vtkExtractSelectionRange Class Reference
compute the range of the input selection. More...
#include <vtkExtractSelectionRange.h>
Inheritance diagram for vtkExtractSelectionRange:
Collaboration diagram for vtkExtractSelectionRange:
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
virtual void SetArrayName (const char *)
 Set the name of the array used to compute the range. More...
virtual char * GetArrayName ()
virtual void SetFieldType (int)
 Set/Get the field type of the selection. More...
virtual int GetFieldType ()
virtual void SetComponent (int)
 Set/Get the component used to compute the range. More...
virtual int GetComponent ()
virtual double * GetRange ()
 Get the output range. More...
virtual void GetRange (double &, double &)
virtual void GetRange (double[2])
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithm * NewInstance () const
vtkTable * GetOutput ()
vtkTable * GetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkExtractSelectionRange * New ()
static vtkExtractSelectionRange * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithm * New ()
static vtkTableAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkExtractSelectionRange ()
 ~vtkExtractSelectionRange () override
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int FieldType
int Component
char * ArrayName
double Range [2]
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkExtractSelectionRange is used to compute the range of an input selection. This is an internal filter designed to be used to "compute visible range" for a dataset.
Definition at line 18 of file vtkExtractSelectionRange.h.
Definition at line 22 of file vtkExtractSelectionRange.h.
◆ vtkExtractSelectionRange()
vtkExtractSelectionRange::vtkExtractSelectionRange ( )
◆ ~vtkExtractSelectionRange()
vtkExtractSelectionRange::~vtkExtractSelectionRange ( )
static vtkExtractSelectionRange* vtkExtractSelectionRange::New ( )
virtual const char* vtkExtractSelectionRange::GetClassName ( )
static int vtkExtractSelectionRange::IsTypeOf ( const char *  type)
virtual int vtkExtractSelectionRange::IsA ( const char *  type)
Reimplemented from vtkTableAlgorithm.
static vtkExtractSelectionRange* vtkExtractSelectionRange::SafeDownCast ( vtkObject *  o)
void vtkExtractSelectionRange::PrintSelf ( ostream &  os,
◆ SetArrayName()
virtual void vtkExtractSelectionRange::SetArrayName ( const char *  )
◆ GetArrayName()
virtual char* vtkExtractSelectionRange::GetArrayName ( )
◆ SetFieldType()
virtual void vtkExtractSelectionRange::SetFieldType ( int  )
◆ GetFieldType()
virtual int vtkExtractSelectionRange::GetFieldType ( )
◆ SetComponent()
virtual void vtkExtractSelectionRange::SetComponent ( int  )
◆ GetComponent()
virtual int vtkExtractSelectionRange::GetComponent ( )
◆ GetRange() [1/3]
virtual double* vtkExtractSelectionRange::GetRange ( )
◆ GetRange() [2/3]
virtual void vtkExtractSelectionRange::GetRange ( double &  ,
double &
◆ GetRange() [3/3]
virtual void vtkExtractSelectionRange::GetRange ( double  [2])
◆ FillInputPortInformation()
int vtkExtractSelectionRange::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ RequestData()
int vtkExtractSelectionRange::RequestData ( vtkInformation *  request,
◆ FieldType
int vtkExtractSelectionRange::FieldType
Definition at line 64 of file vtkExtractSelectionRange.h.
◆ Component
int vtkExtractSelectionRange::Component
Definition at line 65 of file vtkExtractSelectionRange.h.
◆ ArrayName
char* vtkExtractSelectionRange::ArrayName
Definition at line 66 of file vtkExtractSelectionRange.h.
◆ Range
double vtkExtractSelectionRange::Range[2]
Definition at line 67 of file vtkExtractSelectionRange.h.
