vtkImageSimpleSource Class Reference
Create a 3-D image with simple-to-compute pixel values. More...
#include <vtkImageSimpleSource.h>
Inheritance diagram for vtkImageSimpleSource:
Collaboration diagram for vtkImageSimpleSource:
typedef vtkThreadedImageAlgorithm Superclass
- Public Types inherited from vtkThreadedImageAlgorithm
typedef vtkImageAlgorithm Superclass
- Public Types inherited from vtkImageAlgorithm
enum  DesiredOutputPrecision
virtual int * GetWholeExtent ()
 Set/Get the extent of the whole output image. More...
virtual void GetWholeExtent (int &, int &, int &, int &, int &, int &)
virtual void GetWholeExtent (int[6])
void SetWholeExtent (int xMinx, int xMax, int yMin, int yMax, int zMin, int zMax)
virtual bool GetEnableDistanceSquaredData ()
 Enable/Disable DistanceSquared data array. More...
virtual void SetEnableDistanceSquaredData (bool)
virtual void EnableDistanceSquaredDataOn ()
virtual void EnableDistanceSquaredDataOff ()
virtual bool GetEnableSwirlData ()
 Enable/Disable Swirl data array. More...
virtual void SetEnableSwirlData (bool)
virtual void EnableSwirlDataOn ()
virtual void EnableSwirlDataOff ()
- Public Member Functions inherited from vtkThreadedImageAlgorithm
vtkThreadedImageAlgorithm * NewInstance () const
virtual void ThreadedExecute (vtkImageData *inData, vtkImageData *outData, int extent[6], int threadId)
virtual bool GetEnableSMP ()
virtual void SetEnableSMP (bool)
virtual void SetMinimumPieceSize (int, int, int)
virtual void SetMinimumPieceSize (int[3])
virtual int * GetMinimumPieceSize ()
virtual void GetMinimumPieceSize (int &, int &, int &)
virtual void GetMinimumPieceSize (int[3])
virtual void SetDesiredBytesPerPiece (vtkIdType)
virtual vtkIdType GetDesiredBytesPerPiece ()
virtual void SetSplitMode (int)
void SetSplitModeToSlab ()
void SetSplitModeToBeam ()
void SetSplitModeToBlock ()
virtual int GetSplitMode ()
virtual void SetNumberOfThreads (int)
virtual int GetNumberOfThreads ()
virtual int SplitExtent (int splitExt[6], int startExt[6], int num, int total)
- Public Member Functions inherited from vtkImageAlgorithm
vtkImageAlgorithm * NewInstance () const
vtkImageData * GetOutput ()
vtkImageData * GetOutput (int)
vtkDataObject * GetInput ()
vtkImageData * GetImageDataInput (int port)
virtual void AddInputData (vtkDataObject *)
virtual void AddInputData (int, vtkDataObject *)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkImageSimpleSource * New ()
static vtkImageSimpleSource * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkThreadedImageAlgorithm
static vtkThreadedImageAlgorithm * SafeDownCast (vtkObjectBase *o)
static void SetGlobalDefaultEnableSMP (bool enable)
static bool GetGlobalDefaultEnableSMP ()
- Static Public Member Functions inherited from vtkImageAlgorithm
static vtkImageAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkImageSimpleSource ()
 ~vtkImageSimpleSource () override=default
void PrepareImageData (vtkInformationVector **inputVector, vtkInformationVector *outputVector, vtkImageData ***inDataObjects=nullptr, vtkImageData **outDataObjects=nullptr) override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
void ThreadedRequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector, vtkImageData ***inData, vtkImageData **outData, int extent[6], int threadId) override
- Protected Member Functions inherited from vtkThreadedImageAlgorithm
 vtkThreadedImageAlgorithm ()
 ~vtkThreadedImageAlgorithm ()
virtual int RequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
virtual void SMPRequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector, vtkImageData ***inData, vtkImageData **outData, vtkIdType begin, vtkIdType end, vtkIdType pieces, int extent[6])
- Protected Member Functions inherited from vtkImageAlgorithm
 vtkImageAlgorithm ()
 ~vtkImageAlgorithm ()
virtual void CopyInputArrayAttributesToOutput (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
virtual void ExecuteDataWithInformation (vtkDataObject *output, vtkInformation *outInfo)
virtual void ExecuteData (vtkDataObject *output)
virtual void Execute ()
virtual void AllocateOutputData (vtkImageData *out, vtkInformation *outInfo, int *uExtent)
virtual vtkImageData * AllocateOutputData (vtkDataObject *out, vtkInformation *outInfo)
virtual void CopyAttributeData (vtkImageData *in, vtkImageData *out, vtkInformationVector **inputVector)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
bool EnableDistanceSquaredData
bool EnableSwirlData
int FirstIndex [3]
int WholeExtent [6]
- Protected Attributes inherited from vtkThreadedImageAlgorithm
 SLAB
 BEAM
 BLOCK
vtkMultiThreader * Threader
int NumberOfThreads
bool EnableSMP
int SplitMode
int SplitPath [3]
int SplitPathLength
int MinimumPieceSize [3]
vtkIdType DesiredBytesPerPiece
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Types inherited from vtkThreadedImageAlgorithm
enum  SplitModeEnum
- Static Protected Attributes inherited from vtkThreadedImageAlgorithm
static bool GlobalDefaultEnableSMP
vtkImageSimpleSource produces images with pixel values that can be obtained with relatively low computational load. The output point data contains 1-3 arrays:
Definition at line 29 of file vtkImageSimpleSource.h.
