Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
vtkPVExtractHistogram2D Class Reference
Extract 2D histogram for a parallel dataset. More...
#include <vtkPVExtractHistogram2D.h>
Inheritance diagram for vtkPVExtractHistogram2D:
Collaboration diagram for vtkPVExtractHistogram2D:
virtual void SetController (vtkMultiProcessController *)
 Get/Set the multiprocess controller. More...
virtual void SetComponent0 (int)
 Set/Get the components of interest from the two arrays. More...
virtual int GetComponent0 ()
virtual void SetComponent1 (int)
virtual int GetComponent1 ()
void SetComponent (int id, int val)
int GetComponent (int id)
virtual void SetNumberOfBins (int, int)
 Set/get the number of bins to be used per dimension (x,y) More...
void SetNumberOfBins (int[2])
virtual int * GetNumberOfBins ()
virtual void GetNumberOfBins (int &, int &)
virtual void GetNumberOfBins (int[2])
virtual void SetCustomBinRanges0 (double, double)
 Set/Get whether to use custom bin ranges. More...
void SetCustomBinRanges0 (double[2])
virtual double * GetCustomBinRanges0 ()
virtual void GetCustomBinRanges0 (double &, double &)
virtual void GetCustomBinRanges0 (double[2])
virtual void SetCustomBinRanges1 (double, double)
void SetCustomBinRanges1 (double[2])
virtual double * GetCustomBinRanges1 ()
virtual void GetCustomBinRanges1 (double &, double &)
virtual void GetCustomBinRanges1 (double[2])
virtual void SetUseCustomBinRanges0 (bool)
virtual bool GetUseCustomBinRanges0 ()
virtual void UseCustomBinRanges0On ()
virtual void UseCustomBinRanges0Off ()
virtual void SetUseCustomBinRanges1 (bool)
virtual bool GetUseCustomBinRanges1 ()
virtual void UseCustomBinRanges1On ()
virtual void UseCustomBinRanges1Off ()
virtual void SetUseGradientForYAxis (bool)
 Set/Get whether to use the gradient of the scalar array as the Y-axis of the 2D histogram. More...
virtual bool GetUseGradientForYAxis ()
virtual void UseGradientForYAxisOn ()
virtual void UseGradientForYAxisOff ()
virtual void SetUseInputRangesForOutputBounds (bool)
 Set/Get whether the output image bounds are obtained from input data array ranges. More...
virtual bool GetUseInputRangesForOutputBounds ()
virtual void UseInputRangesForOutputBoundsOn ()
virtual void UseInputRangesForOutputBoundsOff ()
virtual void SetOutputOrigin (double, double)
 Set/Get the output histogram image origin and spacing. More...
void SetOutputOrigin (double[2])
virtual double * GetOutputOrigin ()
virtual void GetOutputOrigin (double &, double &)
virtual void GetOutputOrigin (double[2])
virtual void SetOutputSpacing (double, double)
void SetOutputSpacing (double[2])
virtual double * GetOutputSpacing ()
virtual void GetOutputSpacing (double &, double &)
virtual void GetOutputSpacing (double[2])
- Public Member Functions inherited from vtkImageAlgorithm
vtkImageAlgorithm * NewInstance () const
vtkImageData * GetOutput ()
vtkImageData * GetOutput (int)
vtkDataObject * GetInput ()
vtkImageData * GetImageDataInput (int port)
virtual void AddInputData (vtkDataObject *)
virtual void AddInputData (int, vtkDataObject *)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVExtractHistogram2D * New ()
 Instantiate the class. More...
- Static Public Member Functions inherited from vtkImageAlgorithm
static vtkImageAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPVExtractHistogram2D ()
 ~vtkPVExtractHistogram2D () override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
void ComputeHistogram2D (vtkImageData *histogram)
void ComputeGradient (vtkDataObject *input)
void InitializeCache ()
void GetInputArrays (vtkInformationVector **)
void ComputeVectorMagnitude (vtkDataArray *, vtkDataArray *&)
void ComputeComponentRange ()
- Protected Member Functions inherited from vtkImageAlgorithm
 vtkImageAlgorithm ()
 ~vtkImageAlgorithm ()
virtual void CopyInputArrayAttributesToOutput (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
virtual void ExecuteDataWithInformation (vtkDataObject *output, vtkInformation *outInfo)
virtual void ExecuteData (vtkDataObject *output)
virtual void Execute ()
virtual void AllocateOutputData (vtkImageData *out, vtkInformation *outInfo, int *uExtent)
virtual vtkImageData * AllocateOutputData (vtkDataObject *out, vtkInformation *outInfo)
virtual void CopyAttributeData (vtkImageData *in, vtkImageData *out, vtkInformationVector **inputVector)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int Component0 = 0
int Component1 = 0
int NumberOfBins [2] = { 256, 256 }
bool UseGradientForYAxis = false
double CustomBinRanges0 [2]
double CustomBinRanges1 [2]
bool UseCustomBinRanges0 = false
bool UseCustomBinRanges1 = false
vtkMultiProcessController * Controller = nullptr
bool UseInputRangesForOutputBounds = true
double OutputOrigin [2] = { 0.0, 0.0 }
double OutputSpacing [2] = { 1.0, 1.0 }
int ComponentIndexCache [2]
vtkDataArray * ComponentArrayCache [2]
vtkUnsignedCharArray * GhostArray
unsigned char GhostsToSkip
double ComponentRangeCache [2][2]
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
typedef vtkImageAlgorithm Superclass
 Standard methods for the VTK class. More...
