vtkMaterialInterfaceFilter Class Reference
Extract particles and analyse them. More...
#include <vtkMaterialInterfaceFilter.h>
Inheritance diagram for vtkMaterialInterfaceFilter:
Collaboration diagram for vtkMaterialInterfaceFilter:
typedef vtkMultiBlockDataSetAlgorithm Superclass
- Public Types inherited from vtkMultiBlockDataSetAlgorithm
enum  DesiredOutputPrecision
void SelectMaterialArray (const char *name)
 Material sellection. More...
void UnselectMaterialArray (const char *name)
 remove a single array More...
void UnselectAllMaterialArrays ()
 remove all arrays More...
void SetMaterialArrayStatus (const char *name, int status)
 Enable/disable processing on an array. More...
int GetNumberOfMaterialArrays ()
 Query the number of available arrays. More...
const char * GetMaterialArrayName (int index)
 Get the name of a specific array. More...
void SelectMassArray (const char *name)
 Mass sellection. More...
void UnselectMassArray (const char *name)
void UnselectAllMassArrays ()
void SetMassArrayStatus (const char *name, int status)
int GetNumberOfMassArrays ()
const char * GetMassArrayName (int index)
void SelectVolumeWtdAvgArray (const char *name)
 Volume weighted average attribute sellection. More...
void UnselectVolumeWtdAvgArray (const char *name)
void UnselectAllVolumeWtdAvgArrays ()
void SetVolumeWtdAvgArrayStatus (const char *name, int status)
int GetNumberOfVolumeWtdAvgArrays ()
const char * GetVolumeWtdAvgArrayName (int index)
void SelectMassWtdAvgArray (const char *name)
 Mass weighted average attribute sellection. More...
void UnselectMassWtdAvgArray (const char *name)
void UnselectAllMassWtdAvgArrays ()
void SetMassWtdAvgArrayStatus (const char *name, int status)
int GetNumberOfMassWtdAvgArrays ()
const char * GetMassWtdAvgArrayName (int index)
void SelectSummationArray (const char *name)
 Summation attribute sellection. More...
void UnselectSummationArray (const char *name)
void UnselectAllSummationArrays ()
void SetSummationArrayStatus (const char *name, int status)
int GetNumberOfSummationArrays ()
const char * GetSummationArrayName (int index)
vtkMTimeType GetMTime () override
 Return the mtime also considering the locator and clip function. More...
int GetMaterialArrayStatus (const char *name)
 Get enable. More...
int GetMaterialArrayStatus (int index)
 Get enable. More...
int GetMassArrayStatus (const char *name)
 Get enable. More...
int GetMassArrayStatus (int index)
 Get enable. More...
int GetVolumeWtdAvgArrayStatus (const char *name)
 Get enable. More...
int GetVolumeWtdAvgArrayStatus (int index)
 Get enable. More...
int GetMassWtdAvgArrayStatus (const char *name)
 Get enable. More...
int GetMassWtdAvgArrayStatus (int index)
 Get enable. More...
int GetSummationArrayStatus (const char *name)
 Get enable. More...
int GetSummationArrayStatus (int index)
 Get enable. More...
void SetMaterialFractionThreshold (double fraction)
 Volume Fraction. More...
virtual double GetMaterialFractionThreshold ()
virtual void SetComputeOBB (bool)
 OBB. More...
virtual bool GetComputeOBB ()
 OBB. More...
void SetUpperLoadingBound (int nPolys)
 Loading. More...
virtual int GetUpperLoadingBound ()
 Loading. More...
virtual void SetOutputBaseName (const char *)
 Output file. More...
virtual char * GetOutputBaseName ()
virtual void SetWriteGeometryOutput (bool)
 If true, save the results of the filter in a text file. More...
virtual bool GetWriteGeometryOutput ()
virtual void SetWriteStatisticsOutput (bool)
virtual bool GetWriteStatisticsOutput ()
virtual void SetBlockGhostLevel (unsigned char)
 Variable used to specify the number of ghost level is available in each block. More...
virtual unsigned char GetBlockGhostLevel ()
void SetClipFunction (vtkImplicitFunction *clipFunction)
 Set the clip function which can be a plane or a sphere. More...
virtual vtkImplicitFunction * GetClipFunction ()
virtual void SetInvertVolumeFraction (int)
 Invert the volume fraction to extract the negative space. More...
virtual int GetInvertVolumeFraction ()
- Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
vtkMultiBlockDataSetAlgorithm * NewInstance () const
vtkMultiBlockDataSet * GetOutput ()
vtkMultiBlockDataSet * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkMaterialInterfaceFilter * New ()
static vtkMaterialInterfaceFilter * SafeDownCast (vtkObject *o)
static void SelectionModifiedCallback (vtkObject *, unsigned long, void *clientdata, void *)
 Sets modified if array selection changes. More...
- Static Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
static vtkMultiBlockDataSetAlgorithm * New ()
static vtkMultiBlockDataSetAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkMaterialInterfaceFilter ()
 ~vtkMaterialInterfaceFilter () override
void PrepareForPass (vtkNonOverlappingAMR *hbdsInput, std::vector< std::string > &volumeWtdAvgArrayNames, std::vector< std::string > &massWtdAvgArrayNames, std::vector< std::string > &summedArrayNames, std::vector< std::string > &integratedArrayNames)
vtkPolyData * NewFragmentMesh ()
int ProcessBlock (int blockId)
void ConnectFragment (vtkMaterialInterfaceFilterRingBuffer *iterator)
void GetNeighborIterator (vtkMaterialInterfaceFilterIterator *next, vtkMaterialInterfaceFilterIterator *iterator, int axis0, int maxFlag0, int axis1, int maxFlag1, int axis2, int maxFlag2)
void GetNeighborIteratorPad (vtkMaterialInterfaceFilterIterator *next, vtkMaterialInterfaceFilterIterator *iterator, int axis0, int maxFlag0, int axis1, int maxFlag1, int axis2, int maxFlag2)
void CreateFace (vtkMaterialInterfaceFilterIterator *in, vtkMaterialInterfaceFilterIterator *out, int axis, int outMaxFlag)
int ComputeDisplacementFactors (vtkMaterialInterfaceFilterIterator *pointNeighborIterators[8], double displacmentFactors[3], int rootNeighborIdx, int faceAxis)
int SubVoxelPositionCorner (double *point, vtkMaterialInterfaceFilterIterator *pointNeighborIterators[8], int rootNeighborIdx, int faceAxis)
void FindPointNeighbors (vtkMaterialInterfaceFilterIterator *iteratorMin0, vtkMaterialInterfaceFilterIterator *iteratorMax0, int axis0, int maxFlag1, int maxFlag2, vtkMaterialInterfaceFilterIterator pointNeighborIterators[8], double pt[3])
