vtkFileSequenceParser Class Reference
Parses out the base file name of a file sequence and also the specific index of the given file. More...
#include <vtkFileSequenceParser.h>
Inheritance diagram for vtkFileSequenceParser:
Collaboration diagram for vtkFileSequenceParser:
bool ParseFileSequence (const char *file)
 Extract base file name sequence from the file. More...
virtual char * GetSequenceName ()
 Getter to use to get the sequence name after calling ParseFileSequence. More...
virtual int GetSequenceIndex ()
 Getter to use to get the sequence index after calling ParseFileSequence. More...
virtual std::string GetSequenceIndexString ()
 Getter to use to get the sequence index string after calling ParseFileSequence. More...
static vtkFileSequenceParser * New ()
static vtkFileSequenceParser * SafeDownCast (vtkObject *o)
 vtkFileSequenceParser ()
 ~vtkFileSequenceParser () override
virtual void SetSequenceName (const char *)
vtksys::RegularExpression * reg_ex
vtksys::RegularExpression * reg_ex2
vtksys::RegularExpression * reg_ex3
vtksys::RegularExpression * reg_ex4
vtksys::RegularExpression * reg_ex5
vtksys::RegularExpression * reg_ex_last
int SequenceIndex
char * SequenceName
std::string SequenceIndexString
Given a file name (without path). I will extract the base portion of the file name that is common to all the files in the sequence. It will also provide the current sequence index of the provided file name. by several vtkPVUpdateSuppressor objects.
Definition at line 28 of file vtkFileSequenceParser.h.
Definition at line 32 of file vtkFileSequenceParser.h.
◆ vtkFileSequenceParser()
vtkFileSequenceParser::vtkFileSequenceParser ( )
◆ ~vtkFileSequenceParser()
vtkFileSequenceParser::~vtkFileSequenceParser ( )
static vtkFileSequenceParser* vtkFileSequenceParser::New ( )
virtual const char* vtkFileSequenceParser::GetClassName ( )
static int vtkFileSequenceParser::IsTypeOf ( const char *  type)
virtual int vtkFileSequenceParser::IsA ( const char *  type)
static vtkFileSequenceParser* vtkFileSequenceParser::SafeDownCast ( vtkObject *  o)
void vtkFileSequenceParser::PrintSelf ( ostream &  os,
◆ ParseFileSequence()
bool vtkFileSequenceParser::ParseFileSequence ( const char *  file)
Returns true if a sequence is detected and sets SequenceName and SequenceIndex.
◆ GetSequenceName()
virtual char* vtkFileSequenceParser::GetSequenceName ( )
◆ GetSequenceIndex()
virtual int vtkFileSequenceParser::GetSequenceIndex ( )
◆ GetSequenceIndexString()
virtual std::string vtkFileSequenceParser::GetSequenceIndexString ( )
It can be useful when sequence index is duplicated.
◆ SetSequenceName()
virtual void vtkFileSequenceParser::SetSequenceName ( const char *  )
protectedvirtual
◆ reg_ex
vtksys::RegularExpression* vtkFileSequenceParser::reg_ex
Definition at line 65 of file vtkFileSequenceParser.h.
◆ reg_ex2
vtksys::RegularExpression* vtkFileSequenceParser::reg_ex2
Definition at line 66 of file vtkFileSequenceParser.h.
◆ reg_ex3
vtksys::RegularExpression* vtkFileSequenceParser::reg_ex3
Definition at line 67 of file vtkFileSequenceParser.h.
◆ reg_ex4
vtksys::RegularExpression* vtkFileSequenceParser::reg_ex4
Definition at line 68 of file vtkFileSequenceParser.h.
◆ reg_ex5
vtksys::RegularExpression* vtkFileSequenceParser::reg_ex5
Definition at line 69 of file vtkFileSequenceParser.h.
◆ reg_ex_last
vtksys::RegularExpression* vtkFileSequenceParser::reg_ex_last
Definition at line 70 of file vtkFileSequenceParser.h.
◆ SequenceIndex
int vtkFileSequenceParser::SequenceIndex
Definition at line 73 of file vtkFileSequenceParser.h.
◆ SequenceName
char* vtkFileSequenceParser::SequenceName
Definition at line 76 of file vtkFileSequenceParser.h.
◆ SequenceIndexString
std::string vtkFileSequenceParser::SequenceIndexString
Definition at line 77 of file vtkFileSequenceParser.h.
