vtkPPhastaReader Class Reference
parallel Phasta meta-file reader vtkPPhastaReader reads XML based Phasta meta-files and the underlying Phasta files. The meta-file has the following form: More...
#include <vtkPPhastaReader.h>
Inheritance diagram for vtkPPhastaReader:
Collaboration diagram for vtkPPhastaReader:
typedef vtkMultiBlockDataSetAlgorithm Superclass
- Public Types inherited from vtkMultiBlockDataSetAlgorithm
enum  DesiredOutputPrecision
 Set and get the Phasta meta file name. More...
virtual char * GetFileName ()
virtual void SetTimeStepIndex (int)
 Set the step number for the geometry. More...
virtual int GetTimeStepIndex ()
virtual int * GetTimeStepRange ()
 The min and max values of timesteps. More...
virtual void GetTimeStepRange (int &, int &)
virtual void GetTimeStepRange (int[2])
- Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
vtkMultiBlockDataSetAlgorithm * NewInstance () const
vtkMultiBlockDataSet * GetOutput ()
vtkMultiBlockDataSet * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPPhastaReader * New ()
static vtkPPhastaReader * SafeDownCast (vtkObject *o)
static int CanReadFile (const char *filename)
- Static Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
static vtkMultiBlockDataSetAlgorithm * New ()
static vtkMultiBlockDataSetAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPPhastaReader ()
 ~vtkPPhastaReader () override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
- Protected Member Functions inherited from vtkMultiBlockDataSetAlgorithm
 vtkMultiBlockDataSetAlgorithm ()
 ~vtkMultiBlockDataSetAlgorithm ()
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
char * FileName
int TimeStepIndex
int TimeStepRange [2]
 Store the range of time steps. More...
vtkPhastaReader * Reader
vtkPVXMLParser * Parser
int ActualTimeStep
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
* <?xml version="1.0" ?>
* <PhastaMetaFile number_of_pieces="2">
*   <GeometryFileNamePattern pattern="geombc.dat.%d"
*                            has_piece_entry="1"
*                            has_time_entry="0"/>
*   <FieldFileNamePattern pattern="restart.%d.%d"
*                         has_time_entry="1"/>
*   <TimeSteps number_of_steps="2"
*              auto_generate_indices="1"
*              start_index="0"
*              increment_index_by="20"
*              start_value="0."
*              increment_value_by="20.">
*     <TimeStep index="0" geometry_index="" field_index="0" value="0.0"/>
*     <TimeStep index="1" geometry_index="" field_index="20" value="20.0"/>
*   </TimeSteps>
*   <Fields number_of_fields="2">
*     <Field paraview_field_tag="velocity"
*            phasta_field_tag="solution"
*            start_index_in_phasta_array="1"
*            number_of_componenets="3"
*            datadependency="0"
*            data_type="double"/>
*     <Field paraview_field_tag="average speed"
*            phasta_field_tag="ybar"
*            start_index_in_phasta_array="4"
*            number_of_componenets="1"/>
*   </Fields>
*</PhastaMetaFile>
The GeometryFileNamePattern and FieldFileNamePattern elements have three attributes:
The TimeSteps element contains TimeStep sub-elements. Each TimeStep element specifies an index (index attribute), an index used in the geometry filename pattern (geometry_index), an index used in the field filename pattern (field_index) and a time value (float). In the example above, there are two timesteps. The first one is stored in files named geombc.dat.(0,1), restart.(0,20).(0,1). The time placeholders are substituted with the the geometry_index and field_index attribute values.
Normally there is one TimeStep element per timestep. However, it is possible to ask the reader to automatically generate timestep entries. This is done with setting the (optional) auto_generate_indices to 1. In this case, the reader will generate number_of_steps entries. The geometry_index and field_index of these entries will start at start_index and will be incremented by increment_index_by. The time value of these entries will start at start_value and will be incremented by increment_value_by. Note that it is possible to use a combination of both approaches. Any values specified with the TimeStep elements will overwrite anything automatically computed. A common use of this is to let the reader compute all indices for field files and overwrite the geometry indices with TimeStep elements.
