#include <pqProxyModifiedStateUndoElement.h>
| typedef vtkSMUndoElement | Superclass |
Public Types inherited from vtkSMUndoElement | |
| typedef vtkUndoElement | Superclass |
Public Types inherited from vtkUndoElement | |
| int | Undo () override |
| Undo the operation encapsulated by this element. More... | |
| int | Redo () override |
| Redo the operation encaspsulated by this element. More... | |
| void | MadeUnmodified (pqProxy *) |
| Use this to initialize the element if the pqProxy was marked as UNMODIFIED. More... | |
| void | MadeUninitialized (pqProxy *) |
| Use this to initialize the element if the pqProxy was marked as UNINITIALIZED. More... | |
Public Member Functions inherited from vtkSMUndoElement | |
Public Member Functions inherited from vtkUndoElement | |
| virtual bool | Merge (vtkUndoElement *vtkNotUsed(new_element)) |
Called on the older element in the UndoSet to merge with the element being added if both the elements are mergeable. More... | |
| virtual void | SetUndoSetWorkingContext (vtkCollection *workCTX) |
| virtual bool | GetMergeable () |
| Returns if this undo element can be merged with other undo elements. More... | |
| static pqProxyModifiedStateUndoElement * | New () |
| static pqProxyModifiedStateUndoElement * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMUndoElement | |
| static vtkSMUndoElement * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkUndoElement | |
| static vtkUndoElement * | SafeDownCast (vtkObject *o) |
| pqProxyModifiedStateUndoElement () | |
| ~pqProxyModifiedStateUndoElement () override | |
| bool | InternalUndoRedo (bool undo) |
Protected Member Functions inherited from vtkSMUndoElement | |
| vtkSMUndoElement () | |
| ~vtkSMUndoElement () override | |
Protected Member Functions inherited from vtkUndoElement | |
| vtkUndoElement () | |
| ~vtkUndoElement () override | |
| virtual void | SetMergeable (bool) |
| Subclasses must set this flag to enable merging of consecutive elements in an UndoSet. More... | |
Protected Attributes | |
| vtkTypeUInt32 | ProxySourceGlobalId |
| bool | Reverse |
Protected Attributes inherited from vtkSMUndoElement | |
Protected Attributes inherited from vtkUndoElement | |
| bool | Mergeable |
| vtkCollection * | UndoSetWorkingContext |
Definition at line 22 of file pqProxyModifiedStateUndoElement.h.
Definition at line 26 of file pqProxyModifiedStateUndoElement.h.
Reimplemented from vtkSMUndoElement.
inlineoverridevirtual |
Implements vtkUndoElement.
Definition at line 29 of file pqProxyModifiedStateUndoElement.h.
Definition at line 30 of file pqProxyModifiedStateUndoElement.h.
| void pqProxyModifiedStateUndoElement::MadeUnmodified | ( | pqProxy * | ) |
| void pqProxyModifiedStateUndoElement::MadeUninitialized | ( | pqProxy * | ) |
Definition at line 49 of file pqProxyModifiedStateUndoElement.h.
Definition at line 50 of file pqProxyModifiedStateUndoElement.h.
