Public Types | Signals | Public Member Functions | Static Public Member Functions | List of all members
pqDataAssemblyTreeModel Class Reference
QAbstractItemModel implementation for vtkDataAssembly. More...
#include <pqDataAssemblyTreeModel.h>
Inherits QAbstractItemModel.
enum  RoleProperties { Standard, Inherited, InheritedUntilOverridden }
 Supported role properties. More...
Signals
void modelDataChanged (int role)
 This signal is fired in setData if the data is changed. More...
 pqDataAssemblyTreeModel (QObject *parent=nullptr)
 ~pqDataAssemblyTreeModel () override
void setDataAssembly (vtkDataAssembly *assembly)
 Get/Set the vtkDataAssembly to represent in this model. More...
vtkDataAssembly * dataAssembly () const
void setUserCheckable (bool)
 Get whether the model is user-checkable. More...
bool userCheckable () const
int nodeId (const QModelIndex &idx) const
 Given a QModelIndex, returns the vtkDataAssembly node id, if any. More...
QList< int > nodeId (const QModelIndexList &idxes) const
QModelIndex index (int nodeId) const
 Get a node id, returns the QModelIndex for the same. More...
QModelIndexList index (const QList< int > &nodeIds) const
void setCheckedNodes (const QStringList &paths)
 Get/Set the check state for Qt::Checked for nodes selected using the path names specified. More...
QStringList checkedNodes () const
void setRoleProperty (int role, RoleProperties property)
 Set properties for custom roles. More...
RoleProperties roleProperty (int role) const
bool setData (const QList< QPair< QString, QVariant >> &values, int role)
 Get/Set the values for a specific role using selectors. More...
QList< QPair< QString, QVariant > > data (int role) const
int columnCount (const QModelIndex &parent=QModelIndex()) const override
 QAbstractItemModel interface implementation. More...
int rowCount (const QModelIndex &parent=QModelIndex()) const override
QModelIndex index (int row, int column, const QModelIndex &parent=QModelIndex()) const override
QModelIndex parent (const QModelIndex &index=QModelIndex()) const override
QVariant data (const QModelIndex &index, int role) const override
Qt::ItemFlags flags (const QModelIndex &index) const override
bool setData (const QModelIndex &index, const QVariant &value, int role) override
static int GetIsDerivedRole (int role)
 For custom roles, use this function to convert that role into a role that can be used in data() to get a boolean indicating if the value is derived or explicitly set. More...
pqDataAssemblyTreeModel builds a tree-model from a vtkDataAssembly. The vtkDataAssembly to shown is set using setDataAssembly. To allow user-settable check-states, use setUserCheckable(true).
One can store additional data associated with nodes using custom roles (Qt::UserRole). For custom roles, one can define how a value for that specific role get inherited by child nodes or overridden when set on a parent node. This is done using setRoleProperty.
Definition at line 28 of file pqDataAssemblyTreeModel.h.
◆ RoleProperties
Standard implies no special handling i.e. the role does not affect the value of the value for child nodes in the hierarchy. Inherited means for any node, if a value for this role is not explicitly specified, then it is inherited from its parent node. Likewise, if one sets a explicitly on a node (using setData), the it overrides values for this role on all children recursively. InheritedUntilOverridden is similar to Inherited except that the recursion down the subtree stops when a child node with an explicitly set value is encountered.
Enumerator
Standard
Inherited
Definition at line 107 of file pqDataAssemblyTreeModel.h.
◆ pqDataAssemblyTreeModel()
pqDataAssemblyTreeModel::pqDataAssemblyTreeModel ( QObject *  parent = nullptr)
◆ ~pqDataAssemblyTreeModel()
pqDataAssemblyTreeModel::~pqDataAssemblyTreeModel ( )
override
◆ setDataAssembly()
void pqDataAssemblyTreeModel::setDataAssembly ( vtkDataAssembly *  assembly)
◆ dataAssembly()
vtkDataAssembly* pqDataAssemblyTreeModel::dataAssembly ( ) const
◆ setUserCheckable()
void pqDataAssemblyTreeModel::setUserCheckable ( bool  )
◆ userCheckable()
bool pqDataAssemblyTreeModel::userCheckable ( ) const
inline
Definition at line 48 of file pqDataAssemblyTreeModel.h.