The Fields element contain number_of_fields Field sub-element. Each Field element specifies tag attribute to be used in paraview, tag under which the field is stored in phasta files, start index of the array in phasta files, number of components of the field, data dependency, i.e., either 0 for nodal or 1 for elemental and data type, i.e., "double" (as of now supports only 1, 3 & 9 for number of components, i.e., scalars, vectors & tensors, and "double" for type of data). In the example above, there are two fields to be visualized one is velocity field stored under tag solution from index 1 to 3 in phasta files which is a vector field defined on nodes with double values, and the other field is average speed scalar field stored under tag ybar at index 4 in phasta files If any Field element is specified then default attribute values are : (phasta_field_tag is mandatory) paraview_field_tag = Field <number> start_index_in_phasta_array = 0 number_of_components = 1 data_dependency = 0 data_type = double If no Field(s) is/are specified then the default is following 3 fields : pressure (index 0 under solution), velocity (index 1-3 under solution) temperature (index 4 under soltuion)
See also
vtkPhastaReader
Definition at line 119 of file vtkPPhastaReader.h.
Definition at line 123 of file vtkPPhastaReader.h.
◆ vtkPPhastaReader()
vtkPPhastaReader::vtkPPhastaReader ( )
◆ ~vtkPPhastaReader()
vtkPPhastaReader::~vtkPPhastaReader ( )
static vtkPPhastaReader* vtkPPhastaReader::New ( )
virtual const char* vtkPPhastaReader::GetClassName ( )
static int vtkPPhastaReader::IsTypeOf ( const char *  type)
virtual int vtkPPhastaReader::IsA ( const char *  type)
Reimplemented from vtkMultiBlockDataSetAlgorithm.
static vtkPPhastaReader* vtkPPhastaReader::SafeDownCast ( vtkObject *  o)
void vtkPPhastaReader::PrintSelf ( ostream &  os,
◆ SetFileName()
virtual void vtkPPhastaReader::SetFileName ( const char *  )
◆ GetFileName()
virtual char* vtkPPhastaReader::GetFileName ( )
◆ SetTimeStepIndex()
virtual void vtkPPhastaReader::SetTimeStepIndex ( int  )
◆ GetTimeStepIndex()
virtual int vtkPPhastaReader::GetTimeStepIndex ( )
◆ GetTimeStepRange() [1/3]
virtual int* vtkPPhastaReader::GetTimeStepRange ( )
◆ GetTimeStepRange() [2/3]
virtual void vtkPPhastaReader::GetTimeStepRange ( int &  ,
int &
◆ GetTimeStepRange() [3/3]
virtual void vtkPPhastaReader::GetTimeStepRange ( int  [2])
◆ CanReadFile()
static int vtkPPhastaReader::CanReadFile ( const char *  filename)
◆ RequestInformation()
int vtkPPhastaReader::RequestInformation ( vtkInformation *  request,
overrideprotectedvirtual
◆ RequestData()
int vtkPPhastaReader::RequestData ( vtkInformation *  request,
◆ FileName
char* vtkPPhastaReader::FileName
Definition at line 160 of file vtkPPhastaReader.h.
◆ TimeStepIndex
int vtkPPhastaReader::TimeStepIndex
Definition at line 162 of file vtkPPhastaReader.h.
◆ TimeStepRange
int vtkPPhastaReader::TimeStepRange[2]
Definition at line 167 of file vtkPPhastaReader.h.
◆ Reader
vtkPhastaReader* vtkPPhastaReader::Reader
Definition at line 169 of file vtkPPhastaReader.h.
◆ Parser
vtkPVXMLParser* vtkPPhastaReader::Parser
Definition at line 170 of file vtkPPhastaReader.h.
◆ ActualTimeStep
int vtkPPhastaReader::ActualTimeStep
Definition at line 172 of file vtkPPhastaReader.h.
