Public Types | Public Slots | Signals | Public Member Functions | Static Public Member Functions | Protected Member Functions | Properties | Friends | List of all members
pqDisplayColorWidget Class Reference
pqDisplayColorWidget is a widget that can be used to select the array to with for representations (also known as displays). More...
#include <pqDisplayColorWidget.h>
Inherits QWidget.
typedef QPair< int, QString > ValueType
Public Slots
void setRepresentation (pqDataRepresentation *display)
 Set the representation to control the scalar coloring properties on. More...
void setRepresentationText (const QString &text)
 set representation type. More...
Signals
void arraySelectionChanged ()
 fired to indicate the array-name changed. More...
void representationTextChanged (const QString &text)
 fired to indicate the representation type changed, allowing us to update. More...
 pqDisplayColorWidget (QWidget *parent=nullptr)
 ~pqDisplayColorWidget () override
ValueType arraySelection () const
 Get/Set the array name as pair (association-number, arrayname). More...
QString getCurrentText () const
int componentNumber () const
 Get/Set the component number (-1 == magnitude). More...
vtkSMViewProxy * viewProxy () const
 Returns the view proxy corresponding to the set representation, if any. More...
QString representationText () const
 Returns the selected representation type as a string. More...
static void updateScalarBarVisibility (vtkSMViewProxy *view, vtkSMProxy *reprProxy)
 Updates the scalar bar visibility of the representation reprProxy in view. More...
void setArraySelection (const ValueType &)
 Update the UI to show the selected array. More...
void setComponentNumber (int)
 Update the UI to show the selected component. More...
Properties
Friends
class PropertyLinksConnection
It comprises of two combo-boxes, one for the array name, and another for component number. To use, set the representation using setRepresentation(..). If the representation has appropriate properties, this widget will allow users to select the array name.
Definition at line 28 of file pqDisplayColorWidget.h.
◆ ValueType
typedef QPair<int, QString> pqDisplayColorWidget::ValueType
Definition at line 35 of file pqDisplayColorWidget.h.
◆ pqDisplayColorWidget()
pqDisplayColorWidget::pqDisplayColorWidget ( QWidget *  parent = nullptr)
◆ ~pqDisplayColorWidget()
pqDisplayColorWidget::~pqDisplayColorWidget ( )
override
◆ arraySelection()
ValueType pqDisplayColorWidget::arraySelection ( ) const
◆ getCurrentText()
QString pqDisplayColorWidget::getCurrentText ( ) const
inline
Definition at line 44 of file pqDisplayColorWidget.h.
◆ componentNumber()
int pqDisplayColorWidget::componentNumber ( ) const
◆ viewProxy()
vtkSMViewProxy* pqDisplayColorWidget::viewProxy ( ) const
◆ updateScalarBarVisibility()
static void pqDisplayColorWidget::updateScalarBarVisibility ( vtkSMViewProxy *  view,
vtkSMProxy *  reprProxy
The behavior of the scalar bar visibility is dependent of the general settings.
◆ representationText()
QString pqDisplayColorWidget::representationText ( ) const
inline
Definition at line 65 of file pqDisplayColorWidget.h.
◆ arraySelectionChanged
void pqDisplayColorWidget::arraySelectionChanged ( )
signal
◆ representationTextChanged
void pqDisplayColorWidget::representationTextChanged ( const QString &  text)
signal
◆ setRepresentation
void pqDisplayColorWidget::setRepresentation ( pqDataRepresentation *  display)
slot
◆ setRepresentationText
void pqDisplayColorWidget::setRepresentationText ( const QString &  text)
slot
◆ setArraySelection()
void pqDisplayColorWidget::setArraySelection ( const ValueType &  )
◆ setComponentNumber()
void pqDisplayColorWidget::setComponentNumber ( int  )
◆ PropertyLinksConnection
friend class PropertyLinksConnection
friend
Definition at line 166 of file pqDisplayColorWidget.h.
Property Documentation
readwrite
Definition at line 31 of file pqDisplayColorWidget.h.
