPVMergeTable somehow
Definition at line 26 of file vtkPVMergeTablesMultiBlock.h.
Definition at line 31 of file vtkPVMergeTablesMultiBlock.h.
◆ vtkPVMergeTablesMultiBlock()
vtkPVMergeTablesMultiBlock::vtkPVMergeTablesMultiBlock ( )
◆ ~vtkPVMergeTablesMultiBlock()
vtkPVMergeTablesMultiBlock::~vtkPVMergeTablesMultiBlock ( )
static vtkPVMergeTablesMultiBlock* vtkPVMergeTablesMultiBlock::New ( )
virtual const char* vtkPVMergeTablesMultiBlock::GetClassName ( )
static int vtkPVMergeTablesMultiBlock::IsTypeOf ( const char *  type)
virtual int vtkPVMergeTablesMultiBlock::IsA ( const char *  type)
Reimplemented from vtkMultiBlockDataSetAlgorithm.
static vtkPVMergeTablesMultiBlock* vtkPVMergeTablesMultiBlock::SafeDownCast ( vtkObject *  o)
void vtkPVMergeTablesMultiBlock::PrintSelf ( ostream &  os,
◆ FillInputPortInformation()
int vtkPVMergeTablesMultiBlock::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ RequestData()
int vtkPVMergeTablesMultiBlock::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
