Public Slots | Public Member Functions | Static Public Member Functions | Protected Member Functions | List of all members
pqSaveStateReaction Class Reference
#include <pqSaveStateReaction.h>
Inheritance diagram for pqSaveStateReaction:
Collaboration diagram for pqSaveStateReaction:
Public Slots
void updateEnableState () override
 Updates the enabled state. More...
 pqSaveStateReaction (QAction *parent)
 Constructor. More...
 ~pqSaveStateReaction () override=default
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
static bool saveState ()
 Open File dialog in order to choose the location and the type of the state file that should be saved Returns true if the user selected a file to save and false if they canceled the dialog. More...
static bool saveState (const QString &filename, vtkTypeUInt32 location=0x10)
 Saves the state file. More...
static bool savePythonState (const QString &filename, vtkTypeUInt32 location=0x10)
 Saves the state file as a python state. More...
void onTriggered () override
 Called when the action is triggered. More...
- Protected Slots inherited from pqReaction
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
- Protected Attributes inherited from pqReaction
bool IsMaster
Reaction for saving state file.
Definition at line 14 of file pqSaveStateReaction.h.
◆ pqSaveStateReaction()
pqSaveStateReaction::pqSaveStateReaction ( QAction *  parent)
Constructor.
Parent cannot be nullptr.
◆ ~pqSaveStateReaction()
pqSaveStateReaction::~pqSaveStateReaction ( )
overridedefault
◆ saveState() [1/2]
static bool pqSaveStateReaction::saveState ( )
◆ saveState() [2/2]
static bool pqSaveStateReaction::saveState ( const QString &  filename,
vtkTypeUInt32  location = 0x10
Note that this method is static. Applications can simply use this without having to create a reaction instance. Return true if the operation succeeded otherwise return false.
◆ savePythonState()
static bool pqSaveStateReaction::savePythonState ( const QString &  filename,
◆ updateEnableState
void pqSaveStateReaction::updateEnableState ( )
overrideslot
◆ onTriggered()
void pqSaveStateReaction::onTriggered ( )
inlineoverrideprotectedvirtual
Definition at line 61 of file pqSaveStateReaction.h.
