vtkInSituPParticlePathFilter Class Reference
An In Situ Particle tracer for unsteady vector fields. More...
#include <vtkInSituPParticlePathFilter.h>
Inheritance diagram for vtkInSituPParticlePathFilter:
Collaboration diagram for vtkInSituPParticlePathFilter:
typedef vtkPParticlePathFilter Superclass
- Public Types inherited from vtkPParticlePathFilter
typedef vtkPParticleTracerBase Superclass
- Public Types inherited from vtkPParticleTracerBase
typedef vtkParticleTracerBase Superclass
- Public Types inherited from vtkParticleTracerBase
enum  Solvers
typedef vtkPolyDataAlgorithm Superclass
- Public Types inherited from vtkPolyDataAlgorithm
enum  DesiredOutputPrecision
void SetClearCache (bool)
 Set whether or not to clear out cache of previous time steps. More...
void AddRestartConnection (vtkAlgorithmOutput *input)
 Provide support pre-pending previously computed particle paths. More...
void RemoveAllRestarts ()
virtual void SetRestartedSimulation (bool)
 Set/Get if the simulation has been restarted. More...
virtual bool GetRestartedSimulation ()
virtual void SetFirstTimeStep (int)
 Specify the first time step that particle paths are computed. More...
virtual int GetFirstTimeStep ()
- Public Member Functions inherited from vtkPParticlePathFilter
vtkPParticlePathFilter * NewInstance () const
- Public Member Functions inherited from vtkPParticleTracerBase
vtkPParticleTracerBase * NewInstance () const
virtual void SetController (vtkMultiProcessController *controller)
- Public Member Functions inherited from vtkParticleTracerBase
vtkParticleTracerBase * NewInstance () const
void PrintParticleHistories ()
void SetIntegrator (vtkInitialValueProblemSolver *)
virtual vtkInitialValueProblemSolver * GetIntegrator ()
void SetIntegratorType (int type)
int GetIntegratorType ()
virtual bool GetComputeVorticity ()
void SetComputeVorticity (bool)
virtual double GetTerminalSpeed ()
void SetTerminalSpeed (double)
virtual double GetRotationScale ()
void SetRotationScale (double)
virtual void SetIgnorePipelineTime (int)
virtual int GetIgnorePipelineTime ()
virtual void IgnorePipelineTimeOn ()
virtual void IgnorePipelineTimeOff ()
virtual int GetForceReinjectionEveryNSteps ()
void SetForceReinjectionEveryNSteps (int)
void SetTerminationTime (double t)
virtual double GetTerminationTime ()
virtual double GetStartTime ()
void SetStartTime (double t)
virtual void SetStaticSeeds (int)
virtual int GetStaticSeeds ()
virtual void SetStaticMesh (int)
virtual int GetStaticMesh ()
virtual void SetParticleWriter (vtkAbstractParticleWriter *pw)
virtual vtkAbstractParticleWriter * GetParticleWriter ()
virtual void SetParticleFileName (const char *)
virtual char * GetParticleFileName ()
virtual void SetEnableParticleWriting (int)
virtual int GetEnableParticleWriting ()
virtual void EnableParticleWritingOn ()
virtual void EnableParticleWritingOff ()
virtual void SetDisableResetCache (int)
virtual int GetDisableResetCache ()
virtual void DisableResetCacheOn ()
virtual void DisableResetCacheOff ()
void AddSourceConnection (vtkAlgorithmOutput *input)
void RemoveAllSources ()
- Public Member Functions inherited from vtkPolyDataAlgorithm
vtkPolyDataAlgorithm * NewInstance () const
vtkDataObject * GetInput ()
vtkPolyData * GetPolyDataInput (int port)
vtkPolyData * GetOutput ()
vtkPolyData * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkInSituPParticlePathFilter * SafeDownCast (vtkObject *o)
static vtkInSituPParticlePathFilter * New ()
- Static Public Member Functions inherited from vtkPParticlePathFilter
static vtkPParticlePathFilter * SafeDownCast (vtkObjectBase *o)
static vtkPParticlePathFilter * New ()
- Static Public Member Functions inherited from vtkPParticleTracerBase
static vtkPParticleTracerBase * SafeDownCast (vtkObjectBase *o)
- Static Public Member Functions inherited from vtkParticleTracerBase
static vtkParticleTracerBase * SafeDownCast (vtkObjectBase *o)
- Static Public Member Functions inherited from vtkPolyDataAlgorithm
static vtkPolyDataAlgorithm * New ()
static vtkPolyDataAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkInSituPParticlePathFilter ()
 ~vtkInSituPParticlePathFilter () override
std::vector< vtkDataSet * > GetSeedSources (vtkInformationVector *inputVector, int timeStep) override
 Overriding this method allows us to inject the seeds as some point other than the first time step. More...
