Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
vtkPGenericIOMultiBlockReader Class Reference
#include <vtkPGenericIOMultiBlockReader.h>
Inheritance diagram for vtkPGenericIOMultiBlockReader:
Collaboration diagram for vtkPGenericIOMultiBlockReader:
enum  IOType { IOTYPEMPI, IOTYPEPOSIX }
enum  BlockAssignment { ROUND_ROBIN, RCB }
typedef vtkMultiBlockDataSetAlgorithm Superclass
- Public Types inherited from vtkMultiBlockDataSetAlgorithm
enum  DesiredOutputPrecision
int GetNumberOfPointArrays ()
 Returns the number of arrays in the file, i.e., the number of columns. More...
const char * GetPointArrayName (int i)
 Returns the name of the ith array. More...
int GetPointArrayStatus (const char *name)
 Returns the status of the array corresponding to the given name. More...
void SetPointArrayStatus (const char *name, int status)
 Sets the status of the array corresponding to the given name. More...
vtkIdType GetRequestedHaloId (vtkIdType i)
 Gets the ith requested halo id. More...
vtkIdType GetNumberOfRequestedHaloIds ()
 Gets the number of requested halo ids. More...
void SetNumberOfRequestedHaloIds (vtkIdType numIds)
 Sets the number of requested halo ids. More...
void AddRequestedHaloId (vtkIdType haloId)
 Adds the given halo id to the list of halo ids to request. More...
void ClearRequestedHaloIds ()
 Clears the list of requested halo ids. More...
void SetRequestedHaloId (vtkIdType i, vtkIdType haloId)
 Sets the ith requested halo id to the given haloId. More...
virtual void SetXAxisVariableName (const char *)
 Set/Get the variable name to be used as the x-axis for plotting particles. More...
virtual char * GetXAxisVariableName ()
virtual void SetYAxisVariableName (const char *)
 Set/Get the variable name to be used as the y-axis for plotting particles. More...
virtual char * GetYAxisVariableName ()
virtual void SetZAxisVariableName (const char *)
 Set/Get the variable name to be used as the z-axis for plotting particles. More...
virtual char * GetZAxisVariableName ()
 Specify the name of the cosmology particle binary file to read. More...
virtual char * GetFileName ()
virtual void SetGenericIOType (int)
 Set/Get the underlying IO method the reader will employ, i.e., MPI or POSIX. More...
virtual int GetGenericIOType ()
virtual void SetBlockAssignment (int)
 Set/Get the underlying block-assignment strategy to use, i.e., ROUND_ROBIN, or RCB. More...
virtual int GetBlockAssignment ()
virtual vtkStringArray * GetArrayList ()
 Returns the list of arrays used to select the variables to be used for the x,y and z axis. More...
virtual vtkDataArraySelection * GetPointDataArraySelection ()
 Get the data array selection tables used to configure which data arrays are loaded by the reader. More...
 Set/Get a multiprocess-controller for reading in parallel. More...
virtual void SetController (vtkMultiProcessController *)
virtual void SetHaloIdVariableName (const char *)
 Gets/Sets the variable name for the halo id of the particle. More...
