Provides ParaView-specific functionality for regression testing. More...
#include <pqCoreTestUtility.h>
Public Slots | |
| void | setDashboardMode (bool value) override |
| put/unset the DASHBOARD_TEST_FROM_CTEST env var to control if ParaView should behave in dashboard mode Also update players and translators More... | |
| void | updatePlayers () override |
| Reimplemented to add/remove the file dialog player according to the DASHBOARD_TEST_FROM_CTEST env var. More... | |
| void | updateTranslators () override |
| Reimplementated to add/remove the file dialog translator according to the DASHBOARD_TEST_FROM_CTEST env var. More... | |
| pqCoreTestUtility (QObject *parent=nullptr) | |
| ~pqCoreTestUtility () override | |
| bool | supportsDashboardMode () override |
| Reimplemented to inform this test utility supports dashboard mode always returns true. More... | |
| static QString | fixPath (const QString &path) |
| Cleans up patch to replace $PARAVIEW_TEST_ROOT and $PARAVIEW_DATA_ROOT with appropriate paths specified on the command line. More... | |
| static QString | DataRoot () |
| Returns the absolute path to the PARAVIEW_DATA_ROOT in canonical form (slashes forward), or empty string. More... | |
| static QString | TestDirectory () |
| Returns the temporary test directory in which tests can write temporary outputs, difference images etc. More... | |
| static QString | BaselineDirectory () |
| Returns the baseline directory in which test recorder will write baseline images. More... | |
| static bool | SaveScreenshot (vtkRenderWindow *RenderWindow, const QString &File) |
| Saves the contents of a render window to a file for later use as a reference image. More... | |
| static bool | CompareImage (vtkRenderWindow *renderWindow, const QString &referenceImage, double threshold, ostream &output, const QString &tempDirectory, const QSize &size=QSize(300, 300)) |
| Compares the contents of a render window to a reference image, returning true iff the two match within a given threshold. More... | |
| static bool | CompareImage (vtkImageData *testImage, const QString &ReferenceImage, double Threshold, ostream &Output, const QString &TempDirectory) |
| Compares the test image to a reference image, returning true iff the two match within a given threshold. More... | |
| static bool | CompareImage (const QString &testPNGImage, const QString &ReferenceImage, double Threshold, ostream &Output, const QString &TempDirectory) |
| static bool | CompareImage (QWidget *widget, const QString &referenceImage, double threshold, ostream &output, const QString &tempDirectory, const QSize &size=QSize(300, 300)) |
| Compares the contents of any arbitrary QWidget to a reference image, returning true iff the two match within a given threshold. More... | |
| static bool | CompareView (pqView *curView, const QString &referenceImage, double threshold, const QString &tempDirectory, const QSize &size=QSize()) |
| static bool | CompareTile (QWidget *widget, int rank, int tdx, int tdy, const QString &baseline, double threshold, ostream &output, const QString &tempDirectory) |
| static bool | CompareTile (pqView *widget, int rank, int tdx, int tdy, const QString &baseline, double threshold, ostream &output, const QString &tempDirectory) |
| static QString | cleanPath (const QString &) |
| Cleans a path string. More... | |
Static Public Attributes | |
| static const char * | PQ_COMPAREVIEW_PROPERTY_NAME |
Definition at line 24 of file pqCoreTestUtility.h.
| pqCoreTestUtility::pqCoreTestUtility | ( | QObject * | parent = nullptr | ) |
inlineoverride |
Definition at line 107 of file pqCoreTestUtility.h.
overrideslot |
overrideslot |
overrideslot |
Definition at line 91 of file pqCoreTestUtility.h.
