Static Public Member Functions | List of all members
pqCoreUtilities Class Reference
pqCoreUtilities is a collection of arbitrary utility functions that can be used by the application. More...
#include <pqCoreUtilities.h>
Inherits QObject.
static void setMainWidget (QWidget *widget)
 When popping up dialogs, it's generally better if we set the parent widget for those dialogs to be the QMainWindow so that the dialogs show up centered correctly in the application. More...
static QWidget * mainWidget ()
static void processEvents (QEventLoop::ProcessEventsFlags flags=QEventLoop::AllEvents)
 Call QApplication::processEvents plus make sure the testing framework is. More...
static QString getParaViewUserDirectory ()
 Return the path of the root ParaView user specific configuration directory. More...
static QString getParaViewApplicationDirectory ()
 Return the path of the launched application. More...
static QStringList findParaviewPaths (QString directoryOrFileName, bool lookupInAppDir, bool lookupInUserDir)
 Return the list of full available path that exists inside the shared application path and the user specific one. More...
static QString getNoneExistingFileName (QString expectedFilePath)
static unsigned long connect (vtkObject *vtk_object, int vtk_event_id, QObject *qobject, const char *signal_or_slot, Qt::ConnectionType type=Qt::AutoConnection)
 Method used to connect VTK events to Qt slots (or signals). More...
static bool promptUser (const QString &settingsKey, QMessageBox::Icon icon, const QString &title, const QString &message, QMessageBox::StandardButtons buttons, QWidget *parentWdg=nullptr)
 This provides a mechanism to prompt the user to make a choice or to show them some information. More...
static QMessageBox::Button promptUserGeneric (const QString &title, const QString &message, QMessageBox::Icon icon, QMessageBox::StandardButtons buttons, QWidget *parentWidget)
 This show a QMessageBox to the user and returns the clicked button. More...
static QString number (double value, int lowExponent=-6, int highExponent=20)
 Converts a double value to a full precision QString. More...
static QString formatFullNumber (double value)
 Convert double value to string according to FullNotation settings, rely on pqCoreUtilities::number. More...
static QString formatMemoryFromKiBValue (double memoryInKB, int precision=2)
 Convert a double KiB value to an easily readable QString For example, if this function is called with 1500.0 as an input and the default precision, the QString "1.46 MiB" will be returned. More...
static void initializeClickMeButton (QAbstractButton *button)
 Setups up appearance for buttons such as Apply button that we want to draw user's attention to when enabled. More...
static void setPaletteHighlightToOk (QPalette &palette)
 Set the Hightlight value of the palette to CDash green Also set HightlightedText to black. More...
static void setPaletteHighlightToWarning (QPalette &palette)
 Set the Hightlight value of the palette to CDash yellow Also set HightlightedText to white. More...
static void setPaletteHighlightToCritical (QPalette &palette)
 Set the Hightlight value of the palette to CDash red Also set HightlightedText to white. More...
static void removeRecursively (QDir dir)
 Safely delete a directory recursively. More...
static void remove (const QString &filePath)
 Safely delete a file. More...
static QString formatDouble (double value, int notation, bool shortAccurate, int precision, int fullLowExponent=-6, int fullHighExponent=20)
 Convert double value to string, handling formating. More...
static QString formatNumber (double value)
static QString formatTime (double value)
Definition at line 52 of file pqCoreUtilities.h.
◆ setMainWidget()
static void pqCoreUtilities::setMainWidget ( QWidget *  widget)
inlinestatic
For that purpose this convenience method is provided. It locates a QMainWindow and returns it.
Definition at line 62 of file pqCoreUtilities.h.
◆ mainWidget()
static QWidget* pqCoreUtilities::mainWidget ( )
inlinestatic
Definition at line 63 of file pqCoreUtilities.h.
◆ processEvents()
static void pqCoreUtilities::processEvents ( QEventLoop::ProcessEventsFlags  flags = QEventLoop::AllEvents)
inlinestatic
Definition at line 75 of file pqCoreUtilities.h.