virtual char * GetHaloIdVariableName ()
- Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
vtkMultiBlockDataSetAlgorithm * NewInstance () const
vtkMultiBlockDataSet * GetOutput ()
vtkMultiBlockDataSet * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPGenericIOMultiBlockReader * New ()
static vtkPGenericIOMultiBlockReader * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
static vtkMultiBlockDataSetAlgorithm * New ()
static vtkMultiBlockDataSetAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPGenericIOMultiBlockReader ()
 ~vtkPGenericIOMultiBlockReader ()
gio::GenericIOReader * GetInternalReader ()
bool ReaderParametersChanged ()
void LoadMetaData ()
void LoadRawVariableDataForBlock (const std::string &varName, int blockId)
void LoadRawDataForBlock (int blockId)
void GetPointFromRawData (int xType, void *xBuffer, int yType, void *yBuffer, int zType, void *zBuffer, vtkIdType id, double point[3])
void LoadCoordinatesForBlock (vtkUnstructuredGrid *grid, std::set< vtkIdType > &pointsInSelectedHalos, int blockId)
void LoadDataArraysForBlock (vtkUnstructuredGrid *grid, const std::set< vtkIdType > &pointsInSelectedHalos, int blockId)
vtkUnstructuredGrid * LoadBlock (int blockId)
virtual int RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
- Protected Member Functions inherited from vtkMultiBlockDataSetAlgorithm
 vtkMultiBlockDataSetAlgorithm ()
 ~vtkMultiBlockDataSetAlgorithm ()
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
static void SelectionModifiedCallback (vtkObject *caller, unsigned long eid, void *clientdata, void *calldata)
 Call-back registered with the SelectionObserver. More...
char * XAxisVariableName
char * YAxisVariableName
char * ZAxisVariableName
char * HaloIdVariableName
char * FileName
int GenericIOType
int BlockAssignment
bool BuildMetaData
vtkStringArray * ArrayList
vtkDataArraySelection * PointDataArraySelection
vtkIdList * HaloList
vtkCallbackCommand * SelectionObserver
gio::GenericIOReader * Reader
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
Creates a vtkMultiBlockDataSet from a GenericIO file
Definition at line 33 of file vtkPGenericIOMultiBlockReader.h.
Definition at line 50 of file vtkPGenericIOMultiBlockReader.h.
◆ IOType
Enumerator
IOTYPEMPI
IOTYPEPOSIX
Definition at line 37 of file vtkPGenericIOMultiBlockReader.h.
◆ BlockAssignment
Enumerator
ROUND_ROBIN
RCB
Definition at line 43 of file vtkPGenericIOMultiBlockReader.h.
◆ vtkPGenericIOMultiBlockReader()
vtkPGenericIOMultiBlockReader::vtkPGenericIOMultiBlockReader ( )
◆ ~vtkPGenericIOMultiBlockReader()
vtkPGenericIOMultiBlockReader::~vtkPGenericIOMultiBlockReader ( )
static vtkPGenericIOMultiBlockReader* vtkPGenericIOMultiBlockReader::New ( )
virtual const char* vtkPGenericIOMultiBlockReader::GetClassName ( )
static int vtkPGenericIOMultiBlockReader::IsTypeOf ( const char *  type)
virtual int vtkPGenericIOMultiBlockReader::IsA ( const char *  type)
Reimplemented from vtkMultiBlockDataSetAlgorithm.
static vtkPGenericIOMultiBlockReader* vtkPGenericIOMultiBlockReader::SafeDownCast ( vtkObject *  o)
void vtkPGenericIOMultiBlockReader::PrintSelf ( ostream &  os,
◆ SetXAxisVariableName()
virtual void vtkPGenericIOMultiBlockReader::SetXAxisVariableName ( const char *  )
◆ GetXAxisVariableName()
virtual char* vtkPGenericIOMultiBlockReader::GetXAxisVariableName ( )
◆ SetYAxisVariableName()
virtual void vtkPGenericIOMultiBlockReader::SetYAxisVariableName ( const char *  )
◆ GetYAxisVariableName()
virtual char* vtkPGenericIOMultiBlockReader::GetYAxisVariableName ( )
◆ SetZAxisVariableName()
virtual void vtkPGenericIOMultiBlockReader::SetZAxisVariableName ( const char *  )
◆ GetZAxisVariableName()
virtual char* vtkPGenericIOMultiBlockReader::GetZAxisVariableName ( )
◆ SetFileName()
virtual void vtkPGenericIOMultiBlockReader::SetFileName ( const char *  )
◆ GetFileName()
virtual char* vtkPGenericIOMultiBlockReader::GetFileName ( )
◆ SetGenericIOType()
virtual void vtkPGenericIOMultiBlockReader::SetGenericIOType ( int  )
◆ GetGenericIOType()
virtual int vtkPGenericIOMultiBlockReader::GetGenericIOType ( )
◆ SetBlockAssignment()
virtual void vtkPGenericIOMultiBlockReader::SetBlockAssignment ( int  )
◆ GetBlockAssignment()
virtual int vtkPGenericIOMultiBlockReader::GetBlockAssignment ( )
◆ GetArrayList()
virtual vtkStringArray* vtkPGenericIOMultiBlockReader::GetArrayList ( )
◆ GetPointDataArraySelection()
virtual vtkDataArraySelection* vtkPGenericIOMultiBlockReader::GetPointDataArraySelection ( )
◆ GetController()
virtual vtkMultiProcessController* vtkPGenericIOMultiBlockReader::GetController ( )
By default this parameter is set to nullptr by the constructor.
