vtkAnnotateGlobalDataFilter Class Reference
filter for annotating with global / field data More...
#include <vtkAnnotateGlobalDataFilter.h>
Inheritance diagram for vtkAnnotateGlobalDataFilter:
Collaboration diagram for vtkAnnotateGlobalDataFilter:
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
virtual void SetFieldArrayName (const char *)
 Name of the field to display. More...
virtual char * GetFieldArrayName ()
virtual void SetPrefix (const char *)
 Set the text prefix to display in front of the Field value. More...
virtual char * GetPrefix ()
virtual void SetPostfix (const char *)
virtual char * GetPostfix ()
virtual void SetFormat (const char *)
 Set the format to use when displaying the field value. More...
virtual char * GetFormat ()
void SetController (vtkMultiProcessController *)
 Get/Set the controller to use. More...
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithm * NewInstance () const
vtkTable * GetOutput ()
vtkTable * GetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkAnnotateGlobalDataFilter * New ()
static vtkAnnotateGlobalDataFilter * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithm * New ()
static vtkTableAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkAnnotateGlobalDataFilter ()
 ~vtkAnnotateGlobalDataFilter () override
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
char * Prefix
char * Postfix
char * FieldArrayName
char * Format
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkAnnotateGlobalDataFilter is a filter that can be used to generate a vtkTable with a string that contains the contents of a global / field data array. It also supports extracting temporal field data arrays that vtkExodusIIReader produces for "global-data". These are simply arrays that have as many tuples are number of timesteps. The filter then extracts only the tuple associated with the current time-step.
Definition at line 23 of file vtkAnnotateGlobalDataFilter.h.
Definition at line 27 of file vtkAnnotateGlobalDataFilter.h.
◆ vtkAnnotateGlobalDataFilter()
vtkAnnotateGlobalDataFilter::vtkAnnotateGlobalDataFilter ( )
◆ ~vtkAnnotateGlobalDataFilter()
vtkAnnotateGlobalDataFilter::~vtkAnnotateGlobalDataFilter ( )
static vtkAnnotateGlobalDataFilter* vtkAnnotateGlobalDataFilter::New ( )
virtual const char* vtkAnnotateGlobalDataFilter::GetClassName ( )
static int vtkAnnotateGlobalDataFilter::IsTypeOf ( const char *  type)
virtual int vtkAnnotateGlobalDataFilter::IsA ( const char *  type)
Reimplemented from vtkTableAlgorithm.
static vtkAnnotateGlobalDataFilter* vtkAnnotateGlobalDataFilter::SafeDownCast ( vtkObject *  o)
void vtkAnnotateGlobalDataFilter::PrintSelf ( ostream &  os,
◆ SetFieldArrayName()
virtual void vtkAnnotateGlobalDataFilter::SetFieldArrayName ( const char *  )
◆ GetFieldArrayName()
virtual char* vtkAnnotateGlobalDataFilter::GetFieldArrayName ( )
◆ SetPrefix()
virtual void vtkAnnotateGlobalDataFilter::SetPrefix ( const char *  )
◆ GetPrefix()
virtual char* vtkAnnotateGlobalDataFilter::GetPrefix ( )
◆ SetPostfix()
virtual void vtkAnnotateGlobalDataFilter::SetPostfix ( const char *  )
◆ GetPostfix()
virtual char* vtkAnnotateGlobalDataFilter::GetPostfix ( )
◆ SetFormat()
virtual void vtkAnnotateGlobalDataFilter::SetFormat ( const char *  )
◆ GetFormat()
virtual char* vtkAnnotateGlobalDataFilter::GetFormat ( )
◆ SetController()
void vtkAnnotateGlobalDataFilter::SetController ( vtkMultiProcessController *  )
◆ GetController()
virtual vtkMultiProcessController* vtkAnnotateGlobalDataFilter::GetController ( )
◆ FillInputPortInformation()
int vtkAnnotateGlobalDataFilter::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ RequestData()
int vtkAnnotateGlobalDataFilter::RequestData ( vtkInformation *  request,
◆ Prefix
char* vtkAnnotateGlobalDataFilter::Prefix
Definition at line 77 of file vtkAnnotateGlobalDataFilter.h.
◆ Postfix
char* vtkAnnotateGlobalDataFilter::Postfix
Definition at line 78 of file vtkAnnotateGlobalDataFilter.h.
◆ FieldArrayName
char* vtkAnnotateGlobalDataFilter::FieldArrayName
Definition at line 79 of file vtkAnnotateGlobalDataFilter.h.
◆ Format
char* vtkAnnotateGlobalDataFilter::Format
Definition at line 80 of file vtkAnnotateGlobalDataFilter.h.
◆ Controller
vtkMultiProcessController* vtkAnnotateGlobalDataFilter::Controller
Definition at line 81 of file vtkAnnotateGlobalDataFilter.h.