◆ nodeId() [1/2]
int pqDataAssemblyTreeModel::nodeId ( const QModelIndex &  idx) const
-1 is returned for invalid index.
◆ nodeId() [2/2]
QList<int> pqDataAssemblyTreeModel::nodeId ( const QModelIndexList &  idxes) const
◆ index() [1/3]
QModelIndex pqDataAssemblyTreeModel::index ( int  nodeId) const
◆ index() [2/3]
QModelIndexList pqDataAssemblyTreeModel::index ( const QList< int > &  nodeIds) const
◆ setCheckedNodes()
void pqDataAssemblyTreeModel::setCheckedNodes ( const QStringList &  paths)
setCheckedNodes has effect as setData(.., Qt::CheckStateRole), only differing in how the values are specified. For setCheckedNodes, one only lists the selectors for checked nodes, while setData accept pairs where the first value is the selector while the second value is the check state.
Note
checking a node causes all it child nodes to be checked as well.
checkedNodes() may not returns exactly the same paths passed to setCheckedNodes even if the check-states were not changed in between the two calls.
See also
vtkDataAssembly::SelectNodes
◆ checkedNodes()
QStringList pqDataAssemblyTreeModel::checkedNodes ( ) const
Note
See also
◆ GetIsDerivedRole()
static int pqDataAssemblyTreeModel::GetIsDerivedRole ( int  role)
inlinestatic
Definition at line 94 of file pqDataAssemblyTreeModel.h.
◆ setRoleProperty()
void pqDataAssemblyTreeModel::setRoleProperty ( int  role,
If none specified, Standard is assumed. For Qt::CheckStateRole, it is initialized to Inherited.
◆ roleProperty()
RoleProperties pqDataAssemblyTreeModel::roleProperty ( int  role) const
◆ setData() [1/2]
bool pqDataAssemblyTreeModel::setData ( const QList< QPair< QString, QVariant >> &  values,
int  role
The values are specified as a list of pairs which pair comprising of a selector and the associated value for that selector. This model is not capable of generating advanced selectors, so data() will simply return paths as selectors. setData can use any for for selector specification supported by the underlying vtkDataAssembly.
This model does not cache set values. When setData is called, nodes matching the selectors are immediately located and updated. Hence, if this method is called before any assembly is set, the values will be lost. In this case, setData will return false.
See also
◆ data() [1/2]
QList<QPair<QString, QVariant> > pqDataAssemblyTreeModel::data ( int  role) const
See also
◆ columnCount()
int pqDataAssemblyTreeModel::columnCount ( const QModelIndex &  parent = QModelIndex()) const
override
◆ rowCount()
int pqDataAssemblyTreeModel::rowCount ( const QModelIndex &  parent = QModelIndex()) const
override
◆ index() [3/3]
QModelIndex pqDataAssemblyTreeModel::index ( int  row,
int  column,
) const
override
◆ parent()
QModelIndex pqDataAssemblyTreeModel::parent ( const QModelIndex &  index = QModelIndex()) const
override
◆ data() [2/2]
QVariant pqDataAssemblyTreeModel::data ( const QModelIndex &  index,
int  role
) const
override
◆ flags()
Qt::ItemFlags pqDataAssemblyTreeModel::flags ( const QModelIndex &  index) const
override
◆ setData() [2/2]
bool pqDataAssemblyTreeModel::setData ( const QModelIndex &  index,
const QVariant &  value,
int  role
override
◆ modelDataChanged
void pqDataAssemblyTreeModel::modelDataChanged ( int  role)
signal
setData can result in multiple calls to dataChanged signal as the data is updated on nodes in the hierarchy. This signal is fired only once for setData call irrespective of how many internal nodes are updated.