◆ SetController()
virtual void vtkPGenericIOMultiBlockReader::SetController ( vtkMultiProcessController *  )
◆ GetNumberOfPointArrays()
int vtkPGenericIOMultiBlockReader::GetNumberOfPointArrays ( )
◆ GetPointArrayName()
const char* vtkPGenericIOMultiBlockReader::GetPointArrayName ( int  i)
◆ GetPointArrayStatus()
int vtkPGenericIOMultiBlockReader::GetPointArrayStatus ( const char *  name)
◆ SetPointArrayStatus()
void vtkPGenericIOMultiBlockReader::SetPointArrayStatus ( const char *  name,
int  status
◆ SetHaloIdVariableName()
virtual void vtkPGenericIOMultiBlockReader::SetHaloIdVariableName ( const char *  )
This is used by the requested halo selector to select only the points in the desired halos.
◆ GetHaloIdVariableName()
virtual char* vtkPGenericIOMultiBlockReader::GetHaloIdVariableName ( )
◆ GetRequestedHaloId()
vtkIdType vtkPGenericIOMultiBlockReader::GetRequestedHaloId ( vtkIdType  i)
If the number of requested halo ids is greater than 0, only points with those halo ids will be read in. Otherwise all points will be read in.
◆ GetNumberOfRequestedHaloIds()
vtkIdType vtkPGenericIOMultiBlockReader::GetNumberOfRequestedHaloIds ( )
◆ SetNumberOfRequestedHaloIds()
void vtkPGenericIOMultiBlockReader::SetNumberOfRequestedHaloIds ( vtkIdType  numIds)
Use SetRequestedHaloId() to se the ids after this is called If the number of requested halo ids is greater than 0, only points with those halo ids will be read in. Otherwise all points will be read in.
◆ AddRequestedHaloId()
void vtkPGenericIOMultiBlockReader::AddRequestedHaloId ( vtkIdType  haloId)
◆ ClearRequestedHaloIds()
void vtkPGenericIOMultiBlockReader::ClearRequestedHaloIds ( )
◆ SetRequestedHaloId()
void vtkPGenericIOMultiBlockReader::SetRequestedHaloId ( vtkIdType  i,
vtkIdType  haloId
◆ GetInternalReader()
gio::GenericIOReader* vtkPGenericIOMultiBlockReader::GetInternalReader ( )
◆ ReaderParametersChanged()
bool vtkPGenericIOMultiBlockReader::ReaderParametersChanged ( )
◆ LoadMetaData()
void vtkPGenericIOMultiBlockReader::LoadMetaData ( )
◆ LoadRawVariableDataForBlock()
void vtkPGenericIOMultiBlockReader::LoadRawVariableDataForBlock ( const std::string &  varName,
int  blockId
◆ LoadRawDataForBlock()
void vtkPGenericIOMultiBlockReader::LoadRawDataForBlock ( int  blockId)
◆ GetPointFromRawData()
void vtkPGenericIOMultiBlockReader::GetPointFromRawData ( int  xType,
void *  xBuffer,
int  yType,
void *  yBuffer,
int  zType,
void *  zBuffer,
vtkIdType  id,
double  point[3]
◆ LoadCoordinatesForBlock()
void vtkPGenericIOMultiBlockReader::LoadCoordinatesForBlock ( vtkUnstructuredGrid *  grid,
std::set< vtkIdType > &  pointsInSelectedHalos,
