Public Types | Public Member Functions | Static Public Member Functions | List of all members
vtkAMRDualGridHelper Class Reference
Tools for processing AMR as a dual grid. More...
#include <vtkAMRDualGridHelper.h>
Inheritance diagram for vtkAMRDualGridHelper:
Collaboration diagram for vtkAMRDualGridHelper:
int Initialize (vtkNonOverlappingAMR *input)
int SetupData (vtkNonOverlappingAMR *input, const char *arrayName)
const double * GetGlobalOrigin ()
const double * GetRootSpacing ()
int GetNumberOfBlocks ()
int GetNumberOfLevels ()
int GetNumberOfBlocksInLevel (int level)
vtkAMRDualGridHelperBlock * GetBlock (int level, int blockIdx)
vtkAMRDualGridHelperBlock * GetBlock (int level, int xGrid, int yGrid, int zGrid)
void CopyDegenerateRegionBlockToBlock (int regionX, int regionY, int regionZ, vtkAMRDualGridHelperBlock *lowResBlock, vtkDataArray *lowResArray, vtkAMRDualGridHelperBlock *highResBlock, vtkDataArray *highResArray)
 I am generalizing the code that copies lowres blocks to highres ghost regions. More...
void QueueRegionRemoteCopy (int regionX, int regionY, int regionZ, vtkAMRDualGridHelperBlock *lowResBlock, vtkDataArray *lowResArray, vtkAMRDualGridHelperBlock *highResBlock, vtkDataArray *highResArray)
 This queues up either a copy from a remote process to this process or a copy from this process to a remote process. More...
void ProcessRegionRemoteCopyQueue (bool hackLevelFlag)
 This should be called on every process. More...
void ClearRegionRemoteCopyQueue ()
 Call this before adding regions to the queue. More...
virtual int GetSkipGhostCopy ()
 An option to turn off copying ghost values across process boundaries. More...
virtual void SetSkipGhostCopy (int)
virtual void SkipGhostCopyOn ()
virtual void SkipGhostCopyOff ()
virtual int GetEnableDegenerateCells ()
 Turn on/off the ability to create meshing between levels in the grid. More...
virtual void SetEnableDegenerateCells (int)
virtual void EnableDegenerateCellsOn ()
virtual void EnableDegenerateCellsOff ()
virtual int GetEnableAsynchronousCommunication ()
 When this option is on (the default) and a controller that supports asynchronous communication (like MPI) is detected, use asynchronous communication where appropriate. More...
virtual void SetEnableAsynchronousCommunication (int)
virtual void EnableAsynchronousCommunicationOn ()
virtual void EnableAsynchronousCommunicationOff ()
 The controller to use for communication. More...
virtual void SetController (vtkMultiProcessController *)
virtual char * GetArrayName ()
 It is convenient to get this here. More...
static vtkAMRDualGridHelper * New ()
static vtkAMRDualGridHelper * SafeDownCast (vtkObject *o)
This helper object was developed to help the AMR dual grid connectivity and integration filter but I also want a dual grid iso surface filter so I mad it a separate class. The API needs to be improved to make it more generally useful. This class will take advantage of some meta information, if available from a coprocessing adaptor. If not available, it will compute the information.
Definition at line 37 of file vtkAMRDualGridHelper.h.
Definition at line 41 of file vtkAMRDualGridHelper.h.
static vtkAMRDualGridHelper* vtkAMRDualGridHelper::New ( )
virtual const char* vtkAMRDualGridHelper::GetClassName ( )
static int vtkAMRDualGridHelper::IsTypeOf ( const char *  type)
virtual int vtkAMRDualGridHelper::IsA ( const char *  type)
static vtkAMRDualGridHelper* vtkAMRDualGridHelper::SafeDownCast ( vtkObject *  o)
void vtkAMRDualGridHelper::PrintSelf ( ostream &  os,
◆ GetSkipGhostCopy()
virtual int vtkAMRDualGridHelper::GetSkipGhostCopy ( )
If the ghost values are already correct, then the extra communication is not necessary. If this assumption is wrong, this option will produce cracks / seams. This is off by default.
