Keeper of constants for IceT classes. More...
#include <vtkIceTConstants.h>
| enum | StrategyType { DEFAULT = 0, REDUCE = 1, VTREE = 2, SPLIT = 3, SEQUENTIAL = 4, DIRECT = 5 } |
| enum | ComposeOperationType { ComposeOperationClosest = 0, ComposeOperationOver = 1 } |
vtkIceTConstants is not really meant to be used as a class. Rather, it simply holds constants that can be used with the IceT classes. These constants are defined outside of the vtkIceTRenderManager and vtkOpenGLIceTRenderer definitions so that they can be accessed when the IceT implementation classes are not compiled. Because ParaView is designed to run client/server and because the server should be able to use its IceT implementation even when the client is not compiled with IceT. In this case, the client needs to send flags to the server.
Those flags are defined here. This class does not have any dependence on any MPI or IceT libraries, so can be used on either client or server.
Definition at line 31 of file vtkIceTConstants.h.
| Enumerator | |
| DEFAULT | |
| REDUCE | |
| VTREE | |
| SPLIT | |
| SEQUENTIAL | |
| DIRECT | |
Definition at line 34 of file vtkIceTConstants.h.
| Enumerator | |
| ComposeOperationClosest | |
| ComposeOperationOver | |
Definition at line 44 of file vtkIceTConstants.h.
