vtkIceTCompositePass Class Reference
IceT enabled render pass for distributed rendering. More...
#include <vtkIceTCompositePass.h>
Inheritance diagram for vtkIceTCompositePass:
Collaboration diagram for vtkIceTCompositePass:
typedef vtkRenderPass Superclass
- Public Types inherited from vtkRenderPass
void Render (const vtkRenderState *s) override
 Perform rendering according to a render state s. More...
void ReleaseGraphicsResources (vtkWindow *w) override
 Release graphics resources and ask components to release their own resources. More...
void GetLastRenderedTile (vtkSynchronizedRenderers::vtkRawImage &tile)
 Returns the last rendered tile from this process, if any. More...
vtkFloatArray * GetLastRenderedDepths ()
 Provides access to the last rendered depth-buffer, if any. More...
vtkFloatArray * GetLastRenderedRGBA32F ()
 Provides access to the last rendered float image in vtkValuePass, if any. More...
void PushIceTDepthBufferToScreen (const vtkRenderState *render_state)
 Obtains the composited depth-buffer from IceT and pushes it to the screen. More...
 Controller If it is nullptr, nothing will be rendered and a warning will be emitted. More...
virtual void SetController (vtkMultiProcessController *controller)
void SetRenderPass (vtkRenderPass *)
 Get/Set the render pass used to do the actual rendering. More...
virtual vtkRenderPass * GetRenderPass ()
virtual void SetTileDimensions (int, int)
 Get/Set the tile dimensions. More...
void SetTileDimensions (int[2])
virtual int * GetTileDimensions ()
virtual void GetTileDimensions (int &, int &)
virtual void GetTileDimensions (int[2])
virtual void SetTileMullions (int, int)
 Get/Set the tile mullions. More...
void SetTileMullions (int[2])
virtual int * GetTileMullions ()
virtual void GetTileMullions (int &, int &)
virtual void GetTileMullions (int[2])
virtual void SetDataReplicatedOnAllProcesses (bool)
 Set to true if data is replicated on all processes. More...
virtual bool GetDataReplicatedOnAllProcesses ()
virtual void DataReplicatedOnAllProcessesOn ()
virtual void DataReplicatedOnAllProcessesOff ()
virtual void SetImageReductionFactor (int)
 Set the image reduction factor. More...
virtual int GetImageReductionFactor ()
virtual vtkOrderedCompositingHelper * GetOrderedCompositingHelper ()
 partition ordering that gives processes ordering. More...
virtual void SetOrderedCompositingHelper (vtkOrderedCompositingHelper *helper)
virtual bool GetRenderEmptyImages ()
 Enable/disable rendering of empty images. More...
virtual void SetRenderEmptyImages (bool)
virtual void RenderEmptyImagesOn ()
virtual void RenderEmptyImagesOff ()
virtual bool GetUseOrderedCompositing ()
 Set this to true, if compositing must be done in a specific order. More...
virtual void SetUseOrderedCompositing (bool)
virtual void UseOrderedCompositingOn ()
virtual void UseOrderedCompositingOff ()
virtual void SetEnableFloatValuePass (bool)
 Adjusts this pass to handle vtkValuePass::FLOATING_POINT, in which floating- point values are rendered to vtkValuePass's internal FBO. More...
virtual void SetDisplayRGBAResults (bool)
 When set to true, vtkIceTCompositePass will push back compositing results to the display on ranks where the IceT generated a composited result. More...
virtual bool GetDisplayRGBAResults ()
virtual void SetDisplayDepthResults (bool)
virtual bool GetDisplayDepthResults ()
void Draw (const vtkRenderState *render_state, const IceTDrawParams &)
- Public Member Functions inherited from vtkRenderPass
vtkRenderPass * NewInstance () const
virtual int GetNumberOfRenderedProps ()
static vtkIceTCompositePass * New ()
static vtkIceTCompositePass * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkRenderPass
static vtkRenderPass * SafeDownCast (vtkObjectBase *o)
 vtkIceTCompositePass ()
 ~vtkIceTCompositePass () override
void ReadyProgram (vtkOpenGLRenderWindow *context)
 Create program (if needed) and prepare it for texture mapping. More...
void UpdateTileInformation (const vtkRenderState *)
 Updates the IceT tile information during each render. More...
void DisplayResultsIfNeeded (const vtkRenderState *)
 Called after Icet results have been generated. More...
void UpdateMatrices (const vtkRenderState *, double aspect)
 Update projection and model view matrices using current camera and provided aspect ratio. More...
virtual void SetupContext (const vtkRenderState *)
 Spits the different components for the rendering process. More...