int ComputeOriginAndRootSpacingOld (vtkNonOverlappingAMR *input)
void ComputeOriginAndRootSpacing (vtkNonOverlappingAMR *input)
int GetNumberOfLocalBlocks (vtkNonOverlappingAMR *input)
void ShareGhostBlocks ()
void HandleGhostBlockRequests ()
int ComputeRequiredGhostExtent (int level, int inExt[6], int outExt[6])
void ComputeAndDistributeGhostBlocks (int *numBlocksInProc, int *blockMetaData, int myProc, int numProcs)
void AddEquivalence (vtkMaterialInterfaceFilterIterator *neighbor1, vtkMaterialInterfaceFilterIterator *neighbor2)
void PrepareForResolveEquivalences ()
void ResolveEquivalences ()
void GatherEquivalenceSets (vtkMaterialInterfaceEquivalenceSet *set)
void ShareGhostEquivalences (vtkMaterialInterfaceEquivalenceSet *globalSet, int *procOffsets)
void ReceiveGhostFragmentIds (vtkMaterialInterfaceEquivalenceSet *globalSet, int *procOffset)
void MergeGhostEquivalenceSets (vtkMaterialInterfaceEquivalenceSet *globalSet)
int ResolveIntegratedAttributes (int controllingProcId)
int PrepareToResolveIntegratedAttributes ()
int SendIntegratedAttributes (int recipientProcId)
int ReceiveIntegratedAttributes (int sourceProcId)
int PrepareToCollectIntegratedAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray * > &volumes, std::vector< vtkDoubleArray * > &clipDepthMaxs, std::vector< vtkDoubleArray * > &clipDepthMins, std::vector< vtkDoubleArray * > &moments, std::vector< std::vector< vtkDoubleArray * >> &volumeWtdAvgs, std::vector< std::vector< vtkDoubleArray * >> &massWtdAvgs, std::vector< std::vector< vtkDoubleArray * >> &sums)
int CleanUpAfterCollectIntegratedAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray * > &volumes, std::vector< vtkDoubleArray * > &clipDepthMaxs, std::vector< vtkDoubleArray * > &clipDepthMins, std::vector< vtkDoubleArray * > &moments, std::vector< std::vector< vtkDoubleArray * >> &volumeWtdAvgs, std::vector< std::vector< vtkDoubleArray * >> &massWtdAvgs, std::vector< std::vector< vtkDoubleArray * >> &sums)
int CollectIntegratedAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray * > &volumes, std::vector< vtkDoubleArray * > &clipDepthMaxs, std::vector< vtkDoubleArray * > &clipDepthMins, std::vector< vtkDoubleArray * > &moments, std::vector< std::vector< vtkDoubleArray * >> &volumeWtdAvgs, std::vector< std::vector< vtkDoubleArray * >> &massWtdAvgs, std::vector< std::vector< vtkDoubleArray * >> &sums)
int BroadcastIntegratedAttributes (int sourceProcessId)
int SendGeometricAttributes (int controllingProcId)
int PrepareToCollectGeometricAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray * > &coaabb, std::vector< vtkDoubleArray * > &obb, std::vector< int * > &ids)
int CleanUpAfterCollectGeometricAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray * > &coaabb, std::vector< vtkDoubleArray * > &obb, std::vector< int * > &ids)
int CollectGeometricAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray * > &coaabb, std::vector< vtkDoubleArray * > &obb, std::vector< int * > &ids)
int PrepareToMergeGeometricAttributes ()
int GatherGeometricAttributes (int recipientProcId)
void ResolveLocalFragmentGeometry ()
void ResolveRemoteFragmentGeometry ()
void CleanLocalFragmentGeometry ()
void BuildLoadingArray (std::vector< vtkIdType > &loadingArray)
int PackLoadingArray (vtkIdType *&buffer)
int UnPackLoadingArray (vtkIdType *buffer, int bufSize, std::vector< vtkIdType > &loadingArray)
void CopyAttributesToOutput0 ()
void CopyAttributesToOutput1 ()
void CopyAttributesToOutput2 ()
int WriteGeometryOutputToTextFile ()
int WriteStatisticsOutputToTextFile ()
int BuildOutputs (vtkMultiBlockDataSet *mbdsOutput0, vtkMultiBlockDataSet *mbdsOutput1, vtkMultiBlockDataSet *mbdsOutput2, int materialId)
int Accumulate (double *dest, vtkDataArray *src, int nComps, int srcCellIndex, double weight)
int AccumulateMoments (double *moments, vtkDataArray *massArray, int srcCellIndex, double *X)
void ComputeGeometricAttributes ()
int ComputeLocalFragmentOBB ()
int ComputeLocalFragmentAABBCenters ()
void DeleteAllBlocks ()
int InitializeBlocks (vtkNonOverlappingAMR *input, std::string &materialFractionArrayName, std::string &massArrayName, std::vector< std::string > &volumeWtdAvgArrayNames, std::vector< std::string > &massWtdAvgArrayNames, std::vector< std::string > &summedArrayNames, std::vector< std::string > &integratedArrayNames)
void AddBlock (vtkMaterialInterfaceFilterBlock *block, unsigned char levelOfGhostLayer)
void CheckLevelsForNeighbors (vtkMaterialInterfaceFilterBlock *block)
int FindFaceNeighbors (unsigned int blockLevel, int blockIndex[3], int faceAxis, int faceMaxFlag, std::vector< vtkMaterialInterfaceFilterBlock * > *result)
int HasNeighbor (unsigned int blockLevel, int blockIndex[3], int neighborDirection[3])
virtual void SetMaterialFractionArrayName (const char *)
void SaveBlockSurfaces (const char *fileName)
void SaveGhostSurfaces (const char *fileName)
void ComputeFacePoints (vtkMaterialInterfaceFilterIterator *in, vtkMaterialInterfaceFilterIterator *out, int axis, int outMaxFlag)
void ComputeFaceNeighbors (vtkMaterialInterfaceFilterIterator *in, vtkMaterialInterfaceFilterIterator *out, int axis, int outMaxFlag)
long ComputeProximity (const int faceIdx[3], int faceLevel, const int ext[6], int refLevel)
void FindNeighbor (int faceIndex[3], int faceLevel, vtkMaterialInterfaceFilterIterator *neighbor, vtkMaterialInterfaceFilterIterator *reference)
- Protected Member Functions inherited from vtkMultiBlockDataSetAlgorithm
 vtkMultiBlockDataSetAlgorithm ()
 ~vtkMultiBlockDataSetAlgorithm ()
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
std::vector< vtkMaterialInterfaceFilterBlock * > GhostBlocks
vtkMaterialInterfaceEquivalenceSet * EquivalenceSet
int NumberOfInputBlocks
vtkMaterialInterfaceFilterBlock ** InputBlocks
double MaterialFractionThreshold
double scaledMaterialFractionThreshold
char * MaterialFractionArrayName
vtkPolyData * CurrentFragmentMesh
std::vector< vtkPolyData * > FragmentMeshes
int FragmentId
 class vtkMaterialInterfaceFilterIntegrator { More...
