Abstract class implementing a tree model with checkable items.
#include <pqAbstractItemSelectionModel.h>
Inherits QAbstractItemModel.
| | pqAbstractItemSelectionModel (QObject *parent_=nullptr) |
| | ~pqAbstractItemSelectionModel () override |
| virtual void | populateModel (void *dataObject)=0 |
| | Concrete classes should implement how the model is to be populated. More...
| virtual void | initializeRootItem ()=0 |
| | Initialize the root item which holds the header tags. More...
| bool | isIndexValid (const QModelIndex &index_) const |
| | Helper for a more comprehensive validation of indices. More...
| int | rowCount (const QModelIndex &parent_=QModelIndex()) const override |
| | QAbstractItemModel implementation. More...
| int | columnCount (const QModelIndex &parent_=QModelIndex()) const override |
| QModelIndex | index (int row, int column, const QModelIndex &parent_=QModelIndex()) const override |
| QModelIndex | parent (const QModelIndex &index_) const override |
| QVariant | data (const QModelIndex &index_, int role=Qt::DisplayRole) const override |
| bool | setData (const QModelIndex &index_, const QVariant &value, int role) override |
| QVariant | headerData (int section, Qt::Orientation orientation, int role=Qt::DisplayRole) const override |
| Qt::ItemFlags | flags (const QModelIndex &index_) const override |
It uses QTreeWidgetItem as its item class. Reimplement the virtual methods to fill it with data.
Definition at line 17 of file pqAbstractItemSelectionModel.h.
◆ pqAbstractItemSelectionModel()
| pqAbstractItemSelectionModel::pqAbstractItemSelectionModel |
QObject * |
parent_ = nullptr | ) |
◆ ~pqAbstractItemSelectionModel()
| pqAbstractItemSelectionModel::~pqAbstractItemSelectionModel |
◆ rowCount()
| int pqAbstractItemSelectionModel::rowCount |
const QModelIndex & |
parent_ = QModelIndex() | ) |
const |
◆ columnCount()
| int pqAbstractItemSelectionModel::columnCount |
const |
◆ index()
| QModelIndex pqAbstractItemSelectionModel::index |
int |
row, |
int |
column, |
| const |
◆ parent()
| QModelIndex pqAbstractItemSelectionModel::parent |
index_ | ) |
const |
◆ data()
| QVariant pqAbstractItemSelectionModel::data |
index_, |
int |
role = Qt::DisplayRole |
| const |
◆ setData()
| bool pqAbstractItemSelectionModel::setData |
index_, |
const QVariant & |
value, |
int |
role |
◆ headerData()
| QVariant pqAbstractItemSelectionModel::headerData |
int |
section, |
Qt::Orientation |
orientation, |
int |
| const |
◆ flags()
| Qt::ItemFlags pqAbstractItemSelectionModel::flags |
index_ | ) |
const |
◆ populateModel()
| virtual void pqAbstractItemSelectionModel::populateModel |
void * |
dataObject | ) |
protectedpure virtual |
◆ initializeRootItem()
| virtual void pqAbstractItemSelectionModel::initializeRootItem |
◆ isIndexValid()
| bool pqAbstractItemSelectionModel::isIndexValid |
index_ | ) |
const |
◆ RootItem
| QTreeWidgetItem* pqAbstractItemSelectionModel::RootItem |