 We add in a third, optional port for adding in particles for a restarted simulation. More...
void AddRestartSeeds (vtkInformationVector **) override
 For restarts of particle paths, we add in the ability to add in particles from a previous computation that we will still advect. More...
void AssignSeedsToProcessors (double time, vtkDataSet *source, int sourceID, int ptId, vtkParticleTracerBaseNamespace::ParticleVector &localSeedPoints, int &localAssignedCount) override
 Before starting the particle trace, classify all the injection/seed points according to which processor they belong to. More...
- Protected Member Functions inherited from vtkPParticlePathFilter
 vtkPParticlePathFilter ()
 ~vtkPParticlePathFilter ()
virtual void ResetCache ()
virtual int OutputParticles (vtkPolyData *poly)
virtual void InitializeExtraPointDataArrays (vtkPointData *outputPD)
virtual void AppendToExtraPointDataArrays (vtkParticleTracerBaseNamespace::ParticleInformation &)
void Finalize ()
- Protected Member Functions inherited from vtkPParticleTracerBase
 vtkPParticleTracerBase ()
 ~vtkPParticleTracerBase ()
virtual vtkPolyData * Execute (vtkInformationVector **inputVector)
virtual bool SendParticleToAnotherProcess (vtkParticleTracerBaseNamespace::ParticleInformation &info, vtkParticleTracerBaseNamespace::ParticleInformation &previous, vtkPointData *)
virtual bool SendReceiveParticles (RemoteParticleVector &outofdomain, RemoteParticleVector &received)
virtual bool UpdateParticleListFromOtherProcesses ()
virtual bool IsPointDataValid (vtkDataObject *input)
virtual void AssignUniqueIds (vtkParticleTracerBaseNamespace::ParticleVector &localSeedPoints)
- Protected Member Functions inherited from vtkParticleTracerBase
 vtkParticleTracerBase ()
virtual ~vtkParticleTracerBase ()
virtual int RequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
virtual int ProcessInput (vtkInformationVector **inputVector)
virtual void Initialize ()
int InitializeInterpolator ()
int UpdateDataCache (vtkDataObject *td)
void TestParticles (vtkParticleTracerBaseNamespace::ParticleVector &candidates, std::vector< int > &passed)
void CreateProtoPD (vtkDataObject *input)
vtkFloatArray * GetParticleAge (vtkPointData *)
vtkIntArray * GetParticleIds (vtkPointData *)
vtkCharArray * GetParticleSourceIds (vtkPointData *)
vtkIntArray * GetInjectedPointIds (vtkPointData *)
vtkIntArray * GetInjectedStepIds (vtkPointData *)
vtkIntArray * GetErrorCodeArr (vtkPointData *)
vtkFloatArray * GetParticleVorticity (vtkPointData *)
vtkFloatArray * GetParticleRotation (vtkPointData *)
vtkFloatArray * GetParticleAngularVel (vtkPointData *)
bool InsideBounds (double point[])
void CalculateVorticity (vtkGenericCell *cell, double pcoords[3], vtkDoubleArray *cellVectors, double vorticity[3])
double GetCacheDataTime (int i)
double GetCacheDataTime ()
void AddParticle (vtkParticleTracerBaseNamespace::ParticleInformation &info, double *velocity)
virtual int GetReinjectionCounter ()
virtual double GetCurrentTimeValue ()
virtual void InitializeExtraPointDataArrays (vtkPointData *vtkNotUsed(outputPD))
vtkTemporalInterpolatedVelocityField * GetInterpolator ()
void TestParticles (vtkParticleTracerBaseNamespace::ParticleVector &candidates, vtkParticleTracerBaseNamespace::ParticleVector &passed, int &count)
void UpdateParticleList (vtkParticleTracerBaseNamespace::ParticleVector &candidates)
void IntegrateParticle (vtkParticleTracerBaseNamespace::ParticleListIterator &it, double currenttime, double terminationtime, vtkInitialValueProblemSolver *integrator)
bool ComputeDomainExitLocation (double pos[4], double p2[4], double intersection[4], vtkGenericCell *cell)
bool IsPointDataValid (vtkCompositeDataSet *input, std::vector< std::string > &arrayNames)
void GetPointDataArrayNames (vtkDataSet *input, std::vector< std::string > &names)
- Protected Member Functions inherited from vtkPolyDataAlgorithm
 vtkPolyDataAlgorithm ()
 ~vtkPolyDataAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
- Public Attributes inherited from vtkParticleTracerBase
 RUNGE_KUTTA2
 RUNGE_KUTTA4
 RUNGE_KUTTA45
 NONE
 UNKNOWN
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Types inherited from vtkPParticleTracerBase
typedef std::vector< RemoteParticleInfo > RemoteParticleVector
- Protected Attributes inherited from vtkPParticlePathFilter
ParticlePathFilterInternal It
vtkDoubleArray * SimulationTime
vtkIntArray * SimulationTimeStep
- Protected Attributes inherited from vtkPParticleTracerBase
RemoteParticleVector MPISendList
RemoteParticleVector Tail
- Protected Attributes inherited from vtkParticleTracerBase
vtkSmartPointer< vtkPolyData > Output
vtkSmartPointer< vtkPointData > ProtoPD
vtkIdType UniqueIdCounter
vtkParticleTracerBaseNamespace::ParticleDataList ParticleHistories
vtkSmartPointer< vtkPointData > ParticlePointData
int IgnorePipelineTime
int DisableResetCache
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkInSituPParticlePathFilter is a filter that integrates a vector field to generate particle paths. It is intended for in situ use. The additions to the parallel particle path filter is that the particle locations at previous time steps can be cleared out (ClearCache data member) and restarted connection can be used to continue advecting particles from a restarted simulation.