double FragmentVolume
vtkDoubleArray * FragmentVolumes
double ClipDepthMin
double ClipDepthMax
vtkDoubleArray * ClipDepthMinimums
vtkDoubleArray * ClipDepthMaximums
std::vector< double > FragmentMoment
vtkDoubleArray * FragmentMoments
vtkDoubleArray * FragmentAABBCenters
bool ComputeMoments
std::vector< std::vector< double > > FragmentVolumeWtdAvg
std::vector< vtkDoubleArray * > FragmentVolumeWtdAvgs
int NVolumeWtdAvgs
std::vector< std::string > VolumeWtdAvgArrayNames
std::vector< std::vector< double > > FragmentMassWtdAvg
std::vector< vtkDoubleArray * > FragmentMassWtdAvgs
int NMassWtdAvgs
std::vector< std::string > MassWtdAvgArrayNames
std::vector< std::string > IntegratedArrayNames
std::vector< int > IntegratedArrayNComp
int NToIntegrate
std::vector< std::vector< double > > FragmentSum
std::vector< vtkDoubleArray * > FragmentSums
int NToSum
vtkDoubleArray * FragmentOBBs
 }; More...
bool ComputeOBB
int UpperLoadingBound
int * NumberOfRawFragmentsInProcess
int * LocalToGlobalOffsets
int TotalNumberOfRawFragments
int NumberOfResolvedFragments
int ResolvedFragmentCount
int MaterialId
vtkMultiBlockDataSet * ResolvedFragments
std::vector< std::vector< int > > ResolvedFragmentIds
std::vector< std::vector< int > > FragmentSplitMarker
vtkIntArray * FragmentSplitGeometry
vtkMultiBlockDataSet * ResolvedFragmentCenters
std::vector< vtkPoints * > ResolvedFragmentPoints
vtkMultiBlockDataSet * ResolvedFragmentOBBs
double GlobalOrigin [3]
double RootSpacing [3]
int StandardBlockDimensions [3]
std::vector< vtkMaterialInterfaceLevel * > Levels
vtkMaterialInterfaceFilterIterator * FaceNeighbors
int faceAxis0
int faceAxis1
int faceAxis2
double FaceCornerPoints [12]
double FaceEdgePoints [12]
int FaceEdgeFlags [4]
vtkDataArraySelection * MaterialArraySelection
vtkDataArraySelection * MassArraySelection
vtkDataArraySelection * VolumeWtdAvgArraySelection
vtkDataArraySelection * MassWtdAvgArraySelection
vtkDataArraySelection * SummationArraySelection
vtkCallbackCommand * SelectionObserver
char * OutputBaseName
bool WriteGeometryOutput
bool WriteStatisticsOutput
int DrawOBB
double Progress
double ProgressMaterialInc
double ProgressBlockInc
double ProgressResolutionInc
vtkImplicitFunction * ClipFunction
double ClipCenter [3]
int ClipWithSphere
double ClipRadius
int ClipWithPlane
double ClipPlaneVector [3]
double ClipPlaneNormal [3]
int InvertVolumeFraction
unsigned char BlockGhostLevel
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This filter takes a cell data volume fraction and generates a polydata surface. It also performs connectivity on the particles and generates a particle index as part of the cell data of the output. It computes the volume of each particle from the volume fraction.
This will turn on validation and debug i/o of the filter.
#define vtkMaterialInterfaceFilterDEBUG
This will turn on profiling of how long each part of the filter takes
#define vtkMaterialInterfaceFilterPROFILE
Definition at line 58 of file vtkMaterialInterfaceFilter.h.
Definition at line 63 of file vtkMaterialInterfaceFilter.h.
◆ vtkMaterialInterfaceFilter()
vtkMaterialInterfaceFilter::vtkMaterialInterfaceFilter ( )
◆ ~vtkMaterialInterfaceFilter()
vtkMaterialInterfaceFilter::~vtkMaterialInterfaceFilter ( )
static vtkMaterialInterfaceFilter* vtkMaterialInterfaceFilter::New ( )
virtual const char* vtkMaterialInterfaceFilter::GetClassName ( )
static int vtkMaterialInterfaceFilter::IsTypeOf ( const char *  type)
virtual int vtkMaterialInterfaceFilter::IsA ( const char *  type)
Reimplemented from vtkMultiBlockDataSetAlgorithm.
static vtkMaterialInterfaceFilter* vtkMaterialInterfaceFilter::SafeDownCast ( vtkObject *  o)
void vtkMaterialInterfaceFilter::PrintSelf ( ostream &  os,
◆ SelectMaterialArray()
void vtkMaterialInterfaceFilter::SelectMaterialArray ( const char *  name)
Add a single array
◆ UnselectMaterialArray()
void vtkMaterialInterfaceFilter::UnselectMaterialArray ( const char *  name)
◆ UnselectAllMaterialArrays()
void vtkMaterialInterfaceFilter::UnselectAllMaterialArrays ( )
remove all arrays
◆ SetMaterialArrayStatus()
void vtkMaterialInterfaceFilter::SetMaterialArrayStatus ( const char *  name,
int  status
◆ GetMaterialArrayStatus() [1/2]
int vtkMaterialInterfaceFilter::GetMaterialArrayStatus ( const char *  name)
Get enable.
/disable status for a given array
◆ GetMaterialArrayStatus() [2/2]
int vtkMaterialInterfaceFilter::GetMaterialArrayStatus ( int  index)
Get enable.
◆ GetNumberOfMaterialArrays()
int vtkMaterialInterfaceFilter::GetNumberOfMaterialArrays ( )
◆ GetMaterialArrayName()
const char* vtkMaterialInterfaceFilter::GetMaterialArrayName ( int  index)
◆ SelectMassArray()
void vtkMaterialInterfaceFilter::SelectMassArray ( const char *  name)
Mass sellection.
Add a single array
◆ UnselectMassArray()
void vtkMaterialInterfaceFilter::UnselectMassArray ( const char *  name)
◆ UnselectAllMassArrays()
void vtkMaterialInterfaceFilter::UnselectAllMassArrays ( )
remove all arrays
◆ SetMassArrayStatus()
void vtkMaterialInterfaceFilter::SetMassArrayStatus ( const char *  name,
int  status
◆ GetMassArrayStatus() [1/2]
int vtkMaterialInterfaceFilter::GetMassArrayStatus ( const char *  name)
Get enable.
◆ GetMassArrayStatus() [2/2]
int vtkMaterialInterfaceFilter::GetMassArrayStatus ( int  index)
Get enable.
◆ GetNumberOfMassArrays()
int vtkMaterialInterfaceFilter::GetNumberOfMassArrays ( )
◆ GetMassArrayName()
const char* vtkMaterialInterfaceFilter::GetMassArrayName ( int  index)
◆ SelectVolumeWtdAvgArray()
void vtkMaterialInterfaceFilter::SelectVolumeWtdAvgArray ( const char *  name)
Add a single array
◆ UnselectVolumeWtdAvgArray()
void vtkMaterialInterfaceFilter::UnselectVolumeWtdAvgArray ( const char *  name)
◆ UnselectAllVolumeWtdAvgArrays()
void vtkMaterialInterfaceFilter::UnselectAllVolumeWtdAvgArrays ( )
remove all arrays
◆ SetVolumeWtdAvgArrayStatus()
void vtkMaterialInterfaceFilter::SetVolumeWtdAvgArrayStatus ( const char *  name,
int  status
◆ GetVolumeWtdAvgArrayStatus() [1/2]
int vtkMaterialInterfaceFilter::GetVolumeWtdAvgArrayStatus ( const char *  name)
Get enable.
