vtkPVExtractVOI Class Reference
select piece (e.g., volume of interest) and/or subsample structured dataset More...
#include <vtkPVExtractVOI.h>
Inheritance diagram for vtkPVExtractVOI:
Collaboration diagram for vtkPVExtractVOI:
typedef vtkDataSetAlgorithm Superclass
- Public Types inherited from vtkDataSetAlgorithm
enum  DesiredOutputPrecision
virtual void SetVOI (int, int, int, int, int, int)
 Specify i-j-k (min,max) pairs to extract. More...
virtual void SetVOI (int[6])
virtual int * GetVOI ()
virtual void GetVOI (int data[6])
virtual void SetSampleRate (int, int, int)
 Set the sampling rate in the i, j, and k directions. More...
virtual void SetSampleRate (int[3])
virtual int * GetSampleRate ()
virtual void GetSampleRate (int data[3])
void SetSampleRateI (int ratei)
 Set/get the individual components of the sample rate. More...
void SetSampleRateJ (int ratej)
void SetSampleRateK (int ratek)
int GetSampleRateI ()
int GetSampleRateJ ()
int GetSampleRateK ()
virtual void SetIncludeBoundary (int)
 Control whether to enforce that the "boundary" of the grid is output in the subsampling process. More...
virtual int GetIncludeBoundary ()
virtual void IncludeBoundaryOn ()
virtual void IncludeBoundaryOff ()
- Public Member Functions inherited from vtkDataSetAlgorithm
vtkDataSetAlgorithm * NewInstance () const
vtkDataObject * GetInput ()
vtkDataSet * GetOutput ()
vtkDataSet * GetOutput (int)
void SetInputData (vtkDataSet *)
void SetInputData (int, vtkDataSet *)
void AddInputData (vtkDataSet *)
void AddInputData (int, vtkDataSet *)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVExtractVOI * New ()
static vtkPVExtractVOI * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkDataSetAlgorithm
static vtkDataSetAlgorithm * New ()
static vtkDataSetAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPVExtractVOI ()
 ~vtkPVExtractVOI () override
int RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
int RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
void ReportReferences (vtkGarbageCollector *) override
- Protected Member Functions inherited from vtkDataSetAlgorithm
 vtkDataSetAlgorithm ()
 ~vtkDataSetAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int VOI [6]
int SampleRate [3]
int IncludeBoundary
vtkExtractVOI * ExtractVOI
vtkExtractGrid * ExtractGrid
vtkExtractRectilinearGrid * ExtractRG
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkPVExtractVOI is a wrapper around vtkExtractVOI, vtkExtractGrid and vtkExtractRectilinearGrid. It choose the right filter depending on input and passes the necessary parameters.
See also
vtkExtractVOI vtkExtractGrid vtkExtractRectilinearGrid
Definition at line 27 of file vtkPVExtractVOI.h.
Definition at line 32 of file vtkPVExtractVOI.h.
◆ vtkPVExtractVOI()
vtkPVExtractVOI::vtkPVExtractVOI ( )
◆ ~vtkPVExtractVOI()
vtkPVExtractVOI::~vtkPVExtractVOI ( )
static vtkPVExtractVOI* vtkPVExtractVOI::New ( )
virtual const char* vtkPVExtractVOI::GetClassName ( )
static int vtkPVExtractVOI::IsTypeOf ( const char *  type)
virtual int vtkPVExtractVOI::IsA ( const char *  type)
Reimplemented from vtkDataSetAlgorithm.
static vtkPVExtractVOI* vtkPVExtractVOI::SafeDownCast ( vtkObject *  o)
void vtkPVExtractVOI::PrintSelf ( ostream &  os,
◆ SetVOI() [1/2]
virtual void vtkPVExtractVOI::SetVOI ( int  ,
int  ,
int  ,
int  ,
int  ,
int
The resulting structured grid dataset can be of any topological dimension (i.e., point, line, plane, or 3D grid).
