This page documents environment variables that affect ParaView behavior at runtime.
| Variable | Description |
PARAVIEW_DATA_ROOT | Change the location of the data root for testing. |
PARAVIEW_OVERRIDE_EXTRACTS_OUTPUT_DIRECTORY | Override output directory used to save extracts. |
PARAVIEW_USE_MPI_SSEND | When set on the server processes, MPI_Send may be replaced with MPI_Ssend (useful for debugging purposes). |
PV_DEBUG_PANELS | When set, debugging text will be printed out explaining the reason for creation of various widgets on the properties panel (pqPropertiesPanel). |
PV_DEBUG_REMOTE_RENDERING | Forces server-side render windows to swap buffers in order to see what is being rendered on the server ranks. |
PV_DEBUG_SKIP_OPENGL_VERSION_CHECK | Skip test to validate OpenGL support at launch. |
PV_DEBUG_TEST | Prints debugging information about the testing framework during playback to stdout. |
PV_ICET_WINDOW_BORDERS | Force render windows to be 400x400 instead of fullscreen. |
PV_MACRO_PATH | Additional directories defined by the user to store macros. |
PV_PLUGIN_CONFIG_FILE | XML Plugin Configuration Files to specify which plugin to load on startup. |
PV_PLUGIN_PATH | Directories containing plugins to be loaded on startup. |
PV_SHARED_WINDOW_SIZE | Similar to PV_ICET_WINDOW_BORDERS except that the value is specified as WxH where W and H is the width and height for the render window. |
PV_TRANSLATIONS_DIR | Additional directories containing translations binary files. |
PV_TRANSLATIONS_LOCALE | Override the default language to load (needed for testing purposes). |
QT_MAC_NO_NATIVE_MENUBAR | Qt flag to force the Qt menu bar rather than the native mac menu bar. |
VTK_DISABLE_OSPRAY | Skip rendering support tests to enable OSPRay. |
VTK_DISABLE_VISRTX | Skip rendering support tests to enable VisRTX. |
| Obsolete Variable | Description |
PV_PLUGIN_DEBUG | (obsolete) Use PARAVIEW_LOG_PLUGIN_VERBOSITY instead. |
PV_SETTINGS_DEBUG | (obsolete) Use PARAVIEW_LOG_APPLICATION_VERBOSITY instead. |
PV_DEBUG_APPLY_BUTTON | (obsolete) Use PARAVIEW_LOG_APPLICATION_VERBOSITY instead. |
PV_ALLOW_BATCH_INTERACTION | (obsolete) No longer needed. |
ParaView supports generating logs that includes debugging and tracking information. The log messages are categorized and it is possible to temporarily elevate the log level for any category using the following environment variables. The value for each of the variables can be a number in the range [-2, 9] or the strings INFO, ERROR, WARNING, TRACE, or MAX (See vtkLogger for additional information about log levels).