◆ getParaViewUserDirectory()
static QString pqCoreUtilities::getParaViewUserDirectory ( )
◆ getParaViewApplicationDirectory()
static QString pqCoreUtilities::getParaViewApplicationDirectory ( )
◆ findParaviewPaths()
static QStringList pqCoreUtilities::findParaviewPaths ( QString  directoryOrFileName,
◆ getNoneExistingFileName()
static QString pqCoreUtilities::getNoneExistingFileName ( QString  expectedFilePath)
◆ connect()
static unsigned long pqCoreUtilities::connect ( vtkObject *  vtk_object,
int  vtk_event_id,
QObject *  qobject,
const char *  signal_or_slot,
Qt::ConnectionType  type = Qt::AutoConnection
This is an alternative to using vtkEventQtSlotConnect. This method gives a cleaner API to connect vtk-events to Qt slots. It manages cleanup correctly i.e. either vtk-object or the qt-object can be deleted and the observers will be cleaned up correctly. One can disconnect the connection made explicitly by vtk_object->RemoveObserver(eventId) where eventId is the returned value.
◆ promptUser()
static bool pqCoreUtilities::promptUser ( const QString &  settingsKey,
const QString &  title,
const QString &  message,
QWidget *  parentWdg = nullptr
The user can decide to make their choice persistent. Two configurations are supported:
  1. The method prompts the user with a "Yes", "No", and "Yes, and don't ask again" message box. Returns true for "Yes" and false for "No". If "Yes, and don't ask again" was clicked, the selection is remembered in pqSettings and next time this method is called with the same settingsKey it will simply return true.
  2. The method shows a message box with a "Ok" and "Ok and don't show again" If "Ok, and don't show again" was clicked, the next time this method is called with the same settingsKey it will simply return. The 'don't ask/show again' button is created by or-ing 'buttons' with QMessageBox::Save. NOTE: due to issues with test recording and playback, currently, this dialog is not prompted (instead always returning true) when DASHBOARD_TEST_FROM_CTEST environment variable is set. This may change in future.
◆ promptUserGeneric()
static QMessageBox::Button pqCoreUtilities::promptUserGeneric ( const QString &  title,
QWidget *  parentWidget
◆ number()
static QString pqCoreUtilities::number ( double  value,
int  lowExponent = -6,
int  highExponent = 20
Internally uses pqDoubleLineEdit with FullConversion, which relies on vtkNumberToString for lossless conversion from double to string. Set lowExponent and highExponent to control the range of exponents where a fixed precision should be used instead of scientific notation. Outside this range, scientific notation is preferred. Default values of -6 and 20 correspond to the ECMAScript standard.
◆ formatFullNumber()
static QString pqCoreUtilities::formatFullNumber ( double  value)
◆ formatDouble()
static QString pqCoreUtilities::formatDouble ( double  value,
int  notation,
bool  shortAccurate,
int  precision,
int  fullLowExponent = -6,
int  fullHighExponent = 20
◆ formatNumber()
static QString pqCoreUtilities::formatNumber ( double  value)
◆ formatTime()
static QString pqCoreUtilities::formatTime ( double  value)
◆ formatMemoryFromKiBValue()
static QString pqCoreUtilities::formatMemoryFromKiBValue ( double  memoryInKB,
int  precision = 2
◆ initializeClickMeButton()
static void pqCoreUtilities::initializeClickMeButton ( QAbstractButton *  button)
Currently, this changes the palette to use a green background when enabled.
◆ setPaletteHighlightToOk()
static void pqCoreUtilities::setPaletteHighlightToOk ( QPalette &  palette)
◆ setPaletteHighlightToWarning()
static void pqCoreUtilities::setPaletteHighlightToWarning ( QPalette &  palette)
◆ setPaletteHighlightToCritical()
static void pqCoreUtilities::setPaletteHighlightToCritical ( QPalette &  palette)
◆ removeRecursively()
static void pqCoreUtilities::removeRecursively ( QDir  dir)
This function indicates any errors with a modal popup dialog.
◆ remove()
static void pqCoreUtilities::remove ( const QString &  filePath)
