vtkMultiProcessControllerHelper Class Reference
collection of assorted helper routines dealing with communication. More...
#include <vtkMultiProcessControllerHelper.h>
Inheritance diagram for vtkMultiProcessControllerHelper:
Collaboration diagram for vtkMultiProcessControllerHelper:
static vtkMultiProcessControllerHelper * New ()
static vtkMultiProcessControllerHelper * SafeDownCast (vtkObject *o)
static int ReduceToAll (vtkMultiProcessController *controller, vtkMultiProcessStream &data, void(*operation)(vtkMultiProcessStream &A, vtkMultiProcessStream &B), int tag)
 Reduce the stream to all processes calling the (*operation) for reduction. More...
static vtkDataObject * MergePieces (vtkDataObject **pieces, unsigned int num_pieces)
 Utility method to merge pieces received from several processes. More...
static bool MergePieces (std::vector< vtkSmartPointer< vtkDataObject >> &pieces, vtkDataObject *result)
 Overload where the merged pieces are combined into result. More...
 vtkMultiProcessControllerHelper ()
 ~vtkMultiProcessControllerHelper () override
vtkMultiProcessControllerHelper is collection of assorted helper routines dealing with communication.
Definition at line 25 of file vtkMultiProcessControllerHelper.h.
Definition at line 29 of file vtkMultiProcessControllerHelper.h.
◆ vtkMultiProcessControllerHelper()
vtkMultiProcessControllerHelper::vtkMultiProcessControllerHelper ( )
◆ ~vtkMultiProcessControllerHelper()
vtkMultiProcessControllerHelper::~vtkMultiProcessControllerHelper ( )
static vtkMultiProcessControllerHelper* vtkMultiProcessControllerHelper::New ( )
virtual const char* vtkMultiProcessControllerHelper::GetClassName ( )
static int vtkMultiProcessControllerHelper::IsTypeOf ( const char *  type)
virtual int vtkMultiProcessControllerHelper::IsA ( const char *  type)
static vtkMultiProcessControllerHelper* vtkMultiProcessControllerHelper::SafeDownCast ( vtkObject *  o)
void vtkMultiProcessControllerHelper::PrintSelf ( ostream &  os,
◆ ReduceToAll()
static int vtkMultiProcessControllerHelper::ReduceToAll ( vtkMultiProcessController *  controller,
vtkMultiProcessStream &  data,
void(*)(vtkMultiProcessStream &A, vtkMultiProcessStream &B)  operation,
int  tag
The operation is assumed to be commutative.
◆ MergePieces() [1/2]
static vtkDataObject* vtkMultiProcessControllerHelper::MergePieces ( vtkDataObject **  pieces,
It does not handle all data types, and hence not meant for non-paraview specific use. Returns a new instance of data object containing the merged result on success, else returns nullptr. The caller is expected to release the memory from the returned data-object.
◆ MergePieces() [2/2]
static bool vtkMultiProcessControllerHelper::MergePieces ( std::vector< vtkSmartPointer< vtkDataObject >> &  pieces,
vtkDataObject *  result
