pqOneLinerTextEdit is a specialization of pqTextEdit to handle one-liner expressions. More...
#include <pqOneLinerTextEdit.h>
| pqOneLinerTextEdit (QWidget *parent=nullptr) | |
| ~pqOneLinerTextEdit () override=default | |
Public Member Functions inherited from pqTextEdit | |
| pqTextEdit (QWidget *parent=nullptr) | |
| pqTextEdit (const QString &contents, QWidget *parent=nullptr) | |
| void | setCompleter (pqWidgetCompleter *completer) |
| pqWidgetCompleter * | getCompleter () |
| ~pqTextEdit () override | |
Protected Slots | |
| void | adjustToText () |
| Adjust widget height to the number of displayed lines. More... | |
| void | keyPressEvent (QKeyEvent *e) override |
| Reimplemented to disable "Enter" and "Return" key. More... | |
| void | resizeEvent (QResizeEvent *e) override |
| Reimplemented to update widget height depending on text wrapping. More... | |
| void | insertFromMimeData (const QMimeData *source) override |
| Reimplemented to avoid carriage return in pasted text. More... | |
Protected Member Functions inherited from pqTextEdit | |
| void | focusOutEvent (QFocusEvent *e) override |
| void | focusInEvent (QFocusEvent *e) override |
| QString | textUnderCursor () const |
| Returns the text of the current line in the input field. More... | |
| void | updateCompleter () |
| Trigger an update on the completer if any, and show the popup if completions are available. More... | |
| void | updateCompleterIfVisible () |
| In case the completer popup menu is already shown, update it to reflect modifications on the input text. More... | |
| void | selectCompletion () |
| Insert the completion in case there is only one available. More... | |
Signals inherited from pqTextEdit | |
| void | textChangedAndEditingFinished () |
| Unlike editingFinished() which gets fired whenever the widget looses focus irrespective of if the text actually was edited, textChangedAndEditingFinished() is fired only when the text was changed as well. More... | |
| void | editingFinished () |
| Just like the QLineEdit::editingFinished(), this signal is fired every time the widget loses focus. More... | |
Protected Attributes inherited from pqTextEdit | |
| QScopedPointer< pqTextEditPrivate > | d_ptr |
This widget differs from pqTextEdit with the following:
Definition at line 18 of file pqOneLinerTextEdit.h.
| pqOneLinerTextEdit::pqOneLinerTextEdit | ( | QWidget * | parent = nullptr | ) |
overridedefault |
Also remove redundant spaces. see QString::simplified()
protectedslot |
