vtkEnsembleDataReader Class Reference
reader for ensemble data sets More...
#include <vtkEnsembleDataReader.h>
Inheritance diagram for vtkEnsembleDataReader:
Collaboration diagram for vtkEnsembleDataReader:
enum  DesiredOutputPrecision
std::string GetFilePath (unsigned int rowIndex) const
 Get the file path associated with the specified row of the meta data. More...
void SetReader (unsigned int rowIndex, vtkAlgorithm *reader)
 Set the file reader for the specified row of data. More...
void ResetReaders ()
 Removes all readers set using SetReader(). More...
bool UpdateMetaData ()
 Use this method to update the meta data, if needed. More...
 Set/Get the filename of the ensemble (.pve extension). More...
virtual char * GetFileName ()
virtual void SetCurrentMember (unsigned int)
 Set/Get the current ensemble member to process. More...
virtual unsigned int GetCurrentMember ()
unsigned int GetNumberOfMembers () const
 Returns the number of ensemble members. More...
virtual unsigned int * GetCurrentMemberRange ()
virtual void GetCurrentMemberRange (unsigned int &, unsigned int &)
virtual void GetCurrentMemberRange (unsigned int[2])
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkEnsembleDataReader * New ()
static vtkEnsembleDataReader * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkEnsembleDataReader ()
 ~vtkEnsembleDataReader () override
int ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
vtkAlgorithm * GetCurrentReader ()
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
virtual int RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkEnsembleDataReader reads a collection of data sources from a metadata file (of extension .pve). 'pve' a simply CSV file with the last column being the relative filename and other columns for each of the variables in the ensemble.
Definition at line 22 of file vtkEnsembleDataReader.h.
Definition at line 26 of file vtkEnsembleDataReader.h.
◆ vtkEnsembleDataReader()
vtkEnsembleDataReader::vtkEnsembleDataReader ( )
◆ ~vtkEnsembleDataReader()
vtkEnsembleDataReader::~vtkEnsembleDataReader ( )
static vtkEnsembleDataReader* vtkEnsembleDataReader::New ( )
virtual const char* vtkEnsembleDataReader::GetClassName ( )
static int vtkEnsembleDataReader::IsTypeOf ( const char *  type)
virtual int vtkEnsembleDataReader::IsA ( const char *  type)
static vtkEnsembleDataReader* vtkEnsembleDataReader::SafeDownCast ( vtkObject *  o)
void vtkEnsembleDataReader::PrintSelf ( ostream &  os,
◆ SetFileName()
virtual void vtkEnsembleDataReader::SetFileName ( const char *  )
◆ GetFileName()
virtual char* vtkEnsembleDataReader::GetFileName ( )
◆ SetCurrentMember()
virtual void vtkEnsembleDataReader::SetCurrentMember ( unsigned int  )
◆ GetCurrentMember()
virtual unsigned int vtkEnsembleDataReader::GetCurrentMember ( )
◆ GetNumberOfMembers()
unsigned int vtkEnsembleDataReader::GetNumberOfMembers ( ) const
◆ GetCurrentMemberRange() [1/3]
virtual unsigned int* vtkEnsembleDataReader::GetCurrentMemberRange ( )
◆ GetCurrentMemberRange() [2/3]
virtual void vtkEnsembleDataReader::GetCurrentMemberRange ( unsigned int &  ,
unsigned int &
◆ GetCurrentMemberRange() [3/3]
virtual void vtkEnsembleDataReader::GetCurrentMemberRange ( unsigned int  [2])
◆ GetFilePath()
std::string vtkEnsembleDataReader::GetFilePath ( unsigned int  rowIndex) const
◆ SetReader()
void vtkEnsembleDataReader::SetReader ( unsigned int  rowIndex,
vtkAlgorithm *  reader
◆ ResetReaders()
void vtkEnsembleDataReader::ResetReaders ( )
◆ UpdateMetaData()
bool vtkEnsembleDataReader::UpdateMetaData ( )
This will only read the file again if cache is obsolete.
◆ ProcessRequest()
int vtkEnsembleDataReader::ProcessRequest ( vtkInformation *  ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ GetCurrentReader()
vtkAlgorithm* vtkEnsembleDataReader::GetCurrentReader ( )
