Observes high-level ParaView events, and serializes them to a stream as XML for possible playback (as a test-case, demo, tutorial, etc).
#include <pqXMLEventObserver.h>
Inherits pqEventObserver.
| void | onRecordEvent (const QString &Widget, const QString &Command, const QString &Arguments, const int &eventType) override |
| | Record on event in xml file. More...
To use, connect the onRecordEvent() slot to the pqEventTranslator::recordEvent() signal.
- Note
- Output is sent to the stream from this object's destructor, so you must ensure that it goes out of scope before trying to playback the stream.
- See also
- pqEventTranslator, pqStdoutEventObserver, pqXMLEventSource.
Definition at line 23 of file pqXMLEventObserver.h.
◆ pqXMLEventObserver()
| pqXMLEventObserver::pqXMLEventObserver |
QObject * |
p | ) |
◆ ~pqXMLEventObserver()
| pqXMLEventObserver::~pqXMLEventObserver |
◆ setStream()
| void pqXMLEventObserver::setStream |
QTextStream * |
stream | ) |
◆ onRecordEvent
| void pqXMLEventObserver::onRecordEvent |
const QString & |
Widget, |
const QString & |
Command, |
const QString & |
Arguments, |
const int & |
eventType |
overrideslot |