◆ GetVolumeWtdAvgArrayStatus() [2/2]
int vtkMaterialInterfaceFilter::GetVolumeWtdAvgArrayStatus ( int  index)
Get enable.
◆ GetNumberOfVolumeWtdAvgArrays()
int vtkMaterialInterfaceFilter::GetNumberOfVolumeWtdAvgArrays ( )
◆ GetVolumeWtdAvgArrayName()
const char* vtkMaterialInterfaceFilter::GetVolumeWtdAvgArrayName ( int  index)
◆ SelectMassWtdAvgArray()
void vtkMaterialInterfaceFilter::SelectMassWtdAvgArray ( const char *  name)
Add a single array
◆ UnselectMassWtdAvgArray()
void vtkMaterialInterfaceFilter::UnselectMassWtdAvgArray ( const char *  name)
◆ UnselectAllMassWtdAvgArrays()
void vtkMaterialInterfaceFilter::UnselectAllMassWtdAvgArrays ( )
remove all arrays
◆ SetMassWtdAvgArrayStatus()
void vtkMaterialInterfaceFilter::SetMassWtdAvgArrayStatus ( const char *  name,
int  status
◆ GetMassWtdAvgArrayStatus() [1/2]
int vtkMaterialInterfaceFilter::GetMassWtdAvgArrayStatus ( const char *  name)
Get enable.
◆ GetMassWtdAvgArrayStatus() [2/2]
int vtkMaterialInterfaceFilter::GetMassWtdAvgArrayStatus ( int  index)
Get enable.
◆ GetNumberOfMassWtdAvgArrays()
int vtkMaterialInterfaceFilter::GetNumberOfMassWtdAvgArrays ( )
◆ GetMassWtdAvgArrayName()
const char* vtkMaterialInterfaceFilter::GetMassWtdAvgArrayName ( int  index)
◆ SelectSummationArray()
void vtkMaterialInterfaceFilter::SelectSummationArray ( const char *  name)
Add a single array
◆ UnselectSummationArray()
void vtkMaterialInterfaceFilter::UnselectSummationArray ( const char *  name)
◆ UnselectAllSummationArrays()
void vtkMaterialInterfaceFilter::UnselectAllSummationArrays ( )
remove all arrays
◆ SetSummationArrayStatus()
void vtkMaterialInterfaceFilter::SetSummationArrayStatus ( const char *  name,
int  status
◆ GetSummationArrayStatus() [1/2]
int vtkMaterialInterfaceFilter::GetSummationArrayStatus ( const char *  name)
Get enable.
◆ GetSummationArrayStatus() [2/2]
int vtkMaterialInterfaceFilter::GetSummationArrayStatus ( int  index)
Get enable.
◆ GetNumberOfSummationArrays()
int vtkMaterialInterfaceFilter::GetNumberOfSummationArrays ( )
◆ GetSummationArrayName()
const char* vtkMaterialInterfaceFilter::GetSummationArrayName ( int  index)
◆ SetMaterialFractionThreshold()
void vtkMaterialInterfaceFilter::SetMaterialFractionThreshold ( double  fraction)
Volume Fraction.
Volume fraction which volxels are included in a frgament.
◆ GetMaterialFractionThreshold()
virtual double vtkMaterialInterfaceFilter::GetMaterialFractionThreshold ( )
Volume Fraction.
◆ SetComputeOBB()
virtual void vtkMaterialInterfaceFilter::SetComputeOBB ( bool  )
OBB.
Turn on/off OBB calculations
◆ GetComputeOBB()
virtual bool vtkMaterialInterfaceFilter::GetComputeOBB ( )
OBB.
◆ SetUpperLoadingBound()
void vtkMaterialInterfaceFilter::SetUpperLoadingBound ( int  nPolys)
Loading.
Set the upper bound(in number of polygons) that will be used to exclude processes from work sharing during memory intensive portions of the algorithm. acceptable values are [1 INF), however the default is 1,000,000 polys. Increasing increases parallelism while decreasing reduces parallelism. Setting too low can cause problems. For instance if it's set so low that all processes are excluded.
◆ GetUpperLoadingBound()
virtual int vtkMaterialInterfaceFilter::GetUpperLoadingBound ( )
Loading.
◆ SetOutputBaseName()
virtual void vtkMaterialInterfaceFilter::SetOutputBaseName ( const char *  )
Output file.
Name the file to save a table of fragment attributes to.
◆ GetOutputBaseName()
virtual char* vtkMaterialInterfaceFilter::GetOutputBaseName ( )
Output file.
◆ SetWriteGeometryOutput()
virtual void vtkMaterialInterfaceFilter::SetWriteGeometryOutput ( bool  )
◆ GetWriteGeometryOutput()
virtual bool vtkMaterialInterfaceFilter::GetWriteGeometryOutput ( )
◆ SetWriteStatisticsOutput()
virtual void vtkMaterialInterfaceFilter::SetWriteStatisticsOutput ( bool  )
◆ GetWriteStatisticsOutput()
virtual bool vtkMaterialInterfaceFilter::GetWriteStatisticsOutput ( )
◆ SetBlockGhostLevel()
virtual void vtkMaterialInterfaceFilter::SetBlockGhostLevel ( unsigned char  )
By Default set to 1 which is what the scth reader provides
◆ GetBlockGhostLevel()
virtual unsigned char vtkMaterialInterfaceFilter::GetBlockGhostLevel ( )
◆ SelectionModifiedCallback()
static void vtkMaterialInterfaceFilter::SelectionModifiedCallback ( vtkObject *  ,
unsigned long  ,
void *  clientdata,
void *
◆ SetClipFunction()
void vtkMaterialInterfaceFilter::SetClipFunction ( vtkImplicitFunction *  clipFunction)
◆ GetClipFunction()
virtual vtkImplicitFunction* vtkMaterialInterfaceFilter::GetClipFunction ( )
◆ SetInvertVolumeFraction()
virtual void vtkMaterialInterfaceFilter::SetInvertVolumeFraction ( int  )
This is useful for extracting a crater.