virtual void CleanupContext (const vtkRenderState *)
- Protected Member Functions inherited from vtkRenderPass
 vtkRenderPass ()
virtual ~vtkRenderPass ()
void UpdateCamera (vtkRenderer *renderer)
void ClearLights (vtkRenderer *renderer)
void UpdateLightGeometry (vtkRenderer *renderer)
void UpdateLights (vtkRenderer *renderer)
void UpdateGeometry (vtkRenderer *renderer)
void SetLastRenderingUsedDepthPeeling (vtkRenderer *renderer, bool value)
vtkOrderedCompositingHelper * OrderedCompositingHelper
vtkRenderPass * RenderPass
vtkIceTContext * IceTContext
bool RenderEmptyImages
bool UseOrderedCompositing
bool DataReplicatedOnAllProcesses
bool EnableFloatValuePass
int TileDimensions [2]
int TileMullions [2]
int ImageReductionFactor
bool DisplayRGBAResults
bool DisplayDepthResults
vtkNew< vtkFloatArray > LastRenderedDepths
vtkNew< vtkFloatArray > LastRenderedRGBA32F
vtkPixelBufferObject * PBO
vtkTextureObject * ZTexture
vtkOpenGLHelper * Program
std::unique_ptr< vtkSynchronizedRenderers::vtkRawImage > LastRenderedRGBAColors
- Protected Attributes inherited from vtkRenderPass
int NumberOfRenderedProps
vtkIceTCompositePass is a vtkRenderPass subclass that can be used for compositing images (RGBA_UBYTE, depth or RGBA_32F) across processes using IceT. This can be used in lieu of vtkCompositeRGBAPass. The usage of this pass differs slightly from vtkCompositeRGBAPass. vtkCompositeRGBAPass composites the active frame buffer, while this class requires that the render pass to render info the frame buffer that needs to be composited should be set as an ivar using SetRenderPass().
This class also provides support for tile-displays. Simply set the TileDimensions > [1, 1] and instead of rendering a composited image on the root node, it will split the view among all tiles and generate renderings on all processes.
Warning: Compositing RGBA_32F is only supported for a specific pass (vtkValuePass). For a more generic integration, vtkRenderPass should expose an internal FBO API.
Definition at line 46 of file vtkIceTCompositePass.h.
Definition at line 50 of file vtkIceTCompositePass.h.
◆ vtkIceTCompositePass()
vtkIceTCompositePass::vtkIceTCompositePass ( )
◆ ~vtkIceTCompositePass()
vtkIceTCompositePass::~vtkIceTCompositePass ( )
static vtkIceTCompositePass* vtkIceTCompositePass::New ( )
virtual const char* vtkIceTCompositePass::GetClassName ( )
static int vtkIceTCompositePass::IsTypeOf ( const char *  type)
virtual int vtkIceTCompositePass::IsA ( const char *  type)
Reimplemented from vtkRenderPass.
static vtkIceTCompositePass* vtkIceTCompositePass::SafeDownCast ( vtkObject *  o)
void vtkIceTCompositePass::PrintSelf ( ostream &  os,
◆ Render()
void vtkIceTCompositePass::Render ( const vtkRenderState *  s)
Precondition
s_exists: s!=0
Implements vtkRenderPass.
◆ ReleaseGraphicsResources()
void vtkIceTCompositePass::ReleaseGraphicsResources ( vtkWindow *  w)
Precondition
w_exists: w!=0
◆ GetController()
virtual vtkMultiProcessController* vtkIceTCompositePass::GetController ( )
Initial value is a nullptr pointer.
◆ SetController()
virtual void vtkIceTCompositePass::SetController ( vtkMultiProcessController *  controller)
◆ SetRenderPass()
void vtkIceTCompositePass::SetRenderPass ( vtkRenderPass *  )
The result of this delete pass is what gets composited using IceT. Initial value is a nullptr pointer.
◆ GetRenderPass()
virtual vtkRenderPass* vtkIceTCompositePass::GetRenderPass ( )
◆ SetTileDimensions() [1/2]
virtual void vtkIceTCompositePass::SetTileDimensions ( int  ,
int
Default is (1, 1). If any of the dimensions is
1 than tile display mode is assumed.
◆ SetTileDimensions() [2/2]
void vtkIceTCompositePass::SetTileDimensions ( int  [2])
◆ GetTileDimensions() [1/3]
virtual int* vtkIceTCompositePass::GetTileDimensions ( )
◆ GetTileDimensions() [2/3]
virtual void vtkIceTCompositePass::GetTileDimensions ( int &  ,
int &
◆ GetTileDimensions() [3/3]
virtual void vtkIceTCompositePass::GetTileDimensions ( int  [2])
◆ SetTileMullions() [1/2]
virtual void vtkIceTCompositePass::SetTileMullions ( int  ,
int
The mullions are measured in pixels. Use negative numbers for overlap. Initial value is {0,0}.