static vtkPVExtractHistogram2D * SafeDownCast (vtkObject *o)
- Public Types inherited from vtkImageAlgorithm
enum  DesiredOutputPrecision
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkPVExtractHistogram2D is a vtkImageAlgorithm subclass for parallel datasets, to extract the 2D histogram. It uses vtkExtractHistogram2D internally and gathers the histogram data on the root node.
Definition at line 24 of file vtkPVExtractHistogram2D.h.
Definition at line 36 of file vtkPVExtractHistogram2D.h.
◆ vtkPVExtractHistogram2D()
vtkPVExtractHistogram2D::vtkPVExtractHistogram2D ( )
◆ ~vtkPVExtractHistogram2D()
vtkPVExtractHistogram2D::~vtkPVExtractHistogram2D ( )
static vtkPVExtractHistogram2D* vtkPVExtractHistogram2D::New ( )
virtual const char* vtkPVExtractHistogram2D::GetClassName ( )
static int vtkPVExtractHistogram2D::IsTypeOf ( const char *  type)
virtual int vtkPVExtractHistogram2D::IsA ( const char *  type)
Reimplemented from vtkImageAlgorithm.
static vtkPVExtractHistogram2D* vtkPVExtractHistogram2D::SafeDownCast ( vtkObject *  o)
void vtkPVExtractHistogram2D::PrintSelf ( ostream &  os,
◆ SetController()
virtual void vtkPVExtractHistogram2D::SetController ( vtkMultiProcessController *  )
If no controller is set, single process is assumed.
◆ GetController()
virtual vtkMultiProcessController* vtkPVExtractHistogram2D::GetController ( )
◆ SetComponent0()
virtual void vtkPVExtractHistogram2D::SetComponent0 ( int  )
Component0 is the component from input array 0 and Component1 is the component from input array
  1. Set the input arrays using SetInputArrayToProcess.
◆ GetComponent0()
virtual int vtkPVExtractHistogram2D::GetComponent0 ( )
◆ SetComponent1()
virtual void vtkPVExtractHistogram2D::SetComponent1 ( int  )
◆ GetComponent1()
virtual int vtkPVExtractHistogram2D::GetComponent1 ( )
◆ SetComponent()
void vtkPVExtractHistogram2D::SetComponent ( int  id,
int  val
inline
Definition at line 59 of file vtkPVExtractHistogram2D.h.
◆ GetComponent()
int vtkPVExtractHistogram2D::GetComponent ( int  id)
inline
Definition at line 60 of file vtkPVExtractHistogram2D.h.
