input widget for files
#include <pqFileChooserWidget.h>
Inherits QWidget.
| static QStringList | splitFilenames (const QString &filesString) |
| | Converts between a list of file names and delimited string of filenames (which is shown in the line edit box). More...
| static QString | joinFilenames (const QStringList &filesList) |
| void | emitFilenamesChanged (const QStringList &fileList) |
| | Takes a string with delimited files and emits the filenamesChanged and filenameChanged signals. More...
pqFileChooserWidget which consists of a tool button and a line edit hitting the tool button will bring up a file dialog, and the chosen file will be put in the line edit
Definition at line 26 of file pqFileChooserWidget.h.
◆ pqFileChooserWidget()
| pqFileChooserWidget::pqFileChooserWidget |
QWidget * |
p = nullptr | ) |
◆ ~pqFileChooserWidget()
| pqFileChooserWidget::~pqFileChooserWidget |
◆ filenames()
| QStringList pqFileChooserWidget::filenames |
const |
◆ setFilenames()
| void pqFileChooserWidget::setFilenames |
const QStringList & |
◆ singleFilename()
| QString pqFileChooserWidget::singleFilename |
const |
Convenience functions for when using only a single file (see forceSingleFile property).
◆ setSingleFilename()
| void pqFileChooserWidget::setSingleFilename |
const QString & |
◆ extension()
| QString pqFileChooserWidget::extension |
get the file extension for the file dialog
◆ setExtension()
| void pqFileChooserWidget::setExtension |
const QString & |
set the file extension for the file dialog
◆ forceSingleFile()
| bool pqFileChooserWidget::forceSingleFile |
flag specifying whether this widget should accept multiple files
Definition at line 79 of file pqFileChooserWidget.h.
◆ setForceSingleFile()
| void pqFileChooserWidget::setForceSingleFile |
bool |
flag | ) |
◆ useDirectoryMode()
| bool pqFileChooserWidget::useDirectoryMode |
◆ setUseDirectoryMode()
| void pqFileChooserWidget::setUseDirectoryMode |
bool |
flag | ) |
◆ acceptAnyFile()
| bool pqFileChooserWidget::acceptAnyFile |
◆ setAcceptAnyFile()
| void pqFileChooserWidget::setAcceptAnyFile |
bool |
flag | ) |
◆ setTitle()
| void pqFileChooserWidget::setTitle |
const QString & |
ttle | ) |
Get/set the title to use.
If an empty string is specified, a default one is created.
Definition at line 111 of file pqFileChooserWidget.h.
◆ title()
| const QString& pqFileChooserWidget::title |
const |
Definition at line 112 of file pqFileChooserWidget.h.
◆ setServer()
| void pqFileChooserWidget::setServer |
pqServer * |
server | ) |
set server to work on.
If server is nullptr, a local file dialog is used
◆ server()
| pqServer* pqFileChooserWidget::server |
◆ splitFilenames()
| static QStringList pqFileChooserWidget::splitFilenames |
const QString & |
filesString | ) |
inlinestatic |
Definition at line 126 of file pqFileChooserWidget.h.
◆ joinFilenames()
| static QString pqFileChooserWidget::joinFilenames |
filesList | ) |
inlinestatic |
◆ filenamesChanged
| void pqFileChooserWidget::filenamesChanged |
signal |
Signal emitted when the filename changes.
The single string version is a convenience for when you are only grabbing the first file anyway.
◆ filenameChanged
| void pqFileChooserWidget::filenameChanged |
const QString & |
signal |
◆ chooseFile
| void pqFileChooserWidget::chooseFile |
protectedslot |
Called when the user hits the choose file button.
◆ handleFileLineEditChanged
| void pqFileChooserWidget::handleFileLineEditChanged |
const QString & |
fileString | ) |
protectedslot |
Respond to changes with the filename in the line edit box.
◆ emitFilenamesChanged()
| void pqFileChooserWidget::emitFilenamesChanged |
fileList | ) |
◆ Extension
| QString pqFileChooserWidget::Extension |
◆ LineEdit
| QLineEdit* pqFileChooserWidget::LineEdit |
◆ Server
◆ ForceSingleFile
| bool pqFileChooserWidget::ForceSingleFile |
◆ UseDirectoryMode
| bool pqFileChooserWidget::UseDirectoryMode |
◆ AcceptAnyFile
| bool pqFileChooserWidget::AcceptAnyFile |
◆ FilenameList
| QStringList pqFileChooserWidget::FilenameList |
◆ UseFilenameList
| bool pqFileChooserWidget::UseFilenameList |
◆ Title
| QString pqFileChooserWidget::Title |
◆ filenames
readwrite |
◆ singleFilename
readwrite |
◆ extension
readwrite |
◆ useDirectoryMode
readwrite |
◆ forceSingleFile
readwrite |
◆ acceptAnyFile
readwrite |