◆ GetInvertVolumeFraction()
virtual int vtkMaterialInterfaceFilter::GetInvertVolumeFraction ( )
◆ GetMTime()
vtkMTimeType vtkMaterialInterfaceFilter::GetMTime ( )
◆ RequestData()
int vtkMaterialInterfaceFilter::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ FillInputPortInformation()
int vtkMaterialInterfaceFilter::FillInputPortInformation ( int  port,
vtkInformation *  info
◆ FillOutputPortInformation()
int vtkMaterialInterfaceFilter::FillOutputPortInformation ( int  port,
◆ PrepareForPass()
void vtkMaterialInterfaceFilter::PrepareForPass ( vtkNonOverlappingAMR *  hbdsInput,
std::vector< std::string > &  volumeWtdAvgArrayNames,
std::vector< std::string > &  massWtdAvgArrayNames,
std::vector< std::string > &  summedArrayNames,
std::vector< std::string > &  integratedArrayNames
◆ NewFragmentMesh()
vtkPolyData* vtkMaterialInterfaceFilter::NewFragmentMesh ( )
◆ ProcessBlock()
int vtkMaterialInterfaceFilter::ProcessBlock ( int  blockId)
◆ ConnectFragment()
void vtkMaterialInterfaceFilter::ConnectFragment ( vtkMaterialInterfaceFilterRingBuffer *  iterator)
◆ GetNeighborIterator()
void vtkMaterialInterfaceFilter::GetNeighborIterator ( vtkMaterialInterfaceFilterIterator *  next,
vtkMaterialInterfaceFilterIterator *  iterator,
int  axis0,
int  maxFlag0,
int  axis1,
int  maxFlag1,
int  axis2,
int  maxFlag2
◆ GetNeighborIteratorPad()
void vtkMaterialInterfaceFilter::GetNeighborIteratorPad ( vtkMaterialInterfaceFilterIterator *  next,
int  axis0,
int  maxFlag0,
int  axis1,
int  maxFlag1,
int  axis2,
int  maxFlag2
◆ CreateFace()
void vtkMaterialInterfaceFilter::CreateFace ( vtkMaterialInterfaceFilterIterator *  in,
vtkMaterialInterfaceFilterIterator *  out,
int  axis,
int  outMaxFlag
◆ ComputeDisplacementFactors()
int vtkMaterialInterfaceFilter::ComputeDisplacementFactors ( vtkMaterialInterfaceFilterIterator *  pointNeighborIterators[8],
int  faceAxis
◆ SubVoxelPositionCorner()
int vtkMaterialInterfaceFilter::SubVoxelPositionCorner ( double *  point,
int  faceAxis
◆ FindPointNeighbors()
void vtkMaterialInterfaceFilter::FindPointNeighbors ( vtkMaterialInterfaceFilterIterator *  iteratorMin0,
vtkMaterialInterfaceFilterIterator *  iteratorMax0,
int  axis0,
int  maxFlag1,
int  maxFlag2,
double  pt[3]
◆ ComputeOriginAndRootSpacingOld()
int vtkMaterialInterfaceFilter::ComputeOriginAndRootSpacingOld ( vtkNonOverlappingAMR *  input)
◆ ComputeOriginAndRootSpacing()
void vtkMaterialInterfaceFilter::ComputeOriginAndRootSpacing ( vtkNonOverlappingAMR *  input)
◆ GetNumberOfLocalBlocks()
int vtkMaterialInterfaceFilter::GetNumberOfLocalBlocks ( vtkNonOverlappingAMR *  input)
◆ ShareGhostBlocks()
void vtkMaterialInterfaceFilter::ShareGhostBlocks ( )
◆ HandleGhostBlockRequests()
void vtkMaterialInterfaceFilter::HandleGhostBlockRequests ( )
◆ ComputeRequiredGhostExtent()
int vtkMaterialInterfaceFilter::ComputeRequiredGhostExtent ( int  level,
int  inExt[6],
int  outExt[6]
◆ ComputeAndDistributeGhostBlocks()
void vtkMaterialInterfaceFilter::ComputeAndDistributeGhostBlocks ( int *  numBlocksInProc,
int *  blockMetaData,
int  myProc,
int  numProcs
◆ AddEquivalence()
void vtkMaterialInterfaceFilter::AddEquivalence ( vtkMaterialInterfaceFilterIterator *  neighbor1,
vtkMaterialInterfaceFilterIterator *  neighbor2
◆ PrepareForResolveEquivalences()
void vtkMaterialInterfaceFilter::PrepareForResolveEquivalences ( )
◆ ResolveEquivalences()
void vtkMaterialInterfaceFilter::ResolveEquivalences ( )
◆ GatherEquivalenceSets()
void vtkMaterialInterfaceFilter::GatherEquivalenceSets ( vtkMaterialInterfaceEquivalenceSet *  set)
◆ ShareGhostEquivalences()
void vtkMaterialInterfaceFilter::ShareGhostEquivalences ( vtkMaterialInterfaceEquivalenceSet *  globalSet,
int *  procOffsets
◆ ReceiveGhostFragmentIds()
void vtkMaterialInterfaceFilter::ReceiveGhostFragmentIds ( vtkMaterialInterfaceEquivalenceSet *  globalSet,
int *  procOffset
◆ MergeGhostEquivalenceSets()
void vtkMaterialInterfaceFilter::MergeGhostEquivalenceSets ( vtkMaterialInterfaceEquivalenceSet *  globalSet)
◆ ResolveIntegratedAttributes()
int vtkMaterialInterfaceFilter::ResolveIntegratedAttributes ( int  controllingProcId)
◆ PrepareToResolveIntegratedAttributes()
int vtkMaterialInterfaceFilter::PrepareToResolveIntegratedAttributes ( )
◆ SendIntegratedAttributes()
int vtkMaterialInterfaceFilter::SendIntegratedAttributes ( int  recipientProcId)
◆ ReceiveIntegratedAttributes()
int vtkMaterialInterfaceFilter::ReceiveIntegratedAttributes ( int  sourceProcId)
◆ PrepareToCollectIntegratedAttributes()
int vtkMaterialInterfaceFilter::PrepareToCollectIntegratedAttributes ( std::vector< vtkMaterialInterfaceCommBuffer > &  buffers,
std::vector< vtkDoubleArray * > &  volumes,
std::vector< vtkDoubleArray * > &  clipDepthMaxs,
std::vector< vtkDoubleArray * > &  clipDepthMins,
std::vector< vtkDoubleArray * > &  moments,
std::vector< std::vector< vtkDoubleArray * >> &  volumeWtdAvgs,
std::vector< std::vector< vtkDoubleArray * >> &  massWtdAvgs,
std::vector< std::vector< vtkDoubleArray * >> &  sums
◆ CleanUpAfterCollectIntegratedAttributes()
int vtkMaterialInterfaceFilter::CleanUpAfterCollectIntegratedAttributes ( std::vector< vtkMaterialInterfaceCommBuffer > &  buffers,
◆ CollectIntegratedAttributes()
int vtkMaterialInterfaceFilter::CollectIntegratedAttributes ( std::vector< vtkMaterialInterfaceCommBuffer > &  buffers,
◆ BroadcastIntegratedAttributes()
int vtkMaterialInterfaceFilter::BroadcastIntegratedAttributes ( int  sourceProcessId)
◆ SendGeometricAttributes()
int vtkMaterialInterfaceFilter::SendGeometricAttributes ( int  controllingProcId)
◆ PrepareToCollectGeometricAttributes()