Definition at line 34 of file vtkImageSimpleSource.h.
◆ vtkImageSimpleSource()
vtkImageSimpleSource::vtkImageSimpleSource ( )
◆ ~vtkImageSimpleSource()
vtkImageSimpleSource::~vtkImageSimpleSource ( )
overrideprotecteddefault
static vtkImageSimpleSource* vtkImageSimpleSource::New ( )
virtual const char* vtkImageSimpleSource::GetClassName ( )
static int vtkImageSimpleSource::IsTypeOf ( const char *  type)
virtual int vtkImageSimpleSource::IsA ( const char *  type)
Reimplemented from vtkThreadedImageAlgorithm.
static vtkImageSimpleSource* vtkImageSimpleSource::SafeDownCast ( vtkObject *  o)
void vtkImageSimpleSource::PrintSelf ( ostream &  os,
◆ GetWholeExtent() [1/3]
virtual int* vtkImageSimpleSource::GetWholeExtent ( )
◆ GetWholeExtent() [2/3]
virtual void vtkImageSimpleSource::GetWholeExtent ( int &  ,
int &  ,
int &  ,
int &  ,
int &  ,
int &
◆ GetWholeExtent() [3/3]
virtual void vtkImageSimpleSource::GetWholeExtent ( int  [6])
◆ SetWholeExtent()
void vtkImageSimpleSource::SetWholeExtent ( int  xMinx,
int  xMax,
int  yMin,
int  yMax,
int  zMin,
int  zMax
◆ GetEnableDistanceSquaredData()
virtual bool vtkImageSimpleSource::GetEnableDistanceSquaredData ( )
◆ SetEnableDistanceSquaredData()
virtual void vtkImageSimpleSource::SetEnableDistanceSquaredData ( bool  )
◆ EnableDistanceSquaredDataOn()
virtual void vtkImageSimpleSource::EnableDistanceSquaredDataOn ( )
◆ EnableDistanceSquaredDataOff()
virtual void vtkImageSimpleSource::EnableDistanceSquaredDataOff ( )
◆ GetEnableSwirlData()
virtual bool vtkImageSimpleSource::GetEnableSwirlData ( )
◆ SetEnableSwirlData()
virtual void vtkImageSimpleSource::SetEnableSwirlData ( bool  )
◆ EnableSwirlDataOn()
virtual void vtkImageSimpleSource::EnableSwirlDataOn ( )
◆ EnableSwirlDataOff()
virtual void vtkImageSimpleSource::EnableSwirlDataOff ( )
◆ PrepareImageData()
void vtkImageSimpleSource::PrepareImageData ( vtkInformationVector **  inputVector,
vtkInformationVector *  outputVector,
vtkImageData ***  inDataObjects = nullptr,
vtkImageData **  outDataObjects = nullptr
overrideprotectedvirtual
◆ RequestInformation()
int vtkImageSimpleSource::RequestInformation ( vtkInformation *  request,
Reimplemented from vtkImageAlgorithm.
◆ ThreadedRequestData()
void vtkImageSimpleSource::ThreadedRequestData ( vtkInformation *  request,
vtkImageData ***  inData,
vtkImageData **  outData,
int  extent[6],
int  threadId
bool vtkImageSimpleSource::EnableDistanceSquaredData
Definition at line 61 of file vtkImageSimpleSource.h.
◆ EnableSwirlData
bool vtkImageSimpleSource::EnableSwirlData
Definition at line 62 of file vtkImageSimpleSource.h.
◆ FirstIndex
int vtkImageSimpleSource::FirstIndex[3]
Definition at line 63 of file vtkImageSimpleSource.h.
◆ WholeExtent
int vtkImageSimpleSource::WholeExtent[6]
Definition at line 64 of file vtkImageSimpleSource.h.