◆ SetTileMullions() [2/2]
void vtkIceTCompositePass::SetTileMullions ( int  [2])
◆ GetTileMullions() [1/3]
virtual int* vtkIceTCompositePass::GetTileMullions ( )
◆ GetTileMullions() [2/3]
virtual void vtkIceTCompositePass::GetTileMullions ( int &  ,
int &
◆ GetTileMullions() [3/3]
virtual void vtkIceTCompositePass::GetTileMullions ( int  [2])
◆ SetDataReplicatedOnAllProcesses()
virtual void vtkIceTCompositePass::SetDataReplicatedOnAllProcesses ( bool  )
This will enable IceT to minimize communications since data is available on all process. Off by default. Initial value is false.
◆ GetDataReplicatedOnAllProcesses()
virtual bool vtkIceTCompositePass::GetDataReplicatedOnAllProcesses ( )
◆ DataReplicatedOnAllProcessesOn()
virtual void vtkIceTCompositePass::DataReplicatedOnAllProcessesOn ( )
◆ DataReplicatedOnAllProcessesOff()
virtual void vtkIceTCompositePass::DataReplicatedOnAllProcessesOff ( )
◆ SetImageReductionFactor()
virtual void vtkIceTCompositePass::SetImageReductionFactor ( int  )
This can be used to speed up compositing. When using vtkIceTCompositePass use this image reduction factor rather than that on vtkSynchronizedRenderers since using vtkSynchronizedRenderers::ImageReductionFactor will not work correctly with IceT. Initial value is 1.
◆ GetImageReductionFactor()
virtual int vtkIceTCompositePass::GetImageReductionFactor ( )
◆ GetOrderedCompositingHelper()
virtual vtkOrderedCompositingHelper* vtkIceTCompositePass::GetOrderedCompositingHelper ( )
Initial value is a nullptr pointer. This is used only when UseOrderedCompositing is true.
◆ SetOrderedCompositingHelper()
virtual void vtkIceTCompositePass::SetOrderedCompositingHelper ( vtkOrderedCompositingHelper *  helper)
◆ GetRenderEmptyImages()
virtual bool vtkIceTCompositePass::GetRenderEmptyImages ( )
Painters that use MPI global collective communication need to enable this. Initial value is false.
◆ SetRenderEmptyImages()
virtual void vtkIceTCompositePass::SetRenderEmptyImages ( bool  )
◆ RenderEmptyImagesOn()
virtual void vtkIceTCompositePass::RenderEmptyImagesOn ( )
◆ RenderEmptyImagesOff()
virtual void vtkIceTCompositePass::RenderEmptyImagesOff ( )
◆ GetUseOrderedCompositing()
virtual bool vtkIceTCompositePass::GetUseOrderedCompositing ( )
This is necessary when rendering volumes or translucent geometries. When UseOrderedCompositing is set to true, it is expected that the OrderedCompositingHelper is set as well. OrderedCompositingHelper is used to decide the process-order for compositing. Initial value is false.
◆ SetUseOrderedCompositing()
virtual void vtkIceTCompositePass::SetUseOrderedCompositing ( bool  )
◆ UseOrderedCompositingOn()
virtual void vtkIceTCompositePass::UseOrderedCompositingOn ( )
◆ UseOrderedCompositingOff()
virtual void vtkIceTCompositePass::UseOrderedCompositingOff ( )
◆ GetLastRenderedTile()
void vtkIceTCompositePass::GetLastRenderedTile ( vtkSynchronizedRenderers::vtkRawImage &  tile)
Image is invalid if tile is not available on the current process.
◆ GetLastRenderedDepths()
vtkFloatArray* vtkIceTCompositePass::GetLastRenderedDepths ( )
May return nullptr if depth buffer was not composited and available on the current rank.
◆ SetEnableFloatValuePass()
virtual void vtkIceTCompositePass::SetEnableFloatValuePass ( bool  )
◆ GetLastRenderedRGBA32F()
vtkFloatArray* vtkIceTCompositePass::GetLastRenderedRGBA32F ( )
May return nullptr if a float image was not composited and is not available on the current rank.
◆ PushIceTDepthBufferToScreen()
void vtkIceTCompositePass::PushIceTDepthBufferToScreen ( const vtkRenderState *  render_state)
This is only done when DepthOnly is true.
◆ SetDisplayRGBAResults()
virtual void vtkIceTCompositePass::SetDisplayRGBAResults ( bool  )
Generally speaking, for a vtkRenderPass, this must always be true. However, for ParaView use cases many times we display the compositing result on the server-side. In which case, we can save on the extra work to push results to screen. Hence, vtkIceTCompositePass sets this to false by default.
