pqDesktopServicesReaction Class Reference
#include <pqDesktopServicesReaction.h>
Inheritance diagram for pqDesktopServicesReaction:
Collaboration diagram for pqDesktopServicesReaction:
 pqDesktopServicesReaction (const QUrl &url, QAction *parent)
 ~pqDesktopServicesReaction () override
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 Constructor. More...
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
static bool openUrl (const QUrl &url)
 Attempt to open a file (local or on the Web) using QDesktopServices. More...
void onTriggered () override
 Called when the action is triggered. More...
- Protected Slots inherited from pqReaction
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
- Protected Attributes inherited from pqReaction
bool IsMaster
pqDesktopServicesReaction can be used to open a file (or URL) using QDesktopServices. e.g. if your application wants to launch a PDF viewer to open the application's User Guide, you can hookup a menu QAction to the pqDesktopServicesReaction. e.g.
QAction* action = ...
new pqDesktopServicesReaction(QUrl("file:///..../doc/UsersGuide.pdf"), action);
The URL is set as status tip on the parent action.
Definition at line 24 of file pqDesktopServicesReaction.h.
◆ pqDesktopServicesReaction()
pqDesktopServicesReaction::pqDesktopServicesReaction ( const QUrl &  url,
QAction *  parent
◆ ~pqDesktopServicesReaction()
pqDesktopServicesReaction::~pqDesktopServicesReaction ( )
override
◆ openUrl()
static bool pqDesktopServicesReaction::openUrl ( const QUrl &  url)
Returns false if failed to open for some reason, other returns true.
◆ onTriggered()
void pqDesktopServicesReaction::onTriggered ( )
inlineoverrideprotectedvirtual
Definition at line 40 of file pqDesktopServicesReaction.h.
pqDesktopServicesReaction(const QUrl &url, QAction *parent)
