#include "vtkPVAdaptorsPagosaModule.h"
| void VTKPVADAPTORSPAGOSA_EXPORT | setcoprocessorgeometry_ (int *mx, int *my, int *mz, double *x0, double *y0, double *z0, double *dx, double *dy, double *dz, int *my_id, const int *tot_pes, char *nframe, int *nframelen, char *version, int *versionlen) |
| Simulation code. More... | |
| void VTKPVADAPTORSPAGOSA_EXPORT | setgridgeometry_ (char *nframe, int *nframelen, char *version, int *versionlen, int *cycleNum, double *simTime) |
| Update the vtkNonOverlappingAMR headers for every frame (time step) This holds ImageData which does not change size, but frame, version, cycle and simulation time change with each frame. More... | |
| void VTKPVADAPTORSPAGOSA_EXPORT | addgridfield_ (char *fname, int *len, int *mx, int *my, int *mz, int *my_id, float *data, bool *down_convert) |
| Add field data in the first grid of nonoverlapping AMR. More... | |
| void VTKPVADAPTORSPAGOSA_EXPORT | setmarkergeometry_ (int *nvp, char *nframe, int *nframelen, char *version, int *versionlen, int *cycleNum, double *simTime) |
| Initialize unstructured grid for ALL markers and allocate total size. More... | |
| void VTKPVADAPTORSPAGOSA_EXPORT | addmarkergeometry_ (int *numberAdded, float *xloc, float *yloc, float *zloc) |
| Add a field to the unstructured grid of markers. More... | |
| void VTKPVADAPTORSPAGOSA_EXPORT | addmarkerscalarfield_ (char *fname, int *len, int *numberAdded, float *data) |
| void VTKPVADAPTORSPAGOSA_EXPORT | addmarkervectorfield_ (char *fname, int *len, int *numberAdded, float *data0, float *data1, float *data2) |
| Set a 3 element vector field in the unstructured grid of markers. More... | |
| void VTKPVADAPTORSPAGOSA_EXPORT | addmarkertensorfield_ (char *fname, int *len, int *numberAdded, float *data0, float *data1, float *data2, float *data3, float *data4, float *data5) |
| Set a 6 element tensor field in the unstructured grid of markers. More... | |
| void VTKPVADAPTORSPAGOSA_EXPORT setcoprocessorgeometry_ | ( | int * | mx, |
| int * | my, | ||
| int * | mz, | ||
| double * | x0, | ||
| double * | y0, | ||
| double * | z0, | ||
| double * | dx, | ||
| double * | dy, | ||
| double * | dz, | ||
| int * | my_id, | ||
| const int * | tot_pes, | ||
| char * | nframe, | ||
| int * | nframelen, | ||
| char * | version, | ||
| int * | versionlen | ||
Simulation code.
Pagosa is a simulation code. It is a closed source code. A copy of the Physics Manual is at http://permalink.lanl.gov/object/tr?what=info:lanl-repo/lareport/LA-14425-M Define the data structures to hold the in situ output VTK data vtkNonOverlappingAMR is required for using the MaterialInterface filter vtkUnstructuredGrid will hold the data currently written to .cosmo files.
| mx,my,mz | number of grid cells in each logical direction |
| x0,y0,z0 | origin on this Processor Element (PE) |
| dx,dy,dz | grid cell size |
| my_id | this PE number |
| tot_pes | total number of PEs |
| nframe,nframelen | string and stringlength |
| version,versionlen | string and stringlength |
| void VTKPVADAPTORSPAGOSA_EXPORT setgridgeometry_ | ( | char * | nframe, |
| int * | versionlen, | ||
| int * | cycleNum, | ||
| double * | simTime | ||
| cycleNum | simulation cycle number |
| simTime | simulation time |
| void VTKPVADAPTORSPAGOSA_EXPORT addgridfield_ | ( | char * | fname, |
| int * | len, | ||
| int * | mx, | ||
| int * | my, | ||
| int * | mz, | ||
| int * | my_id, | ||
| float * | data, | ||
| bool * | down_convert | ||
| fname,len | name, namelength |
| data | data |
| down_convert | if .true. convert data to unsigned character |
| void VTKPVADAPTORSPAGOSA_EXPORT setmarkergeometry_ | ( | int * | nvp, |
| nvp | Total number of markers in simulation |
| void VTKPVADAPTORSPAGOSA_EXPORT addmarkergeometry_ | ( | int * | numberAdded, |
| float * | xloc, | ||
| float * | yloc, | ||
| float * | zloc | ||
| numberAdded | number of markers added on this PE |
| xloc,yloc,zloc | coordinates for each marker added |
| void VTKPVADAPTORSPAGOSA_EXPORT addmarkerscalarfield_ | ( | char * | fname, |
| int * | len, | ||
| int * | numberAdded, | ||
| float * | data | ||
| void VTKPVADAPTORSPAGOSA_EXPORT addmarkervectorfield_ | ( | char * | fname, |
| int * | len, | ||
| float * | data0, | ||
| float * | data1, | ||
| float * | data2 | ||
| fname,len | Name of data, len(fname) |
| data0,data1,data2 | Data by marker |
| void VTKPVADAPTORSPAGOSA_EXPORT addmarkertensorfield_ | ( | char * | fname, |
| int * | len, | ||
| float * | data2, | ||
| float * | data3, | ||
| float * | data4, | ||
| float * | data5 | ||
| data0,data1,data2,data3,data4,data5 | Data by marker |
