Public Types | Public Member Functions | Static Public Member Functions | Protected Slots | List of all members
pqChartSelectionReaction Class Reference
#include <pqChartSelectionReaction.h>
Inheritance diagram for pqChartSelectionReaction:
Collaboration diagram for pqChartSelectionReaction:
enum  SelectionMode { CLEAR_SELECTION = vtkChart::ACTION_TYPES_COUNT }
 ParaView-specific selection modes. More...
 pqChartSelectionReaction (QAction *parent, pqContextView *view, QActionGroup *modifierGroup)
 Constructor. More...
- Public Member Functions inherited from pqSelectionReaction
 pqSelectionReaction (QAction *parent, QActionGroup *modifierGroup=nullptr)
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
static void startSelection (pqContextView *view, int selectionType, int selectionModifier)
 Start selection on the view where: More...
Protected Slots
virtual void triggered (bool)
 Called when the action is triggered. More...
void stopSelection ()
 Stops selecting on the view. More...
void modifiersChanged () override
 Called when modifier group is changed. More...
int getSelectionModifier () override
 Get the current state of selection modifier, converting it to vtkScene enum. More...
void updateEnableState () override
 Handles enable state for CLEAR_SELECTION action. More...
- Protected Slots inherited from pqSelectionReaction
virtual void modifiersChanged ()
 called when modifier group is changed. More...
- Protected Slots inherited from pqReaction
virtual void onTriggered ()
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
- Protected Member Functions inherited from pqSelectionReaction
virtual int getSelectionModifier ()
 Get the current state of selection modifier, if any. More...
virtual void uncheckSelectionModifiers ()
 Uncheck selection modifiers, if any. More...
virtual void disableSelectionModifiers (bool disable)
 Disable/Enable selection modifiers, if any. More...
- Protected Attributes inherited from pqSelectionReaction
QPointer< QActionGroup > ModifierGroup
- Protected Attributes inherited from pqReaction
bool IsMaster
Reaction for creating selections on chart views.
Definition at line 20 of file pqChartSelectionReaction.h.
◆ SelectionMode
Enumerator
CLEAR_SELECTION
Definition at line 29 of file pqChartSelectionReaction.h.
◆ pqChartSelectionReaction()
pqChartSelectionReaction::pqChartSelectionReaction ( QAction *  parent,
pqContextView *  view,
QActionGroup *  modifierGroup
Constructor.
parent is expected to have data() that indicates the selection type e.g. vtkChart::SELECT_RECTANGLE or vtkChart::SELECT_POLYGON. One can also use vtkChart::CLEAR_SELECTION to clear the current selection. QActionGroup modifierGroup is used to determine selection modifier. If there's a non-null checkedAction() in the group, we use that action's data() to determine the selection mode e.g. vtkContextScene::SELECTION_ADDITION, vtkContextScene::SELECTION_SUBTRACTION etc. If no QActionGroup is specified or no checked action is present, then the default mode of vtkContextScene::SELECTION_DEFAULT is used.
◆ startSelection()
static void pqChartSelectionReaction::startSelection ( pqContextView *  view,
int  selectionType,
◆ triggered
virtual void pqChartSelectionReaction::triggered ( bool  )
protectedvirtualslot
◆ stopSelection
void pqChartSelectionReaction::stopSelection ( )
protectedslot
◆ modifiersChanged
void pqChartSelectionReaction::modifiersChanged ( )
overrideprotectedslot
◆ getSelectionModifier
int pqChartSelectionReaction::getSelectionModifier ( )
◆ updateEnableState
void pqChartSelectionReaction::updateEnableState ( )
