Public Member Functions | Static Public Attributes | Friends | List of all members
pqCustomViewpointButtonDialog Class Reference
#include <pqCustomViewpointButtonDialog.h>
Inherits QDialog.
 pqCustomViewpointButtonDialog (QWidget *parent, Qt::WindowFlags f, QStringList &toolTips, QStringList &configurations, QString &currentConfig)
 Create and initialize the dialog. More...
 ~pqCustomViewpointButtonDialog () override
void setToolTipsAndConfigurations (const QStringList &toolTips, const QStringList &configs)
 Set the list of tool tips and configurations. More...
void setToolTips (const QStringList &toolTips)
 Set/get a list of tool tips, one for each button. More...
QStringList getToolTips ()
void setConfigurations (const QStringList &configs)
 Set/get a list of camera configurations, one for each button. More...
QStringList getConfigurations ()
void setCurrentConfiguration (const QString &config)
 Set/get the current camera configuration. More...
QString getCurrentConfiguration ()
const static QString DEFAULT_TOOLTIP
 Constant variable that contains the default name for the tool tips. More...
const static int MINIMUM_NUMBER_OF_ITEMS
 Constant variable that defines the minimum number of items. More...
const static int MAXIMUM_NUMBER_OF_ITEMS
 Constant variable that defines the maximum number of items. More...
Friends
class pqCustomViewpointButtonDialogUI
Definition at line 33 of file pqCustomViewpointButtonDialog.h.
◆ pqCustomViewpointButtonDialog()
pqCustomViewpointButtonDialog::pqCustomViewpointButtonDialog ( QWidget *  parent,
Qt::WindowFlags  f,
QStringList &  toolTips,
QStringList &  configurations,
QString &  currentConfig
◆ ~pqCustomViewpointButtonDialog()
pqCustomViewpointButtonDialog::~pqCustomViewpointButtonDialog ( )
override
◆ setToolTipsAndConfigurations()
void pqCustomViewpointButtonDialog::setToolTipsAndConfigurations ( const QStringList &  toolTips,
const QStringList &  configs
This is the preferred way of settings these as it supports changing the number of items.
◆ setToolTips()
void pqCustomViewpointButtonDialog::setToolTips ( const QStringList &  toolTips)
The number of items in the toolTips list must match the current number of tooltips being shown. Use setToolTipsAndConfigurations to change the number of items.
◆ getToolTips()
QStringList pqCustomViewpointButtonDialog::getToolTips ( )
◆ setConfigurations()
void pqCustomViewpointButtonDialog::setConfigurations ( const QStringList &  configs)
The number of items in configs must match the current number of configs. Use setToolTipsAndConfigurations to change the number of items.
◆ getConfigurations()
QStringList pqCustomViewpointButtonDialog::getConfigurations ( )
◆ setCurrentConfiguration()
void pqCustomViewpointButtonDialog::setCurrentConfiguration ( const QString &  config)
◆ getCurrentConfiguration()
QString pqCustomViewpointButtonDialog::getCurrentConfiguration ( )
◆ pqCustomViewpointButtonDialogUI
friend class pqCustomViewpointButtonDialogUI
friend
Definition at line 110 of file pqCustomViewpointButtonDialog.h.
◆ DEFAULT_TOOLTIP
const static QString pqCustomViewpointButtonDialog::DEFAULT_TOOLTIP
Definition at line 49 of file pqCustomViewpointButtonDialog.h.
◆ MINIMUM_NUMBER_OF_ITEMS
const static int pqCustomViewpointButtonDialog::MINIMUM_NUMBER_OF_ITEMS
Definition at line 54 of file pqCustomViewpointButtonDialog.h.
◆ MAXIMUM_NUMBER_OF_ITEMS
const static int pqCustomViewpointButtonDialog::MAXIMUM_NUMBER_OF_ITEMS
Definition at line 59 of file pqCustomViewpointButtonDialog.h.
