#include <vtkMaterialInterfaceProcessRing.h>
| vtkMaterialInterfaceProcessRing () | |
| ~vtkMaterialInterfaceProcessRing () | |
| void | Clear () |
| Return the object to an empty state. More... | |
| void | Initialize (int nProcs) |
| Size buffer and point to first element. More... | |
| void | Initialize (std::vector< vtkMaterialInterfaceProcessLoading > &Q, vtkIdType upperLoadingBound) |
| Build from a process loading from a sorted vector of process loading items. More... | |
| vtkIdType | GetNextId () |
| Get the next process id from the ring. More... | |
| void | Print () |
| Print the state of the ring. More... | |
Data structure used to distribute work amongst available processes. The buffer can be initialized from a process priority queue such that only those processes with loading less than a specified tolerance are included.
Definition at line 20 of file vtkMaterialInterfaceProcessRing.h.
| vtkMaterialInterfaceProcessRing::vtkMaterialInterfaceProcessRing | ( | ) |
| vtkMaterialInterfaceProcessRing::~vtkMaterialInterfaceProcessRing | ( | ) |
| void vtkMaterialInterfaceProcessRing::Clear | ( | ) |
| void vtkMaterialInterfaceProcessRing::Initialize | ( | int | nProcs | ) |
| void vtkMaterialInterfaceProcessRing::Initialize | ( | std::vector< vtkMaterialInterfaceProcessLoading > & | Q, |
| vtkIdType | upperLoadingBound | ||
| vtkIdType vtkMaterialInterfaceProcessRing::GetNextId | ( | ) |
| void vtkMaterialInterfaceProcessRing::Print | ( | ) |
