Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
vtkClientServerMoveData Class Reference
Moves data from the server root node to the client. More...
#include <vtkClientServerMoveData.h>
Inheritance diagram for vtkClientServerMoveData:
Collaboration diagram for vtkClientServerMoveData:
enum  ProcessTypes { AUTO = 0, SERVER = 1, CLIENT = 2 }
enum  DesiredOutputPrecision
virtual void SetOutputDataType (int)
 Controls the output type. More...
virtual int GetOutputDataType ()
virtual void SetWholeExtent (int, int, int, int, int, int)
 Controls the output WHOLE_EXTENT. More...
virtual void SetWholeExtent (int[6])
virtual int * GetWholeExtent ()
virtual void GetWholeExtent (int &, int &, int &, int &, int &, int &)
virtual void GetWholeExtent (int[6])
virtual void SetProcessType (int)
 Optionally, set the process type. More...
virtual int GetProcessType ()
void SetController (vtkMultiProcessController *)
 Get/Set the controller to use. More...
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkClientServerMoveData * New ()
static vtkClientServerMoveData * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
Protected Types
enum  Tags { HAS_DATA_OBJECT_TO_TRANSMIT = 23479, TRANSMIT_DATA_OBJECT = 23483 }
 vtkClientServerMoveData ()
 ~vtkClientServerMoveData () override
int RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
virtual int SendData (vtkDataObject *, vtkMultiProcessController *)
virtual vtkDataObject * ReceiveData (vtkMultiProcessController *)
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int OutputDataType
int WholeExtent [6]
int ProcessType
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This class moves all the input data available at the input on the root server node to the client node. If not in server-client mode, this filter behaves as a simple pass-through filter. This can work with any data type, the application does not need to set the output type before hand.
Warning
This filter may change the output in RequestData().
Definition at line 27 of file vtkClientServerMoveData.h.
Definition at line 32 of file vtkClientServerMoveData.h.
◆ ProcessTypes
Enumerator
AUTO
SERVER
CLIENT
Definition at line 81 of file vtkClientServerMoveData.h.
◆ Tags
Enumerator
Definition at line 111 of file vtkClientServerMoveData.h.
◆ vtkClientServerMoveData()
vtkClientServerMoveData::vtkClientServerMoveData ( )
◆ ~vtkClientServerMoveData()
vtkClientServerMoveData::~vtkClientServerMoveData ( )
static vtkClientServerMoveData* vtkClientServerMoveData::New ( )
virtual const char* vtkClientServerMoveData::GetClassName ( )
static int vtkClientServerMoveData::IsTypeOf ( const char *  type)
virtual int vtkClientServerMoveData::IsA ( const char *  type)
static vtkClientServerMoveData* vtkClientServerMoveData::SafeDownCast ( vtkObject *  o)
void vtkClientServerMoveData::PrintSelf ( ostream &  os,
◆ SetOutputDataType()
virtual void vtkClientServerMoveData::SetOutputDataType ( int  )
This is required because processes receiving data cannot know their output type in RequestDataObject without communicating with other processes. Since communicating with other processes in RequestDataObject is dangerous (can cause deadlock because it may happen out-of-sync), the application has to set the output type. The default is VTK_POLY_DATA. Make sure to call this before any pipeline updates occur.
◆ GetOutputDataType()
virtual int vtkClientServerMoveData::GetOutputDataType ( )
◆ SetWholeExtent() [1/2]
virtual void vtkClientServerMoveData::SetWholeExtent ( int  ,
int  ,
int  ,
int  ,
int  ,
int
This is required because processes receiving data cannot know their WHOLE_EXTENT in RequestInformation without communicating with other processes. Since communicating with other processes in RequestInformation is dangerous (can cause deadlock because it may happen out-of-sync), the application has to set the output type. Make sure to call this before any pipeline updates occur.
◆ SetWholeExtent() [2/2]
virtual void vtkClientServerMoveData::SetWholeExtent ( int  [6])
◆ GetWholeExtent() [1/3]
virtual int* vtkClientServerMoveData::GetWholeExtent ( )
◆ GetWholeExtent() [2/3]
virtual void vtkClientServerMoveData::GetWholeExtent ( int &  ,
int &  ,
int &  ,
int &  ,
int &  ,
int &
◆ GetWholeExtent() [3/3]
virtual void vtkClientServerMoveData::GetWholeExtent ( int  [6])
◆ SetProcessType()
virtual void vtkClientServerMoveData::SetProcessType ( int  )
If set to AUTO, then the process type is tried to be determined using the active connection.
◆ GetProcessType()
virtual int vtkClientServerMoveData::GetProcessType ( )
◆ SetController()
void vtkClientServerMoveData::SetController ( vtkMultiProcessController *  )
This is optional and needed only when ProcessType is set to something other than AUTO. If AUTO, then the controller is obtained from the active session.
◆ GetController()
virtual vtkMultiProcessController* vtkClientServerMoveData::GetController ( )
◆ FillInputPortInformation()
int vtkClientServerMoveData::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ RequestData()
int vtkClientServerMoveData::RequestData ( vtkInformation *  request,
◆ RequestDataObject()
int vtkClientServerMoveData::RequestDataObject ( vtkInformation *  request,
◆ RequestInformation()
int vtkClientServerMoveData::RequestInformation ( vtkInformation *  request,
◆ SendData()
virtual int vtkClientServerMoveData::SendData ( vtkDataObject *  ,
protectedvirtual
◆ ReceiveData()
virtual vtkDataObject* vtkClientServerMoveData::ReceiveData ( vtkMultiProcessController *  )
protectedvirtual
◆ OutputDataType
int vtkClientServerMoveData::OutputDataType
Definition at line 117 of file vtkClientServerMoveData.h.
◆ WholeExtent
int vtkClientServerMoveData::WholeExtent[6]
Definition at line 118 of file vtkClientServerMoveData.h.
◆ ProcessType
int vtkClientServerMoveData::ProcessType
Definition at line 119 of file vtkClientServerMoveData.h.
◆ Controller
vtkMultiProcessController* vtkClientServerMoveData::Controller
Definition at line 120 of file vtkClientServerMoveData.h.