int vtkMaterialInterfaceFilter::PrepareToCollectGeometricAttributes ( std::vector< vtkMaterialInterfaceCommBuffer > &  buffers,
std::vector< vtkDoubleArray * > &  coaabb,
std::vector< vtkDoubleArray * > &  obb,
std::vector< int * > &  ids
◆ CleanUpAfterCollectGeometricAttributes()
int vtkMaterialInterfaceFilter::CleanUpAfterCollectGeometricAttributes ( std::vector< vtkMaterialInterfaceCommBuffer > &  buffers,
◆ CollectGeometricAttributes()
int vtkMaterialInterfaceFilter::CollectGeometricAttributes ( std::vector< vtkMaterialInterfaceCommBuffer > &  buffers,
◆ PrepareToMergeGeometricAttributes()
int vtkMaterialInterfaceFilter::PrepareToMergeGeometricAttributes ( )
◆ GatherGeometricAttributes()
int vtkMaterialInterfaceFilter::GatherGeometricAttributes ( int  recipientProcId)
◆ ResolveLocalFragmentGeometry()
void vtkMaterialInterfaceFilter::ResolveLocalFragmentGeometry ( )
◆ ResolveRemoteFragmentGeometry()
void vtkMaterialInterfaceFilter::ResolveRemoteFragmentGeometry ( )
◆ CleanLocalFragmentGeometry()
void vtkMaterialInterfaceFilter::CleanLocalFragmentGeometry ( )
◆ BuildLoadingArray()
void vtkMaterialInterfaceFilter::BuildLoadingArray ( std::vector< vtkIdType > &  loadingArray)
◆ PackLoadingArray()
int vtkMaterialInterfaceFilter::PackLoadingArray ( vtkIdType *&  buffer)
◆ UnPackLoadingArray()
int vtkMaterialInterfaceFilter::UnPackLoadingArray ( vtkIdType *  buffer,
int  bufSize,
◆ CopyAttributesToOutput0()
void vtkMaterialInterfaceFilter::CopyAttributesToOutput0 ( )
◆ CopyAttributesToOutput1()
void vtkMaterialInterfaceFilter::CopyAttributesToOutput1 ( )
◆ CopyAttributesToOutput2()
void vtkMaterialInterfaceFilter::CopyAttributesToOutput2 ( )
◆ WriteGeometryOutputToTextFile()
int vtkMaterialInterfaceFilter::WriteGeometryOutputToTextFile ( )
◆ WriteStatisticsOutputToTextFile()
int vtkMaterialInterfaceFilter::WriteStatisticsOutputToTextFile ( )
◆ BuildOutputs()
int vtkMaterialInterfaceFilter::BuildOutputs ( vtkMultiBlockDataSet *  mbdsOutput0,
vtkMultiBlockDataSet *  mbdsOutput1,
vtkMultiBlockDataSet *  mbdsOutput2,
int  materialId
◆ Accumulate()
int vtkMaterialInterfaceFilter::Accumulate ( double *  dest,
vtkDataArray *  src,
int  nComps,
int  srcCellIndex,
double  weight
◆ AccumulateMoments()
int vtkMaterialInterfaceFilter::AccumulateMoments ( double *  moments,
vtkDataArray *  massArray,
int  srcCellIndex,
double *  X
◆ ComputeGeometricAttributes()
void vtkMaterialInterfaceFilter::ComputeGeometricAttributes ( )
◆ ComputeLocalFragmentOBB()
int vtkMaterialInterfaceFilter::ComputeLocalFragmentOBB ( )
◆ ComputeLocalFragmentAABBCenters()
int vtkMaterialInterfaceFilter::ComputeLocalFragmentAABBCenters ( )
◆ DeleteAllBlocks()
void vtkMaterialInterfaceFilter::DeleteAllBlocks ( )
◆ InitializeBlocks()
int vtkMaterialInterfaceFilter::InitializeBlocks ( vtkNonOverlappingAMR *  input,
std::string &  materialFractionArrayName,
std::string &  massArrayName,
◆ AddBlock()
void vtkMaterialInterfaceFilter::AddBlock ( vtkMaterialInterfaceFilterBlock *  block,
◆ CheckLevelsForNeighbors()
void vtkMaterialInterfaceFilter::CheckLevelsForNeighbors ( vtkMaterialInterfaceFilterBlock *  block)
◆ FindFaceNeighbors()
int vtkMaterialInterfaceFilter::FindFaceNeighbors ( unsigned int  blockLevel,
int  blockIndex[3],
int  faceAxis,
int  faceMaxFlag,
std::vector< vtkMaterialInterfaceFilterBlock * > *  result
◆ HasNeighbor()
int vtkMaterialInterfaceFilter::HasNeighbor ( unsigned int  blockLevel,
int  blockIndex[3],
◆ SetMaterialFractionArrayName()
virtual void vtkMaterialInterfaceFilter::SetMaterialFractionArrayName ( const char *  )
protectedvirtual
◆ SaveBlockSurfaces()
void vtkMaterialInterfaceFilter::SaveBlockSurfaces ( const char *  fileName)
◆ SaveGhostSurfaces()
void vtkMaterialInterfaceFilter::SaveGhostSurfaces ( const char *  fileName)
◆ ComputeFacePoints()
void vtkMaterialInterfaceFilter::ComputeFacePoints ( vtkMaterialInterfaceFilterIterator *  in,
int  axis,
int  outMaxFlag
◆ ComputeFaceNeighbors()
void vtkMaterialInterfaceFilter::ComputeFaceNeighbors ( vtkMaterialInterfaceFilterIterator *  in,
int  axis,
int  outMaxFlag
◆ ComputeProximity()
long vtkMaterialInterfaceFilter::ComputeProximity ( const int  faceIdx[3],
int  faceLevel,
const int  ext[6],
int  refLevel
◆ FindNeighbor()
void vtkMaterialInterfaceFilter::FindNeighbor ( int  faceIndex[3],
int  faceLevel,
vtkMaterialInterfaceFilterIterator *  neighbor,
vtkMaterialInterfaceFilterIterator *  reference
◆ GhostBlocks
std::vector<vtkMaterialInterfaceFilterBlock*> vtkMaterialInterfaceFilter::GhostBlocks
Definition at line 367 of file vtkMaterialInterfaceFilter.h.
◆ Controller
vtkMultiProcessController* vtkMaterialInterfaceFilter::Controller
Definition at line 375 of file vtkMaterialInterfaceFilter.h.
◆ EquivalenceSet
vtkMaterialInterfaceEquivalenceSet* vtkMaterialInterfaceFilter::EquivalenceSet
Definition at line 377 of file vtkMaterialInterfaceFilter.h.
◆ NumberOfInputBlocks
int vtkMaterialInterfaceFilter::NumberOfInputBlocks
Definition at line 484 of file vtkMaterialInterfaceFilter.h.
◆ InputBlocks
vtkMaterialInterfaceFilterBlock** vtkMaterialInterfaceFilter::InputBlocks
Definition at line 485 of file vtkMaterialInterfaceFilter.h.
◆ MaterialFractionThreshold
double vtkMaterialInterfaceFilter::MaterialFractionThreshold
Definition at line 509 of file vtkMaterialInterfaceFilter.h.
◆ scaledMaterialFractionThreshold
double vtkMaterialInterfaceFilter::scaledMaterialFractionThreshold
Definition at line 512 of file vtkMaterialInterfaceFilter.h.
◆ MaterialFractionArrayName
char* vtkMaterialInterfaceFilter::MaterialFractionArrayName
Definition at line 514 of file vtkMaterialInterfaceFilter.h.