◆ GetDisplayRGBAResults()
virtual bool vtkIceTCompositePass::GetDisplayRGBAResults ( )
◆ SetDisplayDepthResults()
virtual void vtkIceTCompositePass::SetDisplayDepthResults ( bool  )
◆ GetDisplayDepthResults()
virtual bool vtkIceTCompositePass::GetDisplayDepthResults ( )
◆ Draw()
void vtkIceTCompositePass::Draw ( const vtkRenderState *  render_state,
◆ SetupContext()
virtual void vtkIceTCompositePass::SetupContext ( const vtkRenderState *  )
protectedvirtual
◆ CleanupContext()
virtual void vtkIceTCompositePass::CleanupContext ( const vtkRenderState *  )
protectedvirtual
◆ ReadyProgram()
void vtkIceTCompositePass::ReadyProgram ( vtkOpenGLRenderWindow *  context)
Precondition
context_exists: context!=0
Postcondition
Program_exists: this->Program!=0
◆ UpdateTileInformation()
void vtkIceTCompositePass::UpdateTileInformation ( const vtkRenderState *  )
◆ DisplayResultsIfNeeded()
void vtkIceTCompositePass::DisplayResultsIfNeeded ( const vtkRenderState *  )
vtkIceTCompositePass will paste back the IceT results image to the viewport if so requested by DisplayDepthResults and DisplayRGBAResults flags.
◆ UpdateMatrices()
void vtkIceTCompositePass::UpdateMatrices ( const vtkRenderState *  ,
double  aspect
◆ Controller
vtkMultiProcessController* vtkIceTCompositePass::Controller
Definition at line 257 of file vtkIceTCompositePass.h.
◆ OrderedCompositingHelper
vtkOrderedCompositingHelper* vtkIceTCompositePass::OrderedCompositingHelper
Definition at line 258 of file vtkIceTCompositePass.h.
◆ RenderPass
vtkRenderPass* vtkIceTCompositePass::RenderPass
Definition at line 259 of file vtkIceTCompositePass.h.
◆ IceTContext
vtkIceTContext* vtkIceTCompositePass::IceTContext
Definition at line 260 of file vtkIceTCompositePass.h.
◆ RenderEmptyImages
bool vtkIceTCompositePass::RenderEmptyImages
Definition at line 262 of file vtkIceTCompositePass.h.
bool vtkIceTCompositePass::UseOrderedCompositing
Definition at line 263 of file vtkIceTCompositePass.h.
bool vtkIceTCompositePass::DataReplicatedOnAllProcesses
Definition at line 264 of file vtkIceTCompositePass.h.
◆ EnableFloatValuePass
bool vtkIceTCompositePass::EnableFloatValuePass
Definition at line 265 of file vtkIceTCompositePass.h.
◆ TileDimensions
int vtkIceTCompositePass::TileDimensions[2]
Definition at line 266 of file vtkIceTCompositePass.h.
◆ TileMullions
int vtkIceTCompositePass::TileMullions[2]
Definition at line 267 of file vtkIceTCompositePass.h.
◆ ImageReductionFactor
int vtkIceTCompositePass::ImageReductionFactor
Definition at line 269 of file vtkIceTCompositePass.h.
◆ DisplayRGBAResults
bool vtkIceTCompositePass::DisplayRGBAResults
Definition at line 271 of file vtkIceTCompositePass.h.
◆ DisplayDepthResults
bool vtkIceTCompositePass::DisplayDepthResults
Definition at line 272 of file vtkIceTCompositePass.h.
◆ LastRenderedDepths
vtkNew<vtkFloatArray> vtkIceTCompositePass::LastRenderedDepths
Definition at line 274 of file vtkIceTCompositePass.h.
◆ LastRenderedRGBA32F
vtkNew<vtkFloatArray> vtkIceTCompositePass::LastRenderedRGBA32F
Definition at line 276 of file vtkIceTCompositePass.h.
◆ PBO
vtkPixelBufferObject* vtkIceTCompositePass::PBO
Definition at line 278 of file vtkIceTCompositePass.h.
◆ ZTexture
vtkTextureObject* vtkIceTCompositePass::ZTexture
Definition at line 279 of file vtkIceTCompositePass.h.
◆ Program
vtkOpenGLHelper* vtkIceTCompositePass::Program
Definition at line 280 of file vtkIceTCompositePass.h.
◆ LastRenderedRGBAColors
std::unique_ptr<vtkSynchronizedRenderers::vtkRawImage> vtkIceTCompositePass::LastRenderedRGBAColors
Definition at line 282 of file vtkIceTCompositePass.h.