See also
vtkPParticlePathFilterBase has the details of the algorithms
Definition at line 23 of file vtkInSituPParticlePathFilter.h.
Definition at line 27 of file vtkInSituPParticlePathFilter.h.
◆ vtkInSituPParticlePathFilter()
vtkInSituPParticlePathFilter::vtkInSituPParticlePathFilter ( )
◆ ~vtkInSituPParticlePathFilter()
vtkInSituPParticlePathFilter::~vtkInSituPParticlePathFilter ( )
virtual const char* vtkInSituPParticlePathFilter::GetClassName ( )
static int vtkInSituPParticlePathFilter::IsTypeOf ( const char *  type)
virtual int vtkInSituPParticlePathFilter::IsA ( const char *  type)
Reimplemented from vtkPParticlePathFilter.
static vtkInSituPParticlePathFilter* vtkInSituPParticlePathFilter::SafeDownCast ( vtkObject *  o)
void vtkInSituPParticlePathFilter::PrintSelf ( ostream &  os,
static vtkInSituPParticlePathFilter* vtkInSituPParticlePathFilter::New ( )
◆ SetClearCache()
void vtkInSituPParticlePathFilter::SetClearCache ( bool  )
Default value is false. Clearing the cache is aimed towards in situ use.
◆ AddRestartConnection()
void vtkInSituPParticlePathFilter::AddRestartConnection ( vtkAlgorithmOutput *  input)
◆ RemoveAllRestarts()
void vtkInSituPParticlePathFilter::RemoveAllRestarts ( )
◆ SetRestartedSimulation()
virtual void vtkInSituPParticlePathFilter::SetRestartedSimulation ( bool  )
If it is a restarted simulation we may not necessarily want to inject/reinject particles on the first time step. The default is False.
◆ GetRestartedSimulation()
virtual bool vtkInSituPParticlePathFilter::GetRestartedSimulation ( )
◆ SetFirstTimeStep()
virtual void vtkInSituPParticlePathFilter::SetFirstTimeStep ( int  )
This is useful for restarted simulations or when the simulation's first time step isn't 0. The default is 0.
◆ GetFirstTimeStep()
virtual int vtkInSituPParticlePathFilter::GetFirstTimeStep ( )
◆ GetSeedSources()
std::vector<vtkDataSet*> vtkInSituPParticlePathFilter::GetSeedSources ( vtkInformationVector *  inputVector,
int  timeStep
overrideprotectedvirtual
This is needed for restarted simulations where the restart step may not coincide with an injection step. Even if it did, the seeds probably were already reinjected before the restart files were written.
Reimplemented from vtkParticleTracerBase.
◆ FillInputPortInformation()
int vtkInSituPParticlePathFilter::FillInputPortInformation ( int  port,
vtkInformation *  info
These particles are only added at the first time step.
◆ RequestUpdateExtent()
int vtkInSituPParticlePathFilter::RequestUpdateExtent ( vtkInformation *  request,
Reimplemented from vtkPParticleTracerBase.
◆ AddRestartSeeds()
void vtkInSituPParticlePathFilter::AddRestartSeeds ( vtkInformationVector **  )
◆ AssignSeedsToProcessors()
void vtkInSituPParticlePathFilter::AssignSeedsToProcessors ( double  time,
vtkDataSet *  source,
int  sourceID,
int  ptId,
vtkParticleTracerBaseNamespace::ParticleVector &  localSeedPoints,
int &  localAssignedCount
This saves us retesting at every injection time providing 1) The volumes are static, 2) the seed points are static If either are non static, then this step is skipped. This takes into account that the "seeds" may just be restarted particles.