◆ CurrentFragmentMesh
vtkPolyData* vtkMaterialInterfaceFilter::CurrentFragmentMesh
Definition at line 515 of file vtkMaterialInterfaceFilter.h.
◆ FragmentMeshes
std::vector<vtkPolyData*> vtkMaterialInterfaceFilter::FragmentMeshes
Definition at line 523 of file vtkMaterialInterfaceFilter.h.
◆ FragmentId
int vtkMaterialInterfaceFilter::FragmentId
Definition at line 531 of file vtkMaterialInterfaceFilter.h.
◆ FragmentVolume
double vtkMaterialInterfaceFilter::FragmentVolume
Definition at line 533 of file vtkMaterialInterfaceFilter.h.
◆ FragmentVolumes
vtkDoubleArray* vtkMaterialInterfaceFilter::FragmentVolumes
Definition at line 536 of file vtkMaterialInterfaceFilter.h.
◆ ClipDepthMin
double vtkMaterialInterfaceFilter::ClipDepthMin
Definition at line 540 of file vtkMaterialInterfaceFilter.h.
◆ ClipDepthMax
double vtkMaterialInterfaceFilter::ClipDepthMax
Definition at line 541 of file vtkMaterialInterfaceFilter.h.
◆ ClipDepthMinimums
vtkDoubleArray* vtkMaterialInterfaceFilter::ClipDepthMinimums
Definition at line 542 of file vtkMaterialInterfaceFilter.h.
◆ ClipDepthMaximums
vtkDoubleArray* vtkMaterialInterfaceFilter::ClipDepthMaximums
Definition at line 543 of file vtkMaterialInterfaceFilter.h.
◆ FragmentMoment
std::vector<double> vtkMaterialInterfaceFilter::FragmentMoment
Definition at line 546 of file vtkMaterialInterfaceFilter.h.
◆ FragmentMoments
vtkDoubleArray* vtkMaterialInterfaceFilter::FragmentMoments
Definition at line 548 of file vtkMaterialInterfaceFilter.h.
◆ FragmentAABBCenters
vtkDoubleArray* vtkMaterialInterfaceFilter::FragmentAABBCenters
Definition at line 550 of file vtkMaterialInterfaceFilter.h.
◆ ComputeMoments
bool vtkMaterialInterfaceFilter::ComputeMoments
Definition at line 552 of file vtkMaterialInterfaceFilter.h.
◆ FragmentVolumeWtdAvg
std::vector<std::vector<double> > vtkMaterialInterfaceFilter::FragmentVolumeWtdAvg
Definition at line 556 of file vtkMaterialInterfaceFilter.h.
◆ FragmentVolumeWtdAvgs
std::vector<vtkDoubleArray*> vtkMaterialInterfaceFilter::FragmentVolumeWtdAvgs
Definition at line 558 of file vtkMaterialInterfaceFilter.h.
◆ NVolumeWtdAvgs
int vtkMaterialInterfaceFilter::NVolumeWtdAvgs
Definition at line 560 of file vtkMaterialInterfaceFilter.h.
◆ VolumeWtdAvgArrayNames
std::vector<std::string> vtkMaterialInterfaceFilter::VolumeWtdAvgArrayNames
Definition at line 562 of file vtkMaterialInterfaceFilter.h.
◆ FragmentMassWtdAvg
std::vector<std::vector<double> > vtkMaterialInterfaceFilter::FragmentMassWtdAvg
Definition at line 566 of file vtkMaterialInterfaceFilter.h.
◆ FragmentMassWtdAvgs
std::vector<vtkDoubleArray*> vtkMaterialInterfaceFilter::FragmentMassWtdAvgs
Definition at line 568 of file vtkMaterialInterfaceFilter.h.
◆ NMassWtdAvgs
int vtkMaterialInterfaceFilter::NMassWtdAvgs
Definition at line 570 of file vtkMaterialInterfaceFilter.h.
◆ MassWtdAvgArrayNames
std::vector<std::string> vtkMaterialInterfaceFilter::MassWtdAvgArrayNames
Definition at line 572 of file vtkMaterialInterfaceFilter.h.
◆ IntegratedArrayNames
std::vector<std::string> vtkMaterialInterfaceFilter::IntegratedArrayNames
Definition at line 577 of file vtkMaterialInterfaceFilter.h.
◆ IntegratedArrayNComp
std::vector<int> vtkMaterialInterfaceFilter::IntegratedArrayNComp
Definition at line 578 of file vtkMaterialInterfaceFilter.h.
◆ NToIntegrate
int vtkMaterialInterfaceFilter::NToIntegrate
Definition at line 580 of file vtkMaterialInterfaceFilter.h.
◆ FragmentSum
std::vector<std::vector<double> > vtkMaterialInterfaceFilter::FragmentSum
Definition at line 584 of file vtkMaterialInterfaceFilter.h.
◆ FragmentSums
std::vector<vtkDoubleArray*> vtkMaterialInterfaceFilter::FragmentSums
Definition at line 586 of file vtkMaterialInterfaceFilter.h.
◆ NToSum
int vtkMaterialInterfaceFilter::NToSum
Definition at line 588 of file vtkMaterialInterfaceFilter.h.
◆ FragmentOBBs
vtkDoubleArray* vtkMaterialInterfaceFilter::FragmentOBBs
Definition at line 592 of file vtkMaterialInterfaceFilter.h.
◆ ComputeOBB
bool vtkMaterialInterfaceFilter::ComputeOBB
Definition at line 594 of file vtkMaterialInterfaceFilter.h.
◆ UpperLoadingBound
int vtkMaterialInterfaceFilter::UpperLoadingBound
Definition at line 598 of file vtkMaterialInterfaceFilter.h.
◆ NumberOfRawFragmentsInProcess
int* vtkMaterialInterfaceFilter::NumberOfRawFragmentsInProcess
Definition at line 606 of file vtkMaterialInterfaceFilter.h.
◆ LocalToGlobalOffsets
int* vtkMaterialInterfaceFilter::LocalToGlobalOffsets
Definition at line 607 of file vtkMaterialInterfaceFilter.h.
◆ TotalNumberOfRawFragments
int vtkMaterialInterfaceFilter::TotalNumberOfRawFragments
Definition at line 608 of file vtkMaterialInterfaceFilter.h.
◆ NumberOfResolvedFragments
int vtkMaterialInterfaceFilter::NumberOfResolvedFragments
Definition at line 609 of file vtkMaterialInterfaceFilter.h.
◆ ResolvedFragmentCount
int vtkMaterialInterfaceFilter::ResolvedFragmentCount
Definition at line 612 of file vtkMaterialInterfaceFilter.h.
◆ MaterialId
int vtkMaterialInterfaceFilter::MaterialId
Definition at line 615 of file vtkMaterialInterfaceFilter.h.
◆ ResolvedFragments
vtkMultiBlockDataSet* vtkMaterialInterfaceFilter::ResolvedFragments
Definition at line 620 of file vtkMaterialInterfaceFilter.h.
◆ ResolvedFragmentIds
std::vector<std::vector<int> > vtkMaterialInterfaceFilter::ResolvedFragmentIds
Definition at line 622 of file vtkMaterialInterfaceFilter.h.