◆ SetSkipGhostCopy()
virtual void vtkAMRDualGridHelper::SetSkipGhostCopy ( int  )
◆ SkipGhostCopyOn()
virtual void vtkAMRDualGridHelper::SkipGhostCopyOn ( )
◆ SkipGhostCopyOff()
virtual void vtkAMRDualGridHelper::SkipGhostCopyOff ( )
◆ GetEnableDegenerateCells()
virtual int vtkAMRDualGridHelper::GetEnableDegenerateCells ( )
This is on by default. Set this before you call initialize.
◆ SetEnableDegenerateCells()
virtual void vtkAMRDualGridHelper::SetEnableDegenerateCells ( int  )
◆ EnableDegenerateCellsOn()
virtual void vtkAMRDualGridHelper::EnableDegenerateCellsOn ( )
◆ EnableDegenerateCellsOff()
virtual void vtkAMRDualGridHelper::EnableDegenerateCellsOff ( )
◆ GetEnableAsynchronousCommunication()
virtual int vtkAMRDualGridHelper::GetEnableAsynchronousCommunication ( )
This can prevent processes from blocking while waiting for communication in other processes to finish.
◆ SetEnableAsynchronousCommunication()
virtual void vtkAMRDualGridHelper::SetEnableAsynchronousCommunication ( int  )
◆ EnableAsynchronousCommunicationOn()
virtual void vtkAMRDualGridHelper::EnableAsynchronousCommunicationOn ( )
◆ EnableAsynchronousCommunicationOff()
virtual void vtkAMRDualGridHelper::EnableAsynchronousCommunicationOff ( )
◆ GetController()
virtual vtkMultiProcessController* vtkAMRDualGridHelper::GetController ( )
◆ SetController()
virtual void vtkAMRDualGridHelper::SetController ( vtkMultiProcessController *  )
◆ Initialize()
int vtkAMRDualGridHelper::Initialize ( vtkNonOverlappingAMR *  input)
◆ SetupData()
int vtkAMRDualGridHelper::SetupData ( vtkNonOverlappingAMR *  input,
const char *  arrayName
◆ GetGlobalOrigin()
const double* vtkAMRDualGridHelper::GetGlobalOrigin ( )
inline
Definition at line 88 of file vtkAMRDualGridHelper.h.
◆ GetRootSpacing()
const double* vtkAMRDualGridHelper::GetRootSpacing ( )
inline
Definition at line 89 of file vtkAMRDualGridHelper.h.
◆ GetNumberOfBlocks()
int vtkAMRDualGridHelper::GetNumberOfBlocks ( )
inline
Definition at line 90 of file vtkAMRDualGridHelper.h.
◆ GetNumberOfLevels()
int vtkAMRDualGridHelper::GetNumberOfLevels ( )
inline
Definition at line 91 of file vtkAMRDualGridHelper.h.
◆ GetNumberOfBlocksInLevel()
int vtkAMRDualGridHelper::GetNumberOfBlocksInLevel ( int  level)
◆ GetBlock() [1/2]
vtkAMRDualGridHelperBlock* vtkAMRDualGridHelper::GetBlock ( int  level,
int  blockIdx
◆ GetBlock() [2/2]
int  xGrid,
int  yGrid,
int  zGrid
◆ CopyDegenerateRegionBlockToBlock()
void vtkAMRDualGridHelper::CopyDegenerateRegionBlockToBlock ( int  regionX,
int  regionY,
int  regionZ,
vtkAMRDualGridHelperBlock *  lowResBlock,
vtkDataArray *  lowResArray,
vtkAMRDualGridHelperBlock *  highResBlock,
vtkDataArray *  highResArray
I need to do this for the clip filter (level mask).
For transitions between levels, degeneracy works well to create and contour wedges and pyramids, but the volume fraction values in the high-level blocks ghost cells need to be the same as the closest cell in the low resolution block. These methods copy low values to high.
◆ QueueRegionRemoteCopy()
void vtkAMRDualGridHelper::QueueRegionRemoteCopy ( int  regionX,
int  regionY,
int  regionZ,
Only the local block needs an array. LowRes block is the source.
◆ ProcessRegionRemoteCopyQueue()
void vtkAMRDualGridHelper::ProcessRegionRemoteCopyQueue ( bool  hackLevelFlag)
It processes the queue of region copies. It sends and copies the regions into blocks.
◆ ClearRegionRemoteCopyQueue()
void vtkAMRDualGridHelper::ClearRegionRemoteCopyQueue ( )
It clears the queue.
◆ GetArrayName()
virtual char* vtkAMRDualGridHelper::GetArrayName ( )
