1 # SPDX-FileCopyrightText: Copyright (c) Kitware Inc.
2 # SPDX-License-Identifier: BSD-3-Clause
4 # Used to determine the version for ParaView source using "git describe", if git
5 # is found. On success sets following variables in caller's scope:
6 # ${var_prefix}_VERSION
7 # ${var_prefix}_VERSION_MAJOR
8 # ${var_prefix}_VERSION_MINOR
9 # ${var_prefix}_VERSION_PATCH
10 # ${var_prefix}_VERSION_PATCH_EXTRA
11 # ${var_prefix}_VERSION_FULL
12 # ${var_prefix}_VERSION_IS_RELEASE is true, if patch-extra is empty.
14 # If git is not found, or git describe cannot be run successfully, then these
15 # variables are left unchanged and status message is printed.
18 # source_dir : Source directory
19 # git_command : git executable
20 # var_prefix : prefix for variables e.g. "PARAVIEW".
22 if (
"$Format:$" STREQUAL
23 # We are in an exported tarball and should use the shipped version
24 # information. Just return here to avoid the warning message at the end of
27 elseif (NOT PARAVIEW_GIT_DESCRIBE AND
28 EXISTS ${git_command} AND
29 EXISTS ${source_dir}/.git)
31 COMMAND ${git_command} describe
32 WORKING_DIRECTORY ${source_dir}
33 RESULT_VARIABLE result
34 OUTPUT_VARIABLE output
36 OUTPUT_STRIP_TRAILING_WHITESPACE
37 ERROR_STRIP_TRAILING_WHITESPACE)
38 if (NOT result EQUAL 0)
39 # git describe failed (bad return code).
43 # note, output may be set to empty if PARAVIEW_GIT_DESCRIBE is not defined.
44 set(output
"${PARAVIEW_GIT_DESCRIBE}")
49 if(DEFINED tmp_VERSION)
50 if (NOT
"${tmp_VERSION}" STREQUAL
"${${var_prefix}_VERSION}")
52 "Version from git (${tmp_VERSION}) disagrees with hard coded version (${${var_prefix}_VERSION}). Either update the git tags or version.txt.")
53 if (NOT
"$ENV{CI}" STREQUAL
55 "Please update your fork tags, using this command: `git fetch origin --tags && git push gitlab --tags`.")
58 foreach(suffix BRANCH VERSION VERSION_MAJOR VERSION_MINOR VERSION_PATCH
59 VERSION_PATCH_EXTRA VERSION_FULL VERSION_IS_RELEASE)
60 set(${var_prefix}_${suffix} ${tmp_${suffix}} PARENT_SCOPE)
64 "Could not use git to determine source version, using version ${${var_prefix}_VERSION_FULL}
68 # Extracts components from a version string. See determine_version() for usage.
69 function(extract_version_components source_dir version_string var_prefix)
70 string(REGEX MATCH "^v?(([0-9]+)\\.([0-9]+)\\.([0-9]+)-?(.*))$
71 version_matches "${version_string}
73 # note, we don't use CMAKE_MATCH_0 for `full` since it may or may not have
75 set(full ${CMAKE_MATCH_1})
76 set(major ${CMAKE_MATCH_2})
77 set(minor ${CMAKE_MATCH_3})
78 set(patch ${CMAKE_MATCH_4})
79 set(patch_extra ${CMAKE_MATCH_5})
83 set(source_dir "${ParaView_SOURCE_DIR}
86 COMMAND ${git_command}
89 --no-undefined # error if these names don't work
90 --refs=refs/tags/* # tags
91 --refs=refs/heads/* # branches
92 --refs=refs/pipelines/* # CI
94 WORKING_DIRECTORY ${source_dir}
95 RESULT_VARIABLE result
96 OUTPUT_VARIABLE output
98 OUTPUT_STRIP_TRAILING_WHITESPACE
99 ERROR_STRIP_TRAILING_WHITESPACE)
102 set(branch "${output}
106 set(${var_prefix}_BRANCH "${branch}
" PARENT_SCOPE)
107 set(${var_prefix}_VERSION "${major}.${minor}
" PARENT_SCOPE)
108 set(${var_prefix}_VERSION_MAJOR ${major} PARENT_SCOPE)
109 set(${var_prefix}_VERSION_MINOR ${minor} PARENT_SCOPE)
110 set(${var_prefix}_VERSION_PATCH ${patch} PARENT_SCOPE)
111 set(${var_prefix}_VERSION_PATCH_EXTRA ${patch_extra} PARENT_SCOPE)
112 set(${var_prefix}_VERSION_FULL ${full} PARENT_SCOPE)
113 if("${major}.${minor}.${patch}
" VERSION_EQUAL "${full}
114 set(${var_prefix}_VERSION_IS_RELEASE TRUE PARENT_SCOPE)
116 set(${var_prefix}_VERSION_IS_RELEASE FALSE PARENT_SCOPE)