◆ FragmentSplitMarker
std::vector<std::vector<int> > vtkMaterialInterfaceFilter::FragmentSplitMarker
Definition at line 624 of file vtkMaterialInterfaceFilter.h.
◆ FragmentSplitGeometry
vtkIntArray* vtkMaterialInterfaceFilter::FragmentSplitGeometry
Definition at line 625 of file vtkMaterialInterfaceFilter.h.
◆ ResolvedFragmentCenters
vtkMultiBlockDataSet* vtkMaterialInterfaceFilter::ResolvedFragmentCenters
Definition at line 629 of file vtkMaterialInterfaceFilter.h.
◆ ResolvedFragmentPoints
std::vector<vtkPoints*> vtkMaterialInterfaceFilter::ResolvedFragmentPoints
Definition at line 631 of file vtkMaterialInterfaceFilter.h.
◆ ResolvedFragmentOBBs
vtkMultiBlockDataSet* vtkMaterialInterfaceFilter::ResolvedFragmentOBBs
Definition at line 635 of file vtkMaterialInterfaceFilter.h.
◆ GlobalOrigin
double vtkMaterialInterfaceFilter::GlobalOrigin[3]
Definition at line 637 of file vtkMaterialInterfaceFilter.h.
◆ RootSpacing
double vtkMaterialInterfaceFilter::RootSpacing[3]
Definition at line 638 of file vtkMaterialInterfaceFilter.h.
◆ StandardBlockDimensions
int vtkMaterialInterfaceFilter::StandardBlockDimensions[3]
Definition at line 639 of file vtkMaterialInterfaceFilter.h.
◆ Levels
std::vector<vtkMaterialInterfaceLevel*> vtkMaterialInterfaceFilter::Levels
Definition at line 646 of file vtkMaterialInterfaceFilter.h.
◆ FaceNeighbors
vtkMaterialInterfaceFilterIterator* vtkMaterialInterfaceFilter::FaceNeighbors
Definition at line 649 of file vtkMaterialInterfaceFilter.h.
◆ faceAxis0
int vtkMaterialInterfaceFilter::faceAxis0
Definition at line 651 of file vtkMaterialInterfaceFilter.h.
◆ faceAxis1
int vtkMaterialInterfaceFilter::faceAxis1
Definition at line 652 of file vtkMaterialInterfaceFilter.h.
◆ faceAxis2
int vtkMaterialInterfaceFilter::faceAxis2
Definition at line 653 of file vtkMaterialInterfaceFilter.h.
◆ FaceCornerPoints
double vtkMaterialInterfaceFilter::FaceCornerPoints[12]
Definition at line 654 of file vtkMaterialInterfaceFilter.h.
◆ FaceEdgePoints
double vtkMaterialInterfaceFilter::FaceEdgePoints[12]
Definition at line 655 of file vtkMaterialInterfaceFilter.h.
◆ FaceEdgeFlags
int vtkMaterialInterfaceFilter::FaceEdgeFlags[4]
Definition at line 656 of file vtkMaterialInterfaceFilter.h.
◆ MaterialArraySelection
vtkDataArraySelection* vtkMaterialInterfaceFilter::MaterialArraySelection
Definition at line 669 of file vtkMaterialInterfaceFilter.h.
◆ MassArraySelection
vtkDataArraySelection* vtkMaterialInterfaceFilter::MassArraySelection
Definition at line 670 of file vtkMaterialInterfaceFilter.h.
◆ VolumeWtdAvgArraySelection
vtkDataArraySelection* vtkMaterialInterfaceFilter::VolumeWtdAvgArraySelection
Definition at line 671 of file vtkMaterialInterfaceFilter.h.
◆ MassWtdAvgArraySelection
vtkDataArraySelection* vtkMaterialInterfaceFilter::MassWtdAvgArraySelection
Definition at line 672 of file vtkMaterialInterfaceFilter.h.
◆ SummationArraySelection
vtkDataArraySelection* vtkMaterialInterfaceFilter::SummationArraySelection
Definition at line 673 of file vtkMaterialInterfaceFilter.h.
◆ SelectionObserver
vtkCallbackCommand* vtkMaterialInterfaceFilter::SelectionObserver
Definition at line 674 of file vtkMaterialInterfaceFilter.h.
◆ OutputBaseName
char* vtkMaterialInterfaceFilter::OutputBaseName
Definition at line 675 of file vtkMaterialInterfaceFilter.h.
bool vtkMaterialInterfaceFilter::WriteGeometryOutput
Definition at line 676 of file vtkMaterialInterfaceFilter.h.
bool vtkMaterialInterfaceFilter::WriteStatisticsOutput
Definition at line 677 of file vtkMaterialInterfaceFilter.h.
◆ DrawOBB
int vtkMaterialInterfaceFilter::DrawOBB
Definition at line 678 of file vtkMaterialInterfaceFilter.h.
◆ Progress
double vtkMaterialInterfaceFilter::Progress
Definition at line 679 of file vtkMaterialInterfaceFilter.h.
◆ ProgressMaterialInc
double vtkMaterialInterfaceFilter::ProgressMaterialInc
Definition at line 680 of file vtkMaterialInterfaceFilter.h.
◆ ProgressBlockInc
double vtkMaterialInterfaceFilter::ProgressBlockInc
Definition at line 681 of file vtkMaterialInterfaceFilter.h.
◆ ProgressResolutionInc
double vtkMaterialInterfaceFilter::ProgressResolutionInc
Definition at line 682 of file vtkMaterialInterfaceFilter.h.
◆ ClipFunction
vtkImplicitFunction* vtkMaterialInterfaceFilter::ClipFunction
Definition at line 688 of file vtkMaterialInterfaceFilter.h.
◆ ClipCenter
double vtkMaterialInterfaceFilter::ClipCenter[3]
Definition at line 691 of file vtkMaterialInterfaceFilter.h.
◆ ClipWithSphere
int vtkMaterialInterfaceFilter::ClipWithSphere
Definition at line 692 of file vtkMaterialInterfaceFilter.h.
◆ ClipRadius
double vtkMaterialInterfaceFilter::ClipRadius
Definition at line 693 of file vtkMaterialInterfaceFilter.h.
◆ ClipWithPlane
int vtkMaterialInterfaceFilter::ClipWithPlane
Definition at line 694 of file vtkMaterialInterfaceFilter.h.
◆ ClipPlaneVector
double vtkMaterialInterfaceFilter::ClipPlaneVector[3]
Definition at line 695 of file vtkMaterialInterfaceFilter.h.
◆ ClipPlaneNormal
double vtkMaterialInterfaceFilter::ClipPlaneNormal[3]
Definition at line 696 of file vtkMaterialInterfaceFilter.h.
◆ InvertVolumeFraction
int vtkMaterialInterfaceFilter::InvertVolumeFraction
Definition at line 699 of file vtkMaterialInterfaceFilter.h.
◆ BlockGhostLevel
unsigned char vtkMaterialInterfaceFilter::BlockGhostLevel
Definition at line 703 of file vtkMaterialInterfaceFilter.h.
