vtkDistributedTrivialProducer Class Reference
#include <vtkDistributedTrivialProducer.h>
Inheritance diagram for vtkDistributedTrivialProducer:
Collaboration diagram for vtkDistributedTrivialProducer:
typedef vtkPVTrivialProducer Superclass
- Public Types inherited from vtkPVTrivialProducer
typedef vtkTrivialProducer Superclass
- Public Types inherited from vtkTrivialProducer
enum  DesiredOutputPrecision
virtual void UpdateFromGlobal (const char *key)
 Update the current instance to use a previously registered global data object as current output. More...
- Public Member Functions inherited from vtkPVTrivialProducer
void SetOutput (vtkDataObject *output) override
 Set the data object that is "produced" by this producer. More...
virtual void SetOutput (vtkDataObject *output, double time)
 Set the output data object as well as time information for the requests. More...
int ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
 Process upstream/downstream requests trivially. More...
- Public Member Functions inherited from vtkTrivialProducer
vtkTrivialProducer * NewInstance () const
virtual void SetWholeExtent (int, int, int, int, int, int)
virtual void SetWholeExtent (int[6])
virtual int * GetWholeExtent ()
virtual void GetWholeExtent (int &, int &, int &, int &, int &, int &)
virtual void GetWholeExtent (int[6])
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkDistributedTrivialProducer * New ()
static vtkDistributedTrivialProducer * SafeDownCast (vtkObject *o)
static void SetGlobalOutput (const char *key, vtkDataObject *output)
 Provide a global method to store a data object across processes and allow a given instance of TrivialProducer to use it based on its registered key. More...
static void ReleaseGlobalOutput (const char *key)
 Release a given Global output if a valid key (not nullptr) is provided, otherwise the global output map will be cleared. More...
- Static Public Member Functions inherited from vtkPVTrivialProducer
static vtkPVTrivialProducer * New ()
static vtkPVTrivialProducer * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTrivialProducer
static vtkTrivialProducer * New ()
static vtkTrivialProducer * SafeDownCast (vtkObjectBase *o)
static void FillOutputDataInformation (vtkDataObject *output, vtkInformation *outInfo)
static vtkAlgorithm * New ()
 vtkDistributedTrivialProducer ()
 ~vtkDistributedTrivialProducer () override
- Protected Member Functions inherited from vtkPVTrivialProducer
 vtkPVTrivialProducer ()
 ~vtkPVTrivialProducer () override
- Protected Member Functions inherited from vtkTrivialProducer
 vtkTrivialProducer ()
 ~vtkTrivialProducer ()
virtual int FillInputPortInformation (int, vtkInformation *)
virtual int FillOutputPortInformation (int, vtkInformation *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Attributes inherited from vtkPVTrivialProducer
vtkPVTrivialProducerInternal * Internals
 Used to store any time step information. More...
- Protected Attributes inherited from vtkTrivialProducer
vtkDataObject * Output
int WholeExtent [6]
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
Extend vtkPVTrivialProducer to allow distributed code to easily populate a trivial producer with local DataObject while using a regular Proxy Model.
Definition at line 18 of file vtkDistributedTrivialProducer.h.
Definition at line 22 of file vtkDistributedTrivialProducer.h.
◆ vtkDistributedTrivialProducer()
vtkDistributedTrivialProducer::vtkDistributedTrivialProducer ( )
◆ ~vtkDistributedTrivialProducer()
vtkDistributedTrivialProducer::~vtkDistributedTrivialProducer ( )
static vtkDistributedTrivialProducer* vtkDistributedTrivialProducer::New ( )
virtual const char* vtkDistributedTrivialProducer::GetClassName ( )
Reimplemented from vtkPVTrivialProducer.
static int vtkDistributedTrivialProducer::IsTypeOf ( const char *  type)
virtual int vtkDistributedTrivialProducer::IsA ( const char *  type)
static vtkDistributedTrivialProducer* vtkDistributedTrivialProducer::SafeDownCast ( vtkObject *  o)
void vtkDistributedTrivialProducer::PrintSelf ( ostream &  os,
Reimplemented from vtkTrivialProducer.
◆ SetGlobalOutput()
static void vtkDistributedTrivialProducer::SetGlobalOutput ( const char *  key,
vtkDataObject *  output
◆ ReleaseGlobalOutput()
static void vtkDistributedTrivialProducer::ReleaseGlobalOutput ( const char *  key)
◆ UpdateFromGlobal()
virtual void vtkDistributedTrivialProducer::UpdateFromGlobal ( const char *  key)