◆ SetVOI() [2/2]
virtual void vtkPVExtractVOI::SetVOI ( int  [6])
◆ GetVOI() [1/2]
virtual int* vtkPVExtractVOI::GetVOI ( )
◆ GetVOI() [2/2]
virtual void vtkPVExtractVOI::GetVOI ( int  data[6])
◆ SetSampleRate() [1/2]
virtual void vtkPVExtractVOI::SetSampleRate ( int  ,
int  ,
int
If the rate is > 1, then the resulting VOI will be subsampled representation of the input. For example, if the SampleRate=(2,2,2), every other point will be selected, resulting in a volume 1/8th the original size.
◆ SetSampleRate() [2/2]
virtual void vtkPVExtractVOI::SetSampleRate ( int  [3])
◆ GetSampleRate() [1/2]
virtual int* vtkPVExtractVOI::GetSampleRate ( )
◆ GetSampleRate() [2/2]
virtual void vtkPVExtractVOI::GetSampleRate ( int  data[3])
◆ SetSampleRateI()
void vtkPVExtractVOI::SetSampleRateI ( int  ratei)
◆ SetSampleRateJ()
void vtkPVExtractVOI::SetSampleRateJ ( int  ratej)
◆ SetSampleRateK()
void vtkPVExtractVOI::SetSampleRateK ( int  ratek)
◆ GetSampleRateI()
int vtkPVExtractVOI::GetSampleRateI ( )
inline
Definition at line 63 of file vtkPVExtractVOI.h.
◆ GetSampleRateJ()
int vtkPVExtractVOI::GetSampleRateJ ( )
inline
Definition at line 64 of file vtkPVExtractVOI.h.
◆ GetSampleRateK()
int vtkPVExtractVOI::GetSampleRateK ( )
inline
Definition at line 65 of file vtkPVExtractVOI.h.
◆ SetIncludeBoundary()
virtual void vtkPVExtractVOI::SetIncludeBoundary ( int  )
(This ivar only has effect when the SampleRate in any direction is not equal to 1.) When this ivar IncludeBoundary is on, the subsampling will always include the boundary of the grid even though the sample rate is not an even multiple of the grid dimensions. (By default IncludeBoundary is off.)
◆ GetIncludeBoundary()
virtual int vtkPVExtractVOI::GetIncludeBoundary ( )
◆ IncludeBoundaryOn()
virtual void vtkPVExtractVOI::IncludeBoundaryOn ( )
◆ IncludeBoundaryOff()
virtual void vtkPVExtractVOI::IncludeBoundaryOff ( )
◆ RequestData()
int vtkPVExtractVOI::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ RequestInformation()
int vtkPVExtractVOI::RequestInformation ( vtkInformation *  ,
◆ RequestUpdateExtent()
int vtkPVExtractVOI::RequestUpdateExtent ( vtkInformation *  ,
◆ ReportReferences()
void vtkPVExtractVOI::ReportReferences ( vtkGarbageCollector *  )
◆ VOI
int vtkPVExtractVOI::VOI[6]
Definition at line 90 of file vtkPVExtractVOI.h.
◆ SampleRate
int vtkPVExtractVOI::SampleRate[3]
Definition at line 91 of file vtkPVExtractVOI.h.
◆ IncludeBoundary
int vtkPVExtractVOI::IncludeBoundary
Definition at line 92 of file vtkPVExtractVOI.h.
◆ ExtractVOI
vtkExtractVOI* vtkPVExtractVOI::ExtractVOI
Definition at line 94 of file vtkPVExtractVOI.h.
◆ ExtractGrid
vtkExtractGrid* vtkPVExtractVOI::ExtractGrid
Definition at line 95 of file vtkPVExtractVOI.h.
◆ ExtractRG
vtkExtractRectilinearGrid* vtkPVExtractVOI::ExtractRG
Definition at line 96 of file vtkPVExtractVOI.h.
