Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | List of all members
vtkPVMergeTables Class Reference
used to merge rows in tables. More...
#include <vtkPVMergeTables.h>
Inheritance diagram for vtkPVMergeTables:
Collaboration diagram for vtkPVMergeTables:
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithm * NewInstance () const
vtkTable * GetOutput ()
vtkTable * GetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVMergeTables * New ()
static vtkPVMergeTables * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithm * New ()
static vtkTableAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPVMergeTables ()
 ~vtkPVMergeTables () override
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
static std::vector< vtkTable * > GetTables (vtkInformationVector *inputVector)
static void MergeTables (vtkTable *output, const std::vector< vtkTable * > &tables)
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
Simplified version of vtkMergeTables which simply combines tables merging columns. This assumes that each of the inputs either has exactly identical columns or no columns at all. This filter can handle composite datasets as well. The output is produced by merging corresponding leaf nodes. This assumes that all inputs have the same composite structure. All inputs must either be vtkTable or vtkCompositeDataSet mixing is not allowed. The output is a flattened vtkTable.
Todo:
We may want to merge this functionality into vtkMergeTables filter itself.
Definition at line 29 of file vtkPVMergeTables.h.
Definition at line 33 of file vtkPVMergeTables.h.
◆ vtkPVMergeTables()
vtkPVMergeTables::vtkPVMergeTables ( )
◆ ~vtkPVMergeTables()
vtkPVMergeTables::~vtkPVMergeTables ( )
static vtkPVMergeTables* vtkPVMergeTables::New ( )
virtual const char* vtkPVMergeTables::GetClassName ( )
static int vtkPVMergeTables::IsTypeOf ( const char *  type)
virtual int vtkPVMergeTables::IsA ( const char *  type)
Reimplemented from vtkTableAlgorithm.
static vtkPVMergeTables* vtkPVMergeTables::SafeDownCast ( vtkObject *  o)
void vtkPVMergeTables::PrintSelf ( ostream &  os,
◆ RequestData()
int vtkPVMergeTables::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ FillInputPortInformation()
int vtkPVMergeTables::FillInputPortInformation ( int  port,
vtkInformation *  info
◆ CreateDefaultExecutive()
vtkExecutive* vtkPVMergeTables::CreateDefaultExecutive ( )
◆ GetTables()
static std::vector<vtkTable*> vtkPVMergeTables::GetTables ( vtkInformationVector *  inputVector)
staticprotected
◆ MergeTables()
static void vtkPVMergeTables::MergeTables ( vtkTable *  output,
const std::vector< vtkTable * > &  tables
staticprotected
