vtkMetaReader Class Reference
Common functionality for meta-readers. More...
#include <vtkMetaReader.h>
Inheritance diagram for vtkMetaReader:
Collaboration diagram for vtkMetaReader:
enum  DesiredOutputPrecision
 vtkMetaReader ()
 ~vtkMetaReader () override
vtkMTimeType GetMTime () override
 Return the MTime when also considering the internal reader. More...
virtual void SetReader (vtkAlgorithm *)
 Set/get the internal reader. More...
virtual vtkAlgorithm * GetReader ()
void SetMetaFileName (const char *name)
 Get/set the filename for the meta-file. More...
char * GetMetaFileName ()
virtual vtkIdType * GetFileIndexRange ()
 Returns the available range of file indexes. More...
virtual void GetFileIndexRange (vtkIdType &, vtkIdType &)
virtual void GetFileIndexRange (vtkIdType[2])
vtkIdType GetFileIndex ()
 Get/set the index of the file to read. More...
void SetFileIndex (vtkIdType i)
virtual void SetFileNameMethod (const char *)
 Name of the method used to set the file name of the internal reader. More...
virtual char * GetFileNameMethod ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkMetaReader * New ()
static vtkMetaReader * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
virtual void Set_MetaFileName (const char *)
virtual char * Get_MetaFileName ()
virtual void Set_FileIndex (vtkIdType)
virtual vtkIdType Get_FileIndex ()
void ReaderSetFileName (const char *filename)
int ReaderCanReadFile (const char *filename)
std::string FromRelativeToMetaFile (const char *metaFileName, const char *fileName)
 'metaFileName' to either a file path that is relative to the current working directory (CWD) or to an absolute file path. More...
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
virtual int RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkAlgorithm * Reader
vtkMTimeType FileNameMTime
vtkMTimeType BeforeFileNameMTime
char * FileNameMethod
vtkIdType _FileIndex
vtkMTimeType FileIndexMTime
vtkIdType FileIndexRange [2]
char * _MetaFileName
vtkMTimeType MetaFileNameMTime
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkTimeStamp MetaFileReadTime
 Records the time when the meta-file was read. More...
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
to another Reader. The Reader reads from a file selected from a list of files using a FileIndex.
Definition at line 21 of file vtkMetaReader.h.
Definition at line 25 of file vtkMetaReader.h.
◆ vtkMetaReader()
vtkMetaReader::vtkMetaReader ( )
◆ ~vtkMetaReader()
vtkMetaReader::~vtkMetaReader ( )
override
static vtkMetaReader* vtkMetaReader::New ( )
virtual const char* vtkMetaReader::GetClassName ( )
static int vtkMetaReader::IsTypeOf ( const char *  type)
virtual int vtkMetaReader::IsA ( const char *  type)
static vtkMetaReader* vtkMetaReader::SafeDownCast ( vtkObject *  o)
◆ SetReader()
virtual void vtkMetaReader::SetReader ( vtkAlgorithm *  )
◆ GetReader()
virtual vtkAlgorithm* vtkMetaReader::GetReader ( )
◆ SetMetaFileName()
void vtkMetaReader::SetMetaFileName ( const char *  name)
inline
Description: Get/Set the meta-file name
Definition at line 44 of file vtkMetaReader.h.
◆ GetMetaFileName()
char* vtkMetaReader::GetMetaFileName ( )
inline
Definition at line 49 of file vtkMetaReader.h.
◆ GetFileIndexRange() [1/3]
virtual vtkIdType* vtkMetaReader::GetFileIndexRange ( )
It is 0, ..., GetNumberOfFiles () - 1.
◆ GetFileIndexRange() [2/3]
virtual void vtkMetaReader::GetFileIndexRange ( vtkIdType &  ,
vtkIdType &
◆ GetFileIndexRange() [3/3]
virtual void vtkMetaReader::GetFileIndexRange ( vtkIdType  [2])
◆ GetFileIndex()
vtkIdType vtkMetaReader::GetFileIndex ( )
inline
Definition at line 64 of file vtkMetaReader.h.
◆ SetFileIndex()
void vtkMetaReader::SetFileIndex ( vtkIdType  i)
inline
Definition at line 65 of file vtkMetaReader.h.
◆ GetMTime()
vtkMTimeType vtkMetaReader::GetMTime ( )
◆ SetFileNameMethod()
virtual void vtkMetaReader::SetFileNameMethod ( const char *  )
By default, this is SetFileName.
◆ GetFileNameMethod()
virtual char* vtkMetaReader::GetFileNameMethod ( )
void vtkMetaReader::PrintSelf ( ostream &  os,
◆ FillOutputPortInformation()
int vtkMetaReader::FillOutputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ Set_MetaFileName()
virtual void vtkMetaReader::Set_MetaFileName ( const char *  )
protectedvirtual
◆ Get_MetaFileName()
virtual char* vtkMetaReader::Get_MetaFileName ( )
protectedvirtual
◆ Set_FileIndex()
virtual void vtkMetaReader::Set_FileIndex ( vtkIdType  )
protectedvirtual
◆ Get_FileIndex()
virtual vtkIdType vtkMetaReader::Get_FileIndex ( )
protectedvirtual
◆ ReaderSetFileName()
void vtkMetaReader::ReaderSetFileName ( const char *  filename)
◆ ReaderCanReadFile()
int vtkMetaReader::ReaderCanReadFile ( const char *  filename)
◆ FromRelativeToMetaFile()
std::string vtkMetaReader::FromRelativeToMetaFile ( const char *  metaFileName,
const char *  fileName
The choice is made based on if 'metaFileName' is relative or absolute. Return the original if 'fileName' is already absolute.
◆ Reader
vtkAlgorithm* vtkMetaReader::Reader
Definition at line 109 of file vtkMetaReader.h.
◆ FileNameMTime
vtkMTimeType vtkMetaReader::FileNameMTime
Definition at line 112 of file vtkMetaReader.h.
◆ BeforeFileNameMTime
vtkMTimeType vtkMetaReader::BeforeFileNameMTime
Definition at line 115 of file vtkMetaReader.h.
◆ FileNameMethod
char* vtkMetaReader::FileNameMethod
Definition at line 117 of file vtkMetaReader.h.
◆ _FileIndex
vtkIdType vtkMetaReader::_FileIndex
Definition at line 119 of file vtkMetaReader.h.
◆ FileIndexMTime
vtkMTimeType vtkMetaReader::FileIndexMTime
Definition at line 120 of file vtkMetaReader.h.
◆ FileIndexRange
vtkIdType vtkMetaReader::FileIndexRange[2]
Definition at line 122 of file vtkMetaReader.h.
◆ _MetaFileName
char* vtkMetaReader::_MetaFileName
Definition at line 125 of file vtkMetaReader.h.
◆ MetaFileNameMTime
vtkMTimeType vtkMetaReader::MetaFileNameMTime
Definition at line 127 of file vtkMetaReader.h.
◆ MetaFileReadTime
vtkTimeStamp vtkMetaReader::MetaFileReadTime
Definition at line 132 of file vtkMetaReader.h.