◆ SetNumberOfBins() [1/2]
virtual void vtkPVExtractHistogram2D::SetNumberOfBins ( int  ,
int
◆ SetNumberOfBins() [2/2]
void vtkPVExtractHistogram2D::SetNumberOfBins ( int  [2])
◆ GetNumberOfBins() [1/3]
virtual int* vtkPVExtractHistogram2D::GetNumberOfBins ( )
◆ GetNumberOfBins() [2/3]
virtual void vtkPVExtractHistogram2D::GetNumberOfBins ( int &  ,
int &
◆ GetNumberOfBins() [3/3]
virtual void vtkPVExtractHistogram2D::GetNumberOfBins ( int  [2])
◆ SetCustomBinRanges0() [1/2]
virtual void vtkPVExtractHistogram2D::SetCustomBinRanges0 ( double  ,
double
◆ SetCustomBinRanges0() [2/2]
void vtkPVExtractHistogram2D::SetCustomBinRanges0 ( double  [2])
◆ GetCustomBinRanges0() [1/3]
virtual double* vtkPVExtractHistogram2D::GetCustomBinRanges0 ( )
◆ GetCustomBinRanges0() [2/3]
virtual void vtkPVExtractHistogram2D::GetCustomBinRanges0 ( double &  ,
double &
◆ GetCustomBinRanges0() [3/3]
virtual void vtkPVExtractHistogram2D::GetCustomBinRanges0 ( double  [2])
◆ SetCustomBinRanges1() [1/2]
virtual void vtkPVExtractHistogram2D::SetCustomBinRanges1 ( double  ,
double
◆ SetCustomBinRanges1() [2/2]
void vtkPVExtractHistogram2D::SetCustomBinRanges1 ( double  [2])
◆ GetCustomBinRanges1() [1/3]
virtual double* vtkPVExtractHistogram2D::GetCustomBinRanges1 ( )
◆ GetCustomBinRanges1() [2/3]
virtual void vtkPVExtractHistogram2D::GetCustomBinRanges1 ( double &  ,
double &
◆ GetCustomBinRanges1() [3/3]
virtual void vtkPVExtractHistogram2D::GetCustomBinRanges1 ( double  [2])
◆ SetUseCustomBinRanges0()
virtual void vtkPVExtractHistogram2D::SetUseCustomBinRanges0 ( bool  )
◆ GetUseCustomBinRanges0()
virtual bool vtkPVExtractHistogram2D::GetUseCustomBinRanges0 ( )
◆ UseCustomBinRanges0On()
virtual void vtkPVExtractHistogram2D::UseCustomBinRanges0On ( )
◆ UseCustomBinRanges0Off()
virtual void vtkPVExtractHistogram2D::UseCustomBinRanges0Off ( )
◆ SetUseCustomBinRanges1()
virtual void vtkPVExtractHistogram2D::SetUseCustomBinRanges1 ( bool  )
◆ GetUseCustomBinRanges1()
virtual bool vtkPVExtractHistogram2D::GetUseCustomBinRanges1 ( )
◆ UseCustomBinRanges1On()
virtual void vtkPVExtractHistogram2D::UseCustomBinRanges1On ( )
◆ UseCustomBinRanges1Off()
virtual void vtkPVExtractHistogram2D::UseCustomBinRanges1Off ( )
◆ SetUseGradientForYAxis()
virtual void vtkPVExtractHistogram2D::SetUseGradientForYAxis ( bool  )
◆ GetUseGradientForYAxis()
virtual bool vtkPVExtractHistogram2D::GetUseGradientForYAxis ( )
◆ UseGradientForYAxisOn()
virtual void vtkPVExtractHistogram2D::UseGradientForYAxisOn ( )
◆ UseGradientForYAxisOff()
virtual void vtkPVExtractHistogram2D::UseGradientForYAxisOff ( )
◆ SetUseInputRangesForOutputBounds()
virtual void vtkPVExtractHistogram2D::SetUseInputRangesForOutputBounds ( bool  )
This means that if the input data array ranges are [r1min, r1max] and [r2min, r2max], the output histogram image would have bounds [r1min, r1max, r2min, r2max, 0, 0], when this flag is enabled. The output spacing is determined based on these bounds and the number of bins.
See also
SetNumberOfBins(), SetOutputSpacing(), SetOutputOrigin()
◆ GetUseInputRangesForOutputBounds()
virtual bool vtkPVExtractHistogram2D::GetUseInputRangesForOutputBounds ( )
See also
◆ UseInputRangesForOutputBoundsOn()
virtual void vtkPVExtractHistogram2D::UseInputRangesForOutputBoundsOn ( )
See also
◆ UseInputRangesForOutputBoundsOff()
virtual void vtkPVExtractHistogram2D::UseInputRangesForOutputBoundsOff ( )
See also
◆ SetOutputOrigin() [1/2]
virtual void vtkPVExtractHistogram2D::SetOutputOrigin ( double  ,
double
Note
This is only used if UseInputRangesForOutputBounds is disabled.