int  blockId
◆ LoadDataArraysForBlock()
void vtkPGenericIOMultiBlockReader::LoadDataArraysForBlock ( vtkUnstructuredGrid *  grid,
const std::set< vtkIdType > &  pointsInSelectedHalos,
int  blockId
◆ LoadBlock()
vtkUnstructuredGrid* vtkPGenericIOMultiBlockReader::LoadBlock ( int  blockId)
◆ SelectionModifiedCallback()
static void vtkPGenericIOMultiBlockReader::SelectionModifiedCallback ( vtkObject *  caller,
unsigned long  eid,
void *  clientdata,
void *  calldata
staticprotected
◆ RequestInformation()
virtual int vtkPGenericIOMultiBlockReader::RequestInformation ( vtkInformation *  ,
vtkInformationVector **  ,
protectedvirtual
◆ RequestData()
virtual int vtkPGenericIOMultiBlockReader::RequestData ( vtkInformation *  ,
protectedvirtual
◆ XAxisVariableName
char* vtkPGenericIOMultiBlockReader::XAxisVariableName
Definition at line 210 of file vtkPGenericIOMultiBlockReader.h.
◆ YAxisVariableName
char* vtkPGenericIOMultiBlockReader::YAxisVariableName
Definition at line 211 of file vtkPGenericIOMultiBlockReader.h.
◆ ZAxisVariableName
char* vtkPGenericIOMultiBlockReader::ZAxisVariableName
Definition at line 212 of file vtkPGenericIOMultiBlockReader.h.
◆ HaloIdVariableName
char* vtkPGenericIOMultiBlockReader::HaloIdVariableName
Definition at line 213 of file vtkPGenericIOMultiBlockReader.h.
◆ FileName
char* vtkPGenericIOMultiBlockReader::FileName
Definition at line 215 of file vtkPGenericIOMultiBlockReader.h.
◆ GenericIOType
int vtkPGenericIOMultiBlockReader::GenericIOType
Definition at line 216 of file vtkPGenericIOMultiBlockReader.h.
◆ BlockAssignment
Definition at line 217 of file vtkPGenericIOMultiBlockReader.h.
◆ BuildMetaData
bool vtkPGenericIOMultiBlockReader::BuildMetaData
Definition at line 219 of file vtkPGenericIOMultiBlockReader.h.
◆ Controller
vtkMultiProcessController* vtkPGenericIOMultiBlockReader::Controller
Definition at line 221 of file vtkPGenericIOMultiBlockReader.h.
◆ ArrayList
vtkStringArray* vtkPGenericIOMultiBlockReader::ArrayList
Definition at line 223 of file vtkPGenericIOMultiBlockReader.h.
◆ PointDataArraySelection
vtkDataArraySelection* vtkPGenericIOMultiBlockReader::PointDataArraySelection
Definition at line 224 of file vtkPGenericIOMultiBlockReader.h.
◆ HaloList
vtkIdList* vtkPGenericIOMultiBlockReader::HaloList
Definition at line 225 of file vtkPGenericIOMultiBlockReader.h.
◆ SelectionObserver
vtkCallbackCommand* vtkPGenericIOMultiBlockReader::SelectionObserver
Definition at line 226 of file vtkPGenericIOMultiBlockReader.h.
◆ Reader
gio::GenericIOReader* vtkPGenericIOMultiBlockReader::Reader
Definition at line 228 of file vtkPGenericIOMultiBlockReader.h.
