Public Slots | Signals | Public Member Functions | Protected Member Functions | Properties | List of all members
pqMultiSliceAxisWidget Class Reference
#include <pqMultiSliceAxisWidget.h>
Inherits QWidget.
Public Slots
void renderView ()
Signals
void sliceAdded (int index)
 Signal emitted when the model has changed internally. More...
void sliceRemoved (int index)
void sliceModified (int index)
void markClicked (int button, int modifier, double value)
 Signal emitted when a mark is clicked. More...
void titleChanged (const QString &)
 pqMultiSliceAxisWidget (QWidget *parent=nullptr)
 ~pqMultiSliceAxisWidget () override
void setRange (double min, double max)
 Set the range of the Axis (Bound) More...
void setAxisType (int type)
 Axis::LEFT=0, Axis::BOTTOM, Axis::RIGHT, Axis::TOP. More...
QString title () const
 Title that appears inside the view. More...
void setTitle (const QString &title)
QWidget * getVTKWidget ()
 Return the Widget that contain the ContextView. More...
const double * getVisibleSlices (int &nbSlices) const
 Return the locations of the visible slices within the range as well as the number of values that can be read from the pointer. More...
const double * getSlices (int &nbSlices) const
 Returns the locations for all slices (visible or otherwise). More...
void updateSlices (double *values, bool *visibility, int numberOfValues)
 Update our internal model to reflect the proxy state. More...
void SetActiveSize (int size)
 The active size define the number of pixel that are going to be used for the slider handle. More...
void SetEdgeMargin (int margin)
 The margin used on the side of the Axis. More...
vtkContextScene * scene () const
void invalidateCallback (vtkObject *, unsigned long, void *)
 Internal VTK callback used to emit the modelUpdated() signal. More...
void onMarkClicked (vtkObject *, unsigned long, void *)
 Internal VTK callback used to emit markClicked(...) signale. More...
Properties
QString title
Definition at line 15 of file pqMultiSliceAxisWidget.h.
◆ pqMultiSliceAxisWidget()
pqMultiSliceAxisWidget::pqMultiSliceAxisWidget ( QWidget *  parent = nullptr)
◆ ~pqMultiSliceAxisWidget()
pqMultiSliceAxisWidget::~pqMultiSliceAxisWidget ( )
override
◆ setRange()
void pqMultiSliceAxisWidget::setRange ( double  min,
double  max
◆ setAxisType()
void pqMultiSliceAxisWidget::setAxisType ( int  type)
◆ title()
QString pqMultiSliceAxisWidget::title ( ) const
◆ setTitle()
void pqMultiSliceAxisWidget::setTitle ( const QString &  title)
◆ getVTKWidget()
QWidget* pqMultiSliceAxisWidget::getVTKWidget ( )
◆ getVisibleSlices()
const double* pqMultiSliceAxisWidget::getVisibleSlices ( int &  nbSlices) const
◆ getSlices()
const double* pqMultiSliceAxisWidget::getSlices ( int &  nbSlices) const
◆ updateSlices()
void pqMultiSliceAxisWidget::updateSlices ( double *  values,
bool *  visibility,
int  numberOfValues
◆ SetActiveSize()
void pqMultiSliceAxisWidget::SetActiveSize ( int  size)
◆ SetEdgeMargin()
void pqMultiSliceAxisWidget::SetEdgeMargin ( int  margin)
◆ renderView
void pqMultiSliceAxisWidget::renderView ( )
slot
◆ sliceAdded
void pqMultiSliceAxisWidget::sliceAdded ( int  index)
signal
◆ sliceRemoved
void pqMultiSliceAxisWidget::sliceRemoved ( int  index)
signal
◆ sliceModified
void pqMultiSliceAxisWidget::sliceModified ( int  index)
signal
◆ markClicked
void pqMultiSliceAxisWidget::markClicked ( int  button,
int  modifier,
double  value
signal
The value is inside the provided range
◆ titleChanged
void pqMultiSliceAxisWidget::titleChanged ( const QString &  )
signal
◆ scene()
vtkContextScene* pqMultiSliceAxisWidget::scene ( ) const
◆ invalidateCallback()
void pqMultiSliceAxisWidget::invalidateCallback ( vtkObject *  ,
unsigned long  ,
void *
◆ onMarkClicked()
void pqMultiSliceAxisWidget::onMarkClicked ( vtkObject *  ,
unsigned long  ,
void *
Property Documentation
◆ title
readwrite
Definition at line 19 of file pqMultiSliceAxisWidget.h.