See also
◆ SetOutputOrigin() [2/2]
void vtkPVExtractHistogram2D::SetOutputOrigin ( double  [2])
Note
See also
◆ GetOutputOrigin() [1/3]
virtual double* vtkPVExtractHistogram2D::GetOutputOrigin ( )
Note
See also
◆ GetOutputOrigin() [2/3]
virtual void vtkPVExtractHistogram2D::GetOutputOrigin ( double &  ,
double &
Note
See also
◆ GetOutputOrigin() [3/3]
virtual void vtkPVExtractHistogram2D::GetOutputOrigin ( double  [2])
Note
See also
◆ SetOutputSpacing() [1/2]
virtual void vtkPVExtractHistogram2D::SetOutputSpacing ( double  ,
double
Note
See also
◆ SetOutputSpacing() [2/2]
void vtkPVExtractHistogram2D::SetOutputSpacing ( double  [2])
Note
See also
◆ GetOutputSpacing() [1/3]
virtual double* vtkPVExtractHistogram2D::GetOutputSpacing ( )
Note
See also
◆ GetOutputSpacing() [2/3]
virtual void vtkPVExtractHistogram2D::GetOutputSpacing ( double &  ,
double &
Note
See also
◆ GetOutputSpacing() [3/3]
virtual void vtkPVExtractHistogram2D::GetOutputSpacing ( double  [2])
Note
See also
◆ RequestData()
int vtkPVExtractHistogram2D::RequestData ( vtkInformation *  request,
overrideprotectedvirtual
◆ RequestInformation()
int vtkPVExtractHistogram2D::RequestInformation ( vtkInformation *  request,
◆ RequestUpdateExtent()
int vtkPVExtractHistogram2D::RequestUpdateExtent ( vtkInformation *  request,
◆ FillInputPortInformation()
int vtkPVExtractHistogram2D::FillInputPortInformation ( int  port,
vtkInformation *  info
◆ ComputeHistogram2D()
void vtkPVExtractHistogram2D::ComputeHistogram2D ( vtkImageData *  histogram)
◆ ComputeGradient()
void vtkPVExtractHistogram2D::ComputeGradient ( vtkDataObject *  input)
◆ InitializeCache()
void vtkPVExtractHistogram2D::InitializeCache ( )
◆ GetInputArrays()
void vtkPVExtractHistogram2D::GetInputArrays ( vtkInformationVector **  )
◆ ComputeVectorMagnitude()
void vtkPVExtractHistogram2D::ComputeVectorMagnitude ( vtkDataArray *  ,
vtkDataArray *&
◆ ComputeComponentRange()
void vtkPVExtractHistogram2D::ComputeComponentRange ( )
◆ Component0
int vtkPVExtractHistogram2D::Component0 = 0
Definition at line 138 of file vtkPVExtractHistogram2D.h.
◆ Component1
int vtkPVExtractHistogram2D::Component1 = 0
Definition at line 139 of file vtkPVExtractHistogram2D.h.
◆ NumberOfBins
int vtkPVExtractHistogram2D::NumberOfBins[2] = { 256, 256 }
Definition at line 140 of file vtkPVExtractHistogram2D.h.
bool vtkPVExtractHistogram2D::UseGradientForYAxis = false
Definition at line 141 of file vtkPVExtractHistogram2D.h.
◆ CustomBinRanges0
double vtkPVExtractHistogram2D::CustomBinRanges0[2]
Definition at line 143 of file vtkPVExtractHistogram2D.h.
◆ CustomBinRanges1
double vtkPVExtractHistogram2D::CustomBinRanges1[2]
Definition at line 144 of file vtkPVExtractHistogram2D.h.
bool vtkPVExtractHistogram2D::UseCustomBinRanges0 = false
Definition at line 145 of file vtkPVExtractHistogram2D.h.
bool vtkPVExtractHistogram2D::UseCustomBinRanges1 = false
Definition at line 146 of file vtkPVExtractHistogram2D.h.
◆ Controller
vtkMultiProcessController* vtkPVExtractHistogram2D::Controller = nullptr
Definition at line 147 of file vtkPVExtractHistogram2D.h.
bool vtkPVExtractHistogram2D::UseInputRangesForOutputBounds = true
Definition at line 148 of file vtkPVExtractHistogram2D.h.
◆ OutputOrigin
double vtkPVExtractHistogram2D::OutputOrigin[2] = { 0.0, 0.0 }
Definition at line 149 of file vtkPVExtractHistogram2D.h.
◆ OutputSpacing
double vtkPVExtractHistogram2D::OutputSpacing[2] = { 1.0, 1.0 }
Definition at line 150 of file vtkPVExtractHistogram2D.h.
◆ ComponentIndexCache
int vtkPVExtractHistogram2D::ComponentIndexCache[2]
Definition at line 153 of file vtkPVExtractHistogram2D.h.
◆ ComponentArrayCache
vtkDataArray* vtkPVExtractHistogram2D::ComponentArrayCache[2]
Definition at line 154 of file vtkPVExtractHistogram2D.h.
◆ GhostArray
vtkUnsignedCharArray* vtkPVExtractHistogram2D::GhostArray
Definition at line 155 of file vtkPVExtractHistogram2D.h.
◆ GhostsToSkip
unsigned char vtkPVExtractHistogram2D::GhostsToSkip
Definition at line 156 of file vtkPVExtractHistogram2D.h.
◆ ComponentRangeCache
double vtkPVExtractHistogram2D::ComponentRangeCache[2][2]
Definition at line 157 of file vtkPVExtractHistogram2D.h.
