Public Slots | Public Member Functions | List of all members
pqCustomFilterDefinitionWizard Class Reference
The pqCustomFilterDefinitionWizard class is used to create a compound proxy definition one step at a time. More...
#include <pqCustomFilterDefinitionWizard.h>
Inherits QDialog.
Public Slots
void createCustomFilter ()
 Creates a compound proxy definition. More...
 pqCustomFilterDefinitionWizard (pqCustomFilterDefinitionModel *model, QWidget *parent=nullptr)
 Creates a custom filter definition wizard. More...
 ~pqCustomFilterDefinitionWizard () override
pqCustomFilterDefinitionModel * getModel () const
 Gets the custom filter definition model used by the wizard. More...
QString getCustomFilterName () const
 Gets the name of the compound proxy created by the wizard. More...
The wizard should be created with a pqCustomFilterDefinitionModel. The model stores the sources that will be placed in the custom filter. The model is also used when selecting the exposed properties.
The following is an example of how to use the wizard:
filter.setContents(
pqApplicationCore::instance()->getSelectionModel()->selectedItems());
pqCustomFilterDefinitionWizard wizard(&filter, this);
if(wizard.exec() == QDialog::Accepted)
wizard.createCustomFilter();
The custom filter definition model is filled out using the selected pipeline sources. After setting the custom filter definition model's contents, you can check to see if any sources were added. The wizard can make a compound proxy without any sources, but you may not want to allow it. After the createCustomFilter call, you can get the name of the newly created compound proxy.
Definition at line 54 of file pqCustomFilterDefinitionWizard.h.
◆ pqCustomFilterDefinitionWizard()
pqCustomFilterDefinitionWizard::pqCustomFilterDefinitionWizard ( pqCustomFilterDefinitionModel *  model,
QWidget *  parent = nullptr
Parameters
modelThe custom filter definition model to use. The model should not be null.
parentThe parent widget for the wizard.
◆ ~pqCustomFilterDefinitionWizard()
pqCustomFilterDefinitionWizard::~pqCustomFilterDefinitionWizard ( )
override
◆ getModel()
pqCustomFilterDefinitionModel* pqCustomFilterDefinitionWizard::getModel ( ) const
inline
Returns
A pointer to the custom filter definition model.
Definition at line 75 of file pqCustomFilterDefinitionWizard.h.
◆ getCustomFilterName()
QString pqCustomFilterDefinitionWizard::getCustomFilterName ( ) const
Returns
The name of the new compound proxy definition. The name will be empty if the compound proxy has not been created.
See also
pqCustomFilterDefinitionWizard::createCustomFilter();
◆ createCustomFilter
void pqCustomFilterDefinitionWizard::createCustomFilter ( )
slot
The compound proxy definition is created using the custom filter definition model and the parameters entered by the user. The new definition is registered with the server manager.
See also
pqCustomFilterDefinitionWizard::getCustomFilterName()
The pqCustomFilterDefinitionModel class stores the sources that define a compound proxy in a hierarch...
Definition: pqCustomFilterDefinitionModel.h:34
The pqCustomFilterDefinitionWizard class is used to create a compound proxy definition one step at a ...
Definition: pqCustomFilterDefinitionWizard.h:54
static pqApplicationCore * instance()
