Public Slots | Public Member Functions | Protected Slots | List of all members
pqEditScalarBarReaction Class Reference
#include <pqEditScalarBarReaction.h>
Inheritance diagram for pqEditScalarBarReaction:
Collaboration diagram for pqEditScalarBarReaction:
Public Slots
void setRepresentation (pqDataRepresentation *)
 Set the active representation. More...
bool editScalarBar ()
 Show the editor dialog for editing scalar bar properties. More...
 pqEditScalarBarReaction (QAction *parent=nullptr, bool track_active_objects=true)
 ~pqEditScalarBarReaction () override
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 Constructor. More...
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
Protected Slots
void updateEnableState () override
 Updates the enabled state. More...
void onTriggered () override
 Called when the action is triggered. More...
- Protected Slots inherited from pqReaction
virtual void onTriggered ()
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
- Protected Attributes inherited from pqReaction
bool IsMaster
Reaction to allow editing of scalar bar properties using a pqProxyWidgetDialog.
Reaction allows editing of scalar bar properties using a pqProxyWidgetDialog. Internally, it uses pqScalarBarVisibilityReaction to track the visibility state for the scalar to enable/disable the parent action.
Definition at line 23 of file pqEditScalarBarReaction.h.
◆ pqEditScalarBarReaction()
pqEditScalarBarReaction::pqEditScalarBarReaction ( QAction *  parent = nullptr,
bool  track_active_objects = true
◆ ~pqEditScalarBarReaction()
pqEditScalarBarReaction::~pqEditScalarBarReaction ( )
override
◆ setRepresentation
void pqEditScalarBarReaction::setRepresentation ( pqDataRepresentation *  )
slot
This should only be used when track_active_objects is false. If used when track_active_objects is true, the representation will get replaced whenever the active representation changes.
◆ editScalarBar
bool pqEditScalarBarReaction::editScalarBar ( )
slot
◆ updateEnableState
void pqEditScalarBarReaction::updateEnableState ( )
overrideprotectedslot
◆ onTriggered
void pqEditScalarBarReaction::onTriggered ( )
